Question about Kenmore Washing Machines
Kenmore 11016962502 Was able to fix problem with spinning. However, when I put everything together again, the casing does not sit on the base snugly. When I tested the machine water was leaking because it was splashing over the tub and down the back. HELP!
Till the casing toward yourself then enter the lower part of the casing into the part of the base closest to you then lower the casing. The elongaged slots at the bottom of the casing will sit over the two vertical points on both sides of the base
Posted on Sep 13, 2009
2002 malabu won't shift from park to neutral
their is a cable and bushing under the hood on the side of the transmission that cable is broken or the bushing is missing you can fix with a bolt and two nuts put bolt thru then snug the first nut then spin second nut up to the first one then take two wrenches and jam the two nut together by going opposite directions with the two nuts should go into all gears
and bolt and nuts assembly should last forever
Jul 24, 2016 | 2002 Chevrolet Malibu
Tip
How to fix your washer if it does not drain or spin
kenmore whirlpool,roper,kitchenaid,estate,inglis washer if it will not drain or spin,it's a bad lid switch,remove the 2 head screws,flip the top up,pop the 2 spring clip,unplug the lid switch,pull the cabinet off,remove the 2 screws under the lid,replace switch,put everything back together and your done,most times the model number is under the washer lid-mike
on Jan 31, 2010 | Washing Machines
Bought a kenmore 90 series won't drain or spin figured it was lid switch is there a way i can make it work till i can afford to fix it the right way thank you
Nathaniel, if you are sure that it is the lid switch, one way that I have repaired those, with the consent of my clients, is to put a zip tie around the switch and pull it tight. What usually happens is the detergent and moisture gets up around the switch and dissolves the glue holding the two halves of the switch together and it separates and no longer works. Putting the zip tie around the switch holds everything together and will keep the washer running properly. Hope this helps!
Jan 21, 2015 | Kenmore Washing Machines
I've got a Kenmore Elite Oasis gas dryer, model #110.77082600 with an F40 code. Followed troubleshooting instructions on the tech sheet: Snugged connectors on wiring harness Measured resistance on the MC2...
Common to find loose connection on control panel. Unplug machine access control panel area and squeeze the connectors slightly to inside good contact. If not then c. Panel is shot.
Mar 02, 2017 | Kenmore Elite Oasis 7808 Gas Dryer
Mixer head loose
Turn the mixer upside down and you'll see the screws up inside that hold the head to the base. You'll need a long screw driver.
May 15, 2010 | KitchenAid KL26M8XOB Stand Mixer
Washer made loud noise after cycle began
Your coupler is bad and the motor is sitting there spinning inside the coupler. If you remove the case, take the two clips off the pump (You don't have to remove it, just push it out of the way). Then take the two screws out of the clips holding the motor. Un-clip the motor. One piece of the coupler is on the motor shaft. another is a black piece of rubber and the last piece should still be on the transmission. Replace this and put back together. This will fix your problem.
Please rate solution
Sep 07, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite Washer 110.24992300 spin problems
The pressure switch is mis-reporting the water level to the ECU.
Test/replace the pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Washer Tub banging on fast spin
there are some springs that help hold the tub even as it spins also make sure that the washer is level check front to back side to side and corner to corner if it is unlevel they will be out of balance in high speed spin
May 07, 2009 | Kenmore 23822 Top Load Washer
My waher isn't working right
Hi there!
Is it heating at all?
If not, it may be supplying power and waiting for it to heat up before continuing. If the Element is broken, it never will, so will just sit there as you describe.
If this isn't it, please contact again for further steps before rating. Thanks.
Jun 21, 2008 | Kenmore 22422 Top Load Washer
Kenmore washer series 70 shakes wildly during spin during cycle
I have the same kenmore and have experience this before. It is unbalanced. Get a spirit level to check for balance. To rebalance, empty the washer (so it's not heavy), lean over the washer and grab the back, tilt it forward and the auto balancing legs should reposition themselves. Re-check for balance using the spirit level. If still out, adjust the front feet of the washer by screwing the legs up or down (using a wrench). This will cure the problem (unless you have a very unbalanced load of towels for instance). Good luck
Mar 30, 2008 | Washing Machines
Washing Machines Logo
55 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
