Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Singer Futura 250E - thread is shredding after 5-6 stitches
A short time ago I began using some rayon embroidery thread I recently bought. Up to this time I have exclusively used Madeira thread. After stitching one design with this new (made in China) thread, my needle broke in half. I put in a new needle & rethreaded but now my machine will only go 5-6 stitches before it shreds my thread at the needle.
I have adjusted the tension from E to 2 & that seemed to help a little bit but it is still shredding even after I went back to my Madeira thread.
Have I done permanent damage or is the machine just not used to this new needle?
Thoughts?
    Top Expert:
  • Singer Master
  • 49,272 Answers
No damage to the machine yet
check the thread size you are using as you may have to use a needle with a bigger eye
thread is made by winding the material around and around then using a product to hold the material ends together
as a result thread will not last indefinitely and will break easily
you may have to use only thread from manufacturers that you know make good thread
Posted on Apr 03, 2017
bargainbox
  • 1388 Answers
SOURCE: mock safety stitch
Sounds like the timing is a little out.
If you remove the needle plate and turn the handwheel manually watch for the lower looper as it swings behind the Left needle....the needles ought to rise by only about 2mm before the looper passes......the looper must pass the needle above the eye to catch the thread, and be so close as to be barely touching the rear of the needles......if the left needle thread is not picked up, it may be the timing, or the distance between needle and looper.
For the uninitiated, there are a myriad of variables in correctly timing an overlocker (serger), and without the manual to refer to the correct parameters, you will rapidly descend down a road of despair....if you move a looper to advance or ****** the timing, you risk looper collision and a broken looper is almost as much as a service, so my advice is do the test to see if the timing is the likely culprit, and if so, take the opportunity to give the old girl a treat.
If you need to save for a while to do it, just use the 3 thread option for the time being.
www.bargainbox.com.au
Posted on May 10, 2008
SOURCE: Singer futura ce-200 problem, pattern mis-alignment
I have had similar problems in the past.
Do you hear a noise from the embroidery unit when the misalignment occurs ? If so, I suspect that your issue may be that you have some resistance under the hoop. Is there extra material that may be rubbing on the machine or catching somewhere. I have found that if I use some masking tape to keep all of the extra material from hitting any other parts of the machine or dragging under the edge of the hoop this error does not occur. FYI: I also stopped using the "optimize stitch speed" option at the same time. I believe that material dragging was causing the problem, but I still wonder about the stitch speed optimization feature.
Posted on Jul 20, 2008
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
Mongo32
  • 111 Answers
SOURCE: Machine will not pick up the bobbin thread.
if your machine's needle threads from front to back, make sure that the flat part of the needle shank points to the rear of the machine. If it threads from left to right, the flat side should face right, etc.
Posted on Jun 11, 2009
SOURCE: Singer 4572 model: thread breaking, skipping stitches
I have this same machine and it does this sometimes, too. I've found it's usually due to a couple of things: 1. The thread is caught on the spool in the little **** that holds the initial starter piece. If you turn the spool around with the **** on the side away from the bobbin maker, that usually does it. 2. The needle is not in with the thread going from front to back (it may be in with the thread going from side to side). 3. The thread is bad. (I had one spool that actually had "lumps" in it!
Hope this helps - good luck.
Posted on Aug 13, 2009
Cotton breaks on Brother Embroidery Galaxie 2100 machine
Try turning down your top tension setting a bit. If its at 4 or 5, i would turn it down to about 3 ish. Cotton thread is more brittle than polyester and rayon thread.
Hope that helps :)
Chris
Jun 05, 2010 | Brother CE5000 Computerized Sewing Machine
How do I shorten the stitch to make a rolled hem? Please help.
For the rolled hem: the needle is in the O2 or right position, the length is 1.5 in the rolled section- you will see this, if you look on the side of the bottom knob- you can decrease this to 1, but you have to stay within the rolled section, the width is 3.5. the stitch selector is on D, the upper looper selector is UP, the blade is engaged and the subsidiary looper is to the right. You can use a decorative thread in the upper looper- Madeira Decor, Superior Threads made for bobbin work, or YLI Pearl Crown Rayon- or use a wooly nylon for excellent coverage and not need to decrease stitch length. I usually don't need to change the length with these threads.
