Question about Frigidaire Dryers
I keep getting a E9E error code on my Fridgidaire gas dryer. It starts, then stops and flashes the code
  • 1,531 Answers
This is a line voltage error code press the cancel button for three seconds check you power and make sure the power supplied is correct.
Posted on Sep 27, 2009
Frigidaire dryer. What do the error codes e56 and e9e mean?
sounds like you need to consider a new dryer .
May 19, 2015 | Dryers
Shutting down power on my fridgidaire 2008 dryer that stops and lights start flashing
without make/model we have a real hard time looking for a solution
Mar 22, 2015 | Dryers
Frigidaire dryer error code e9e
Hello zabbster - Typically E9E means that there is an issue with the control board receiving low or intermittent voltage and you would need to contact a professional to verify the house wiring and confirm the power supply.
Sep 25, 2012 | Frigidaire Dryers
Model glgq2152es error code E9E
The E9E code is a low voltage/intermittent voltage alert. It says in the troubleshooting manual to press cancel when this appears.
You may want to check the plug or the wall socket to make sure there is not a short occuring. The fault code is not saying your dryer is broken, just to check for proper voltage.
Jan 10, 2010 | Washing Machines
Dryer front load model # GLG22152ESO, Flashes Error Code E9E
Ok, i would also pull the blower assembly and, check it for clog's as well. clean out the entire exhaust hose as well. if this doesn't stop the shut down, you will need to replace the hi limit thermostat and (dryness)sensor(if equipped) as well.
Jun 09, 2009 | Frigidaire Dryers
KENMORE MOD. 417.84092....RUNS FOR A MINUTE ORTWO OR FIVE / STOPS. HEATS UP OK BUT WON'T RUN FOR MORE THAN A FEW MINUTES. ERROR CODE E9E.
The error code E9E indicates that low voltage is being detected at the control board of the dryer.
This could be caused by the following factors:
* The electrical power supply to the dryer is bad. Check the dryer outlet for proper voltage (120 volts AC).
* Unplug the dryer and check the wiring of the dryer outlet plug. A loose wire on the terminal block could cause this problem.
* If you are able to safely access the control board in the console, check the red wire that connects to the heater relay on the board.
(NOTE: The dryer should always be unplugged when accessing internal components.)
A loose wire or burned connection in this area could result in this error code.
* A failed control board could cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 05, 2009 | Kenmore 62602 Electric Dryer
Kenmore 94082 gas dryer: Runs a short time, then stops, E9E error
Apr 25, 2009 | Kenmore 67082 Electric Dryer
My affinity frigidaire dryer keeps flashing an E9E error code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$#
Nov 26, 2008 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Frigidaire dryer
it sounds like the programer on the drying side has had its day
Dec 23, 2007 | Frigidaire GLTF2940ES Front Load Washer
Error codes
if this is a fridgidaire washer, I guess it's a clogged coin catcher. You have remove the front access panel and clean it out. I am working on that now.
Nov 05, 2007 | Washing Machines
Dryers Logo
364 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
