Question about Dell Studio XPS Desktop Computer
How to: Dual Boot system with XP & Vista on separate hard drives
I would like to install the hard drive from my old Windows XP computer into my Vista machine and set it up so I can choose which one to use at startup and easily switch from one to the other.
I know how to install the hard drive in the computer, I just don't know how to set up the dual boot system. Can anyone help?
Thanks!
  • msbel Sep 12, 2009
    I have two separate hard drives so the above info isn't an issue. Thanks anyway!
  • Michael Thomas
    Michael Thomas May 11, 2010
    Hello there: this may help you out some ok
    Reformatting and Repairing the Hard Disk
    loadTOCNode(3, 'summary');
    You may need to reformat and repartition your hard disk if:
    You have only one volume. You have to install each
    operating system on a separate volume of your computer so that each
    installation can retain its own files and configuration information.
    The boot partition is not formatted with the correct file system:
    If
    you want to create a multiple-boot system by using MS-DOS, Windows 95,
    Windows 98 or Windows Me, you have to format the system partition by
    using FAT16 or FAT32 because the operating system cannot start if the
    system partition is NTFS.
    If you want to create a multiple-boot
    system by using Windows 95, Windows 98 or Windows Me along with
    Microsoft Windows XP, you have to format the boot partition by using
    FAT16 because Windows 95, Windows 98 and Windows Me do not support the
    NTFS file system.
    If you want to install Windows 95, Windows
    98, or Windows Me with Windows NT 4.0, Windows 2000, or Windows XP, you
    can format the boot partition by using FAT16 because Windows NT 4.0
    does not support the FAT32 file system.
    multiple-boot system using Windows 98 or Windows Me with Windows 2000,
    or Windows XP, you can format the boot partition by using FAT32. Note
    If you format a Windows NT 4.0, Windows 2000, or Windows XP volume with
    any file system other than NTFS, you will lose all NTFS-specific
    features. This includes some Windows XP features such as file system
    security, Encrypting File System (EFS) settings, disk quotas, and
    Remote Storage. Likewise, Windows 95, Windows 98, and Windows Me do not
    recognize an NTFS partition and identify it as unknown. Therefore, if
    you format a Windows 98 or Windows Me partition as FAT, and a Windows
    XP partition as NTFS, any files on the NTFS partition will not be
    available or visible if you try to access them while running Windows 98
    or Windows Me.
    Supported File Systems
    The following table lists the supported file systems for Microsoft operating systems:
    Operating system Supported file systems ----------------------------------------- MS-DOS FAT Windows 3.1 FAT Windows NT FAT, NTFS Windows 95 FAT Windows 95 OSR2 FAT, FAT32 Windows 98 FAT, FAT32 Windows Me FAT, FAT32 Windows 2000 FAT, FAT32, NTFS Windows XP FAT, FAT32, NTFS Precautions
    Before creating a multiple-boot configuration with Windows XP and another operating system, review the following precautions:
    Before attempting to create a multiple-boot system, be sure to back up your current system and all data files. Each
    operating system must be installed on a separate volume. Microsoft does
    not support installing multiple operating systems on the same volume. If
    you have only one volume on your computer, you have to reformat and
    repartition your hard disk to contain multiple volumes before you begin
    creating a multiple-boot configuration, unless you are simply
    installing another copy of Windows XP. Do not install Windows XP on a compressed drive that was not compressed using the NTFS compression utility. You
    have to use a different computer name for each operating system if the
    computer is on a Windows 2000 or Windows XP secure domain. Install the operating systems in the following order: MS-DOS Windows 95, Windows 98 or Windows Me Windows NT Windows 2000 Windows XPBack to the topTo Create a Multiple-Boot System with Windows XP and MS-DOS, Windows 95, Windows 98, or Windows Me
    loadTOCNode(2, 'summary');
    Note
    You can only install a single instance of Windows 95, Windows 98, or
    Windows Me in a multiple-boot configuration. You cannot configure a
    computer to multiple-boot Windows 95, Windows 98, or Windows Me because
    each of these platforms use the same boot file. For example, you can
    use Windows 95, Windows 2000, and Windows XP, but you cannot use
    Windows 95, Windows 98, and Windows XP.