May 21, 2010 | Baby Lock Evolve
Thread keeps breaking
Have you checked any edge the thread might contact for knicks which should be files or sanded down? Also, I had to replace my bobbin case after a number of years as it had kind of stretched out and allowed my bobbin to pop around and consequently broke many threads.
Feb 07, 2010 | Janome Memory Craft 9000 Computerized...
Husqvarna Rose Embroidery Unit problem
Call Viking direct
440-808-6550
800-358-0001
Aug 20, 2009 | Husqvarna Rose
Pfaff creative half-speed and thread breaks
YIKES - what a nightmare! We can approach your problem two ways, but to determine whether the problem is your machine or your design, I need to know if you have been using one design, or if you've tried to embroidery several different designs and are getting threadbreaks about every 10,000 stitches, no matter what design, needle, thread, and bobbin you use.
Here are some rules you should following whenever you embroider on your machine:
  • Change your needle and insert a newly wound bobbin every time you start a new project
  • Use a size Embroidery Needle - size 90 for most projects
  • Check the backside of your design - you should see alot more bobbin thread than embroidery thread. If you don't see enough bobbin thread, loosen your top tension. If the tension is set automatically, change it manually.
  • Your design might be the problem. Some designs have WAY to many stitches. If you haven't already, choose several different designs with different styles - for example, a monogram, a design that is mostly satin stitches, a design that is mostly straight stitches, and so on. Sew one or all over and over so you determine whether your thread will continue to break about every 10,000 stitches.
I hope this helps. Machine embroidery is so much fun once you've learned and practiced. I hope to hear from you - machine embroidery is not hard to learn, but there is a lot to learn. Thanks.
If you want to get right to work, skip the troubleshooting and answer as many questions as you can or have time for. It is possible that your problem is the design and not the machine. Try one suggestion at time so you what helps and what doesn't. Questions first:
  1. Is the machine brand new, or new to you?
  2. Do you have your manual?
  3. Do you been embroidering by machine for a while, or are you just learning?
  4. Does this problem occur with every design you sew, or is it one particular design that you are having trouble with?
  5. How many total stitches are in the design you are trying ot sew?
  6. What kind of thread are you using (rayon, poly, sewing?)
  7. Did you buy the machine from a dealer, and if so, does it have a warranty?
  8. Have you taken lessons on how to use your machine for both sewing and embroidery?
  9. Are you familiar with embroidery backings, needles, and threads and how to choose which to use for a particular project?
Feb 01, 2009 | PfaFF Creative 7570
My rayon threads always shread while embroiedering on tshirts
make sure that you don't have any thead hung in the uptake arm also try useing it without the spool cap and see if that works I never use them because of that problem
Jan 25, 2009 | Brother Disney PE-400D Computerized Sewing...
Bernina Deco 650 Top thread is winding around the bobbin
You should use some klnd of stabilizer under your hoop. I use the paper kind which is thin or there is a heavier tear away stabilizer. I have used all cotton thread for embroidery or you can use rayon. There is a finer thread called bobbin thread for the bobbin but I gernerally use the same as on the top so it will be the same. Are you using an embroidery needle? .As for your thread getting wound around the bobbin the only thibng I can think of is tht it is threaded incorrectly. if it isn't the lack of a stabilizer. I hope this helps but I think it the the lack of stabilizer that is causingyour problems. The needle is going in and our of the same hole during embroidery and is getting stuck on your bobbin. Let me know if this helps! Suz
Jan 17, 2009 | Sewing Machines
Top thread wrapping around hook under needle plate then jamming
Could be the needle is the incorrect size or the thread is not compatible with the embroidery or both. :)
Oct 31, 2017 | Singer CE-100 Futura Computerized Sewing...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
309 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
