Question about Dometic Rooftop RV Air Conditioner
LAST NIGHT WORKING FINE ~ THIS MORNING NOT BLOWING COLD AIR
WAS BLOWING GOOD COLD AIR - THIS MORNING GOT UP AND WAS NOT BLOWING COLD ANY MORE - STARTS OFF BLOWING COOLER AIR ( NOT COLD) BUT THEN TURNS TO BLOWING WARM AIR
  • Ned C Cook
    Ned C Cook May 11, 2010
    Worked fine at night and in the morning it was blowing warm air or low to no air? Does the compressor sound to be running? Or just the blower fans?How long does it coolwhen you say it cools than stops cooloing? Are you on shore power or generator?-Ned
  • 128 Answers
Check one of the following stop the cooling
a- condenser need cleaning
b- condenser fan not operating
1 -check correct voltage comes to the fan motor if ok
2- check capacitor if ok
3-check motor winding
c-low suction pressure
need check for leak before charging.
Posted on Sep 13, 2009
2001 jeep grand Cherokee every time I start it Idles rough and cuts out until warm and if heater is turned on when cold it cuts out really bad and dies. but after completely warmed up runs fine. (?)
ok no engine stated?
if gas engine, ?
I bet never tuned-up up in decade,right?> that gets 99% here.
but it can be far more complex, not guessing,,
what if , the ECT reads wrong.
and the PCM thinks you are in ALASKA,and you are in key west,FL..
so,it floods cranked. and cold running,same...
all EFI cars do that ,everyone, like that.'
forget heater (that blow'r motor sucks 15amps and alternator puts that load on the engine, breaking the CAMELS back, for get that
fix MISFIRE COLD that is the problem.!! real.
and new spark plugs top that list????
a rich engine needs more spark, and on HILLS
and scanning the ECT.
does ECT read correctly first thing in morning before starting engine
yes ECT can be scanned keyon, not started.
correct means if last night was 40f, the ECT is 50f in morning
or lower. say 41f.
-20f wrong, 0f wrong , got that? not blow average of last nights
ambient air temps or garage temps parked. there.
the air cleaner can be packed.up
the ISC valve stuck (my 4.0L did that ever 10k miles)most of the cured in 90s with better ISC
leaking injectr.
misfiring cold
and more
best is a tuneup ,pray, and work form there.
doing tests.
Feb 07, 2017 | 2001 Jeep Grand Cherokee
I have a kenmore 90 series dryer, it was working fine last night but this morning it was only blowing cold air. I checked the dryer vent and checked the heating element and there are no broken coils. What...
check the thermal fuse on the blower housing,if its ok then some units have a heater relay located behind the control panel thats controlled by the moisture sensor board its in the center of the panel but without a model number i cant be sure if this one has it
Jul 17, 2012 | Kenmore Dryers
2001 Monte Carlo battery goes dead over night
check for loose / dirty ground wires and points
indicates a voltage circuit being broken and the ECM is loosing voltage to work
Jun 27, 2017 | 2001 Chevrolet Monte Carlo
I got a 94 chevy cavalier. it was blowing heat just fine last night but when i went to start it this morning i noticed it wasn't blowing. its been cold and vary snowy the last couple of days if that helps.
if the fan is blowing and you have no heat and the car runs at the normal temp range then it would be your heater core needs to be replaced,if you have heat and its not blowing it would be the blower motor needs to be replaced ,or the switch is faulty.
Jan 09, 2011 | Chevrolet Cavalier Cars & Trucks
Air worked fine all last night and his morning.
if the air comes on for a short time and then turns off for 15-30 minutes, the overload protection inside the compressor is shutting down to protect the compressor. this can be caused by blocked supply or return vents, improper charge, bad valves in the compressor, and a multitude of other things. the problem will have to be corrected first.
Dec 14, 2009 | Heating & Cooling
1991 dodge carvan wont start cold
you have water in the fuel line
Mar 05, 2009 | 1991 Dodge Caravan
My 2006 heaer doesn't work
check the coolant level on the radiator..it sounds low
Feb 04, 2009 | 2006 Hyundai Accent
Auxilliary heat just started blowing cold air
SOund like you heating element has a open limit or the sequencer is bad. Another thing that it may be is the element wire has broken. Either way it sounds like you need a technician to come out and repair.
Jan 27, 2009 | Honeywell TH4210D1005 Heater
We left the freezer door open all night by accident two days ago
I turned the fridge side off on mine, and left it overnight (last night!). This morning there is frozen stuff in the freezer. I think the compressor motor just needed ALOT of time to cool down b4 it would work properly again
Jan 11, 2009 | Whirlpool GC5SHEXNS Side by Side...
Intertherm heater blows cold air.
do you have elec or gas heat? nat or propane?
Nov 16, 2008 | Intertherm P3RA-048K Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
1,534 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