    You have to install Windows XP only after installing MS-DOS, Windows
    95, Windows 98, or Windows Me to prevent these operating systems from
    overwriting the Windows XP boot sector and the Windows XP startup
    files.
    To create a multiple-boot system with Windows XP and MS-DOS, Windows 95, Windows 98 or Windows Me:
    Ensure that your hard disk is formatted with the correct file system. Install
    the multiple operating systems into separate volumes, in the following
    order: MS-DOS; Windows 95, Windows 98, or Windows Me; and then Windows
    XP. Do one of the following: If you want a multiple-boot
    system with MS-DOS, Windows 95, Windows 98 or Windows Me along with
    Windows XP, install MS-DOS, Windows 95, Windows 98 or Windows Me, and
    then install Windows XP. If you want a dual-boot system with
    Windows 95, Windows 98 or Windows Me, along with Windows XP, you should
    install either Windows 95, Windows 98 or Windows Me, and then install
    Windows XP.
    Install each operating system according to the standard installation procedure.
    Back to the topTo Create a Multiple-Boot System with Windows NT 4.0 and Windows XP
    Using a multiple-boot system with both Windows NT 4.0 and Windows XP is
    not recommended as a long-term solution. The NTFS update in Service
    Pack 5 (SP5) for Windows NT 4.0 is provided only to help you evaluate
    and upgrade to Windows XP.
    To create a multiple-boot system with Windows NT 4.0 and Windows XP:
    Install Windows NT 4.0 and apply SP5, and then install Windows X
    Brigadier General:
  • 4,044 Answers
If XP where your primary OS this would not be a problem. Since Vista is the Primary you are going to need to get a boot loader that will start before either OS does and use that to choose OS at bootup.
Posted on Sep 12, 2009
Testimonial: "Super quick reply, helpful."
  • 125 Answers
To begine we're going to shrink the Windows XP partition on the hard disk andcreate enough space for an installation of Vista. There are two easymethods of doing this - using the GPartEd Live CD and the DISKPARTutility on the Vista DVD. On some systems, depending on the primarystorage controller, We'll then install Vista and use the EasyBCDutility to modify Vista's bootloader to get XP loading properly. Please follow this link for a thorough explanation.
http://apcmag.com/how_to_dualboot_vista_with_xp__stepbystep_guide_with_screenshots.htm
Upgrading windows vista to windows xp in presario 115DX
You cannot 'upgrade' Windows Vista to Windows XP - that is technically a 'downgrade' and would need you to save all your user data on Vista then format you Windows drive then do a clean install of Windows XP.
If you try to install XP over the top of Vista you will have lots of problems because of the difference in architecture and boot manager changes.
The only alternative would be to set up a dual-boot installation where you install XP alongside Vista but would be best done on either a separate disk partition or on a second disk. Normally such a dual-boot configuration would start with having XP installed then adding Vista as the second operating system.
Jan 11, 2012 | Compaq Presario CQ56-115DX Laptop
How to install xp on this unit from vista
You have to format the hard disk before you can insall XP on a Vista machine, or you can try to install a dual boot system. Go to Microsoft.com and search for dual boot system help
Jan 29, 2010 | Computers & Internet
How to uninstall Windows Vista
You must use a full retail or OEM version of XP (not the cd from your old computer) this makes life really easy and can usually be downloaded from the web.
You must also have a genuine XP key, which has not been used on another system.
Next you should know or find out the specifications of your system, to do this goto Manufactures website.
The most important step is to find out if your hardisk is using SATA interface (if so you will require the SATA XP drivers and a floppy disk, as this is the only way that XP can install these drivers.)
