Question about Vacuums
Looking for a manual for a jr propo max-66 crystal set
Handi mate jr manual
Check and see if it's plugged in some place. That is a common happening.
Jun 30, 2014 | Hoover Vacuums
I need an instruction/recipe book for the American Harvester Snackmaster Jr. Dehydrator
Not sure if any of these are correct, but here are some instruction manuals for Nesco dehydrators:
http://www.nesco.com/customer_support/owners_manual_download/?lang=english
There is also a cookbook available. Best.
Mar 13, 2011 | Vacuums
Power-mate jr belt appears to be loose, as will not turn brush. Can it be replaced? Looked online and could not find one.
Greetings,
You're in luck! I found the belt for you Powermate Jr. below; If you need help installing this belt, please start a new repair here on Fixya, and I'll be more then happy to walk you through the repair of this. If this helped, please be sure to click the thumbs up icon to rate it as helpful. This helps the Fixya community keep answering questions. Thank you,
http://www.searspartsdirect.com/partsdirect/showPart.pd?partNumber=8192011&productGroupId=0020&supplierId=116&brandId=x&documentId=P0601002&keySuffixId=NA&modelNumber=x&keyId=000010&pageId=00002&productTypeId=x&searchModelNumber=11625513506&subCompDesc=Attachments&brandDesc=KENMORE&modelDesc=CANISTER-VAC&blt=11
Mar 21, 2010 | Kenmore 25812 / 25813 Progressive Bagged...
I need a replacement hose assembly for the hoover steamvac jr. any suggestions where i might find the part?
Only through a Hoover warranty/ service center if still available. If not save your hose ends and find a different hose with adaptable ends
Nov 25, 2009 | Hoover F5411 SteamVac Jr. Canister Vacuum
How do I clean the nozzle of my Hoover steam vac Jr?
No, this assembly can only be rinsed under running water.
Sep 29, 2009 | Hoover F5411 SteamVac Jr. Canister Vacuum
Handi-mate jr. manual
I scanned my manual, but I can't fund any way to attach it here. I can send it to you if you provide your email address.
Mar 19, 2009 | Vacuums
Power mate jr
Did you push the reset? Check where the plug from the power head goes into the end of the handle. Sometmes the female plug gets pushed in to far, then the male part can't plug in and you will have no power to the power head. If this is the case, the the tabs on the tube inside the handle broke off and allowed the female plug to be pushed inside the handle. The other is the switch in the handle is bad, motor could also be bad. If you go to sears.com, click on the parts link, put in your complete model number and you will get a parts list and picture breakdown to look at and you can order parts here also.
Jun 22, 2008 | Kenmore 22812 Bagged Canister Vacuum
F5411 steam vac jr. spot cleaner
There is one manual for the Hoover F5411 SteamVac Jr. available on FixYa.com but, when I opened it, I was not able to actually download a "copy" of the manual.
Instead, it looked like I would have to download / save all the pages of the manual as individual web pages (and then, if I wanted, convert them).
I went to http://safemanuals.com/ (also a very good site) and, although they didn't have the manual there, I was directed to the main www.Hoover.com website.
There, under "manuals," I found the manual, available for download as a pdf file.
http://www.hoover.com/pdfs/manuals/F5411.pdf
Happy steamcleaning!
Peter
Nov 18, 2007 | Hoover F5411 SteamVac Jr. Canister Vacuum
Vacuums Logo
143 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
