Question about LG Washing Machines
Filmy brown mess in the drum. I don't know what it is.
  • 736 Answers
Detergents can be so harsh on metal parts so they somtimes include a waxy substance that prevents corrosion .. this can build up and make a mess as well as smell bad .. fabric softner can build up also .. you can clean it out once in a while using a solution of vinigar and baking soda ... here is a site that might help if you have a top loader .. similar things can be done for a front loader ...
http://www.associatedcontent.com/article/397607/how_to_clean_your_toploading_washing.html
there are commercial "washing machine cleaners" that do about the same thing .. Tide makes one that seems to be good .. you can find that here
http://www.tide.com/en-US/product/tide-washing-machine-cleaner.jspx?ms=true&gclid=CPOJ-9yI7ZwCFQRM5QodFzhutQ
Posted on Sep 12, 2009
I tried fixing the chain in the Hampton fan model #b522qi-bn and forgot how to re-plug the wires HELP!!!!
Usually the black wire goes into the L. I don't know what color your wires are but you can try what I have here.
L - Black, 1 - gray or orange, 2 - brown or yellow, 3 - purple
The bad news is just because the switch looks the same on the outside doesn't mean it's the same on the inside.
May 21, 2013 | Hampton Bay Dryers
My AOC 912SW, the screen is pink, I tried the UDPixel and black looks brown, cables and video card are fine. tried them on another computer and the problem persists, any solution
Chances are high that it's your video drivers messing up. Try installing the graphic card drivers from one of the CDs you got with your computer, if you don't have those anymore you can download them from the official site of the graphics card manufacturer.
If you don't know how to find out which graphic card you have, let me know and i'll try to help out.
Jul 25, 2011 | AOC Monitor
Have a 20001 kdx 220. need to know fuel oil ratio
40:1 is generally the ratio for this bike, as long as it was jetted correctly for that ratio and hasn't been messed with.
If you don't know the bike's history, check your silencer isn't ejecting any excess partially burned oil and there's not excessive smoke, also check the spark plug to see how its burning. It should be chocolate brown.
Jul 22, 2011 | 2003 kawasaki KDX 220 R
I have a yellow tint across most of the page on my canon imagerunner c3200 color copier/printer. I don't see it on the first pages but it tends to appear after maybe 20+ pages Maybe related to the...
Bottom line is that your yellow drum is failing. Back ground is very common on this model with older drums. It is not related to temperature. Your best answer is to replace drum. Always make sure machine is turned off durning any drum (imaging unit) change. If the high cost is something you don't want jump into then. Always run very short runs until error code E0000020 apprears. The irC3200 series is without a doubt is predicable. If your going to have an imaging issue it will for sure apprear between 10-20 copiers. If your colour changes to a muddy yellow or brown smear than it will be a cleaning blade failure. These two replaces are easy to do. Good Luck.
Jun 24, 2011 | Canon imageRUNNER C3200 Copier
I have a pto shaft that has boke in my case david brown 885 and i have it torn down to the pto shaft right now i just need to know how to get the shaft out
Take the gears out.Bell housing side of pto shaft, insert punch in hole and use allen wrench to remove plug on shaft end. use punch in allen screw hole to drive shaft out of housing (don't mess up the threads!!)
Aug 16, 2010 | Milwaukee Tool Case Heat Gun
Service recommendations for 200K miles
yes timing belt is a must then a 10,000mile service old school style ,you know back brake drums off ,oil can and grease where needed ,bulbs cleaned spare wheel carrier oiled and greased ,car jack oiled .ect ect
Nov 25, 2009 | 1997 Honda Odyssey
Brown marks on my light coloured clothes
I just noticed My Frigidaire doing the same thing. Using a lightly soapy damp cloth, I cleaned the interior, paying particular attention to the small gap between the drum and the housing. I also took apart the lint pre-filter and screen and cleaned them. There was a filmy build up of the same colored substance. I suspect that dryer sheets are leaving a waxy residue that over time is sufficient enough to rub off on lighter colored, primarily synthetic, fabrics.
Jul 11, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer leaves brown spots on clothing articles. Suspect back seals as gaps are evident and drum is loose within the unit. What is remedy? Cost of seal replacement?? Kenmore 62802 Electric Dryer Deb in Brown...
With the combination of seal gaps and brown spots (streaks) on your clothes, chances are the front (part # 3406129 ~ $26) and rear (part # 279857 ~ $17) drum seals need to be replaced. Run a rag around the seals and check the marks to confirm this is the problem.
Depending how big the gap is, you may need to replace the drum support rollers if they are worn (part # 349241T ~ $24).
The parts are available at Sears. Labor costs will vary depending on where you live and if you're not replacing them yourself.
Let me know if you need more help or information.
Mar 23, 2009 | Kenmore Dryers
White wash contaminated with brown marks
drum bearings are leaking oil into the drum..they need replacing.
Mar 11, 2007 | Hotpoint Aquarius WMA52 Front Load Washer
Washing Machines Logo
57 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
