Question about GE Refrigerators
How to snap the grill back on? GE Eterna Series side-by-side
  • 1462 Answers
SOURCE: ge eterna refrigerator loud humming
suspect you have a problem with the defrost system and hence the noise with the fan. take back panel off inside the freezer and if i'm right, melt ice off with a hairdryer. get back to me to say the results if you want
Posted on Aug 23, 2008
Sea Breeze
  • 4654 Answers
SOURCE: ge eterna series fridge side not working
Could you look inside the freezer compartment and after unplugged remove the panel to see if ice is blocking the vent to fresh food compartment. If there is ice it could be something is not working with the defrost cycle. Your refrigerator has a control board that handles these processes but other factors can cause ice buildup in vent. Thanks, Sea Breeze
Posted on Mar 26, 2009
erpaalai
  • 999 Answers
SOURCE: GE Profile Series - Side by Side Refrig - No Water Dispensing
Tubing/resevoir is coiled behind the crispers and can freeze.
Eric
Posted on Jun 20, 2009
mgprice
  • 744 Answers
SOURCE: The frdge side stopped cooling. the freezer side is fine - help!
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck & thanks for using fixya! Mike p.s. please don't forget to rate this free solution.
Posted on Aug 18, 2009
SOURCE: GE Eterna side by side fridge Model ESS2SLGMAWW
I've got the same problem...have de-thawed everything, (this was how we fixed it before) and still can't get water to dispense. Guess another 75 bucks service call...urgggg...
Posted on Feb 15, 2011
GE Eterna Series Side by Side refrigerator ice maker stopped making ice
Please try posting this question in the Kitchen Appliances/ Refridgerator and Freezer Accessories section. It is now posted in the Getzen/Eternana musical instruments section. Getzen Eternas are trumpets.
Feb 20, 2014 | Getzen 900S Eterna Classic Series Bb...
I took the grill on bottom front off can not remember how to put back on.
The grille usually snaps in place. There should be hooks and/or latches for this purpose
Jul 01, 2013 | GE GSS20IEP Side by Side Refrigerator
My refrigerator stopped cooling and my freezer stopped freezing but the freezer is still cooling
Same thing with our GE Eterna Series - off and on for the last two weeks. Took back panel off, looked around, vacuumed dust build up off of the fan blades, etc.; everything worked fine for five good days. Then frig went out stopped cooling. Off and on for the last week. Unplugging it works for a day then back to not freezing and or colling.
Jul 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge spectra eterna series gas stove broiler will not fire up. The glow plug gets hot, but the broiler fails to start.
I have an GE Spectra Eterna Series where the oven comes on and only gets warms no matter what setting the oven is set at. Can some one solve this problem?
Mar 07, 2010 | GE Eterna EGR2000EMBB Gas Kitchen Range
BOTTOM BLACK GRILL GAURD WON'T GO BACK ON
hello, i can help. The grill actually hangs on two little protrusions near the top of the space. Get right down there and look around. you will see where the grill hangs on the top and then merely snaps into position.
Jun 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice will not come out of the door. The auger is not turning
take the ice bin completely out and run water in it until all the ice is clear from the auger
Mar 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Eterna Series side x side refridgerator
Temperature adjust displays not showing, can not adjust temp, is something disconnected?
Dec 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge eterna refrigerator loud humming
Aug 23, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
