Question about Whirlpool CEM2760KQ Electric Dryer
Heat isn't what it should free of lint - Whirlpool CEM2760KQ Electric Dryer
  • Marc White
    Marc White May 11, 2010
    please clarify what you are asking?
    Problem Solver:
  • 12 Answers
If it heats and little but not enough to dry close first spin cycle you may need to call a repair man the replace the heating coils. there are around five and they slow burn out one by one.
Posted on Sep 14, 2009
Electric dryer heats up and blows air but doesnt dry my clothes
I would check to see that the lint/filter isn't completely clogged up. This could make the dryer warm without allowing it to do its job of drying the clothes.
Also, is the drum spinning? If not, it could be indicative of other problems.
Nov 13, 2012 | Dryers
Why isn't My Kenmore Heavy Duty 70 Series Soft Heat Extra Capacity Electric Dryer drying clothes on any one cycle?
One possibility: Air flow! Make sure that the lint trap is cleaned before each cycle. You likely need to thoroughly clean out the vent piping out the back of the machine- a buildup of lint in here can also restrict airflow.
Sep 04, 2012 | Kenmore 659 Electric Dryer
No heat
Check to make sure the thing that holds the lint trapper isn't clogged as well as the foil hose leading from the dryer to the outside wall.
Jul 28, 2012 | Frigidaire FEX831CS Top Load Stacked...
WHIRLPOOL DUET DRYER-Line clogged with wet lint from daughter air drying all of her delicate heat shrinking clothing. Dryer quit heating all at once that is when I discovered all of the wet lint in the...
if your dryer does not seem to be drying the wet clothes, first check that it is generating heat. If not, check the vent to make sure it is clear.
If the dryer runs but fails to heat clothing, check the circuit breaker. Most dryers use so much electricity that their functions are divided between two breakers. If one has been tripped, that may be why the heating elements aren't functioning. If the dryer still isn't heating, unplug it and pull it away from the wall. There's a service access panel on the back that should be pried free. Inside, you'll find a small black strip of plastic with two blue wires attached. This is the heating fuse. A replacement part can be had for around $15, and takes a little less than 1 minute to swap out. It's unlikely that the heating element itself, which consists of a few metal coils, is broken. If the dryer still won't heat, you're better off getting a replacement dryer than repairing the old one
Dec 08, 2011 | Whirlpool Dryers
Have a Kenmore elite electric dryer model 11062952100 that heats but stops midcycle on both timed and auto. It does start right back up. Does seem to take a little longer to dry clothes. Have checked the...
Check behind the dryer to make sure the tube running to the exit vent isn't clogged or blocked. Then go out side where the vent runs to and make sure it isn't clogged.
Aug 29, 2011 | Kenmore Elite Oasis 6808 Electric Dryer
Dryer will not heat up
G'day, open the door and look at the air flow. There is a lint filter either at the back of door or on the back of machine which should be cleaned after every use. Wikipedia has a good explanations on how dryers work if interested. If lint isn't taken out, it will not heat up - and can even become hazardous towards fires. i hope this helps
Aug 17, 2011 | Frigidaire Dryers
Blower does not blow on profile dryer GE Profile dryer drum turns heats but does not dry
the clip that holds the fan on the back shaft of the motor may have broken so the fan isn't turning, check that , but first check the duct and make sure that you don't have a ball of lint clogging the vent,, also check the venting all the way out of the house,, clean the overhang of the outside vent cover, they get moist and collect lint
Jun 21, 2011 | GE Profile DPSB620GCWW Gas Dryer
How to know if the blower motor isn't working? The heating element is working and the flame is on but not sure if it is blowing while on. It seems to take a longer while to dry.
There is always a kill switch on the door, so you have to hold the switch closed and the dryer will start. You can also take off the exhaust tube and see if you have any air movement there.
But first, when was the last time you check your lint trap to make sure that is isn't obstructed? And I am not talking about just cleaning the lint off of it either. Take the lint trap out, clean the lint out and then take it to you sink. If you run it under water, the water should pass right through without pooling. If it pools, then just clean the screen with a soft brisstled brush and water, then test again.
It is the dryer sheets that close up the screen openings and if bad enough can even cause an overload/overheat situation.
Jun 04, 2011 | Dryers
My dyer heats and tumbles, but doesn't dry
I'd check first for clogged vent hose or clogged lint filter or clogged vent flap on wall (outside).
If that's not a problem, it may be a faulty thermostat. Heating element is probably okay if it heats some of the time.
More info, let me know.
Charlie
Oct 01, 2009 | Kenmore Dryers
The drum is spinning, the heats working, not drying
Try washing both lint screens with soap and water and letting them dry.
Apr 04, 2009 | Asko T700 Electric Commercial Dryer
Whirlpool CEM2760KQ Electric Dryer Logo
80 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