Install XP via cd rom by booting cdrom at system start (if you cannot do this then you must access your system bios at first boot by pressing F2 or Del keys(or whatever key your system uses) and change the boot option to cdrom as first drive.
If your system uses SATA press F6 when XP prompts “press F6 to install other” at very beginng of XP install and install sata drivers from floppy.
Jun 12, 2009 | Microsoft Windows Vista Home Premium SP1...
Trying too dual boot xp pro on toshiba tecra m5. conflict image of original xp pro, in slim select bay hdd. Need help with settings so as the same op system can be used on both drives.Any help would be...
in order to dual boot something.... you need to partition the hard disk... if there's only 1... you need a program that will create another partition from drive C...
for example the size of your Hard disk(drive C) is 160gb
you need a program that will split 160gb into 2 it should come out and you will have now two drives (C & D) with a size of 80gb each...(It depends on how large you want the other drives to have)...
the program is called Partition Magic 8.0 if you want that program.. i can send it to you... just contact me in my yahoo messenger... derick_10_02@yahoo.com
now it's time to install the Windows XP in each drive then you'll have a dual boot... or you can install Windows Vista on the other drive... so therefore you'll have Windows Xp and Windows Vista in one PC...
hope it will help you... tnx
Jun 07, 2009 | Computers & Internet
Can the two operating system can be installed in same drive ?
Yes, you can have multiple OS's on the same hard drive, and partition. I've seen it and have done it before to my machines. You can choose at the boot menu which one you want (when installed), and can run Linux or XP, Vista, Mac OS... my personal favorite is a small OS called "SliTaz". It's a light, Linux-based OS that is very functionable to the user.
Mar 14, 2009 | Microsoft Windows XP Professional With...
It possible to run 2 differant os on 2 differant hd on 1 compute
to be honest, im not sure if its possible....you can only do it using dual boot but it only uses a single hardisk with 2 separate operating system.
how to make a dual boot can be found here
supported dual boot configurations here
if you need more information, please let us know
Feb 07, 2009 | Maxtor DiamondMax® 6800 10 GB ATA-66 Hard...
Two hard drives Vista and XP not booting
If you would like to start up in the xp ,At computer start up hit F1 or F2 there are so many ways some times its hold the del key ,once your into the BIOS you can change the boot order of your drives to make the drive xp is on load first .You will have to do this everytime or buy a program that will do it for you .I would just leave the power unpluged on one of the drives until you need it that way it will be safe from a virus or if you have a hard drive crash you always have one good drive .Hops this helps.
Dec 19, 2008 | Microsoft Windows Vista Home Premium with...
WindowsXP not loading after installing Windows Vista Demo Version
You need to get rid of the Vista Demo, and reload xp. You need to keep one or the other I think, you can't keep both operating systems on the same drive. What were you thinking?
Did you install the vista demo as a dual boot setup? Doesn't sound like it.
I hope someone can help you, I can't.
Nov 24, 2008 | Microsoft Windows Vista Ultimate Edition
Multibooting
nope not if its in vista u would nee dto dual boot dl alll latest drivers software for vista then mosttime it works on older stuff
Oct 14, 2008 | Toshiba Satellite A135-S2276 Notebook
Win vista uninstall
Put your window XP disk into the Disk drive. Start up your computer. When it asks you what Drive you want to install it on select C:\ (where Vista is) Say yes to deleting the current Operating System and follow the instructions from there.
You did say you wanted to Uninstall Vista!
If you mean Dual Boot Vista and XP, then you will need to create a Logical Partition of about 10 Gb to install XP on and when asked where to install select this partition. But note that XP will wipe the Boot sector clean of all other Operating Systems which means that if you want to Dual boot then you will have to reinstall Vista again to get Dual Boot functionality.
Apr 14, 2008 | Computers & Internet
Dell Studio XPS Desktop Computer   Logo
206 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
