Question about Dell 924 All-in-One InkJet Printer
My printer go to print and it makes a clicking noise
  • 114 Answers
It sounds like the prinhead is out of alignment. Try turning off the printer, disconnect the power and then move the printhead by hand to the extreme right position (home). On some printers there is what appears to be a clear mylar (plastic) strip that the printhead rides on. Ths is not actually clear but is used to determine the position of the prinhead at any given time. You can open the printer cover and with a damp cloth just wipe this clean. Do it carefully so you don't put too much strain on the mylar that it could break.
Lou
Posted on Sep 12, 2009
HP 8600 makes clicking noise takes long time to start printing
Solved!
Found a misfed page jammed inside the printer on far
right side ( by the ink service station) - after removing the
"hidden" wad, the printer no longer makes "clicking" sounds
and prints right away!
Officejet Pro 8600
Feb 18, 2013 | HP Officejet Pro 8600 Premium e-All-in-One...
Tip
Noise while printing - Diagnosis Pt 1
<p>Unexpected noise (such as clicking, thumping, or grinding) from an branded device are heard during printer operation.<br /> <br /> <span><b>NOTE: </b></span><br /> Noises can be caused by a number of things, some of which may not be addressed in this document. This document deals strictly with the isolation and potential resolution of known noises through troubleshooting.<br /> <p>The following table describes some of the noises to be expected in a printer functioning normally:<br /> <span>Noise occurs:</span> <br /> <span>Additional information:</span> <br /> During power-up<br /> When the printer periodically makes humming and buzzing sounds as the carriage assembly moves around on the right/left side of the printer, the printer is actually cleaning the ink cartridges. This is a normal operation for the printer. This sequence may happen in the following conditions:<br /><br /><br /> <ul> <li> <p>Before and/or after printing<br /> <li> <p>During power on <br /> <li> <p>After the printer has been on standby/idle for some time<br /> <li> <p>After replacing a cartridge<br /> <li> <p>In the middle of a long print job (such as printing many photos)<br /></li></ul> During printing*<br /> <ul> <li> <p>Paper pickup: There will be some noise during paper pickup due to the movement of rollers and gears.<br /> <li> <p>While printing: The unit has printed a few lines or the paper has been fed into the printing area. There will be some noise during printing due to the movement of rollers, gears, carriage and paper (paper feed and ejection).<br /></li></ul> During paper ejection*<br /> At the end of the print job, there is a louder clicking noise as the paper is being "pushed off" to the output tray.<br /> During copying/scanning<br /> The scanner may make pulsing and dragging noises as it scans portions of the document or it may make a long rolling sound if it is doing a continuous scan. After scanning, it will make a long dragging noise as the scanner is brought back to the home position (could be on the left or right side).<br /> Post-printing with no additional jobs in the queue<br /> Post-completion of a print job and without another job in queue: At the end of a print job, there will be a noise on the left/right side of the printer as the pens are being capped. The printer may try to do this a couple of times, which is normal.<br /> Between print jobs<br /> The printer may make humming and buzzing sounds as the carriage assembly moves around on the right/ left side of the printer during the cleaning of the ink cartridges.<br /> In the accessories<br /> There may be some noise associated with accessories (ADF, duplexer, etc.) during the initial positioning and during normal operation.<br />
on Mar 10, 2011 | Office Equipment & Supplies
I have HP laserjet 1018 printer and it makes noisy sound when it prints. But it prints fine though. What causes making this noise?
The noise is probably due to the print heads aligning and clicking. To try to make this noise a little quieter, clean and align the print heads.
Mar 23, 2011 | HP LaserJet 1018 Printer
Printer makes clicking noise when printing
One reason why the cartridge is making a clicking noise is that there is a washer and spring missing from the inside of the cartridge
if this is the case you will need to buy a new cartridge as it can not be solved until the washer and spring are put in
Apr 26, 2010 | Brother HL 5140 Laser Printer
Printer making a loud clicking noise when printing.
the feed roller gear is stripping; remove the cover and, adjust the gear retainer before it completely fails. (it should be easy to see the gear once the printer cover is removed.
Mar 30, 2010 | Dell 1700n Laser Printer
I have a Kodak ESP 5 and it makes a clicking noise when it is printing. It did not make this noise before. Does anyone know what it could be?
Please take out the printhead and the ink cartridges
Install them back
Again try to print > Is still same noise please call Kodak 18004216699 and get the printer replaced free of charge
Feb 28, 2010 | Kodak ESP 5 Printer
Making a clicking noise when it prints.
Here is a great guide that you can follow to try to identify where the noise is coming from and try to fix it or have it fix.
http://bit.ly/dif9Ck
Feb 06, 2010 | Lexmark T630 Laser Printer
Hp 2115 - clicking noise from carriage, can`t print test page
I have an HP 6110 is always has a grinding noise.No functions work. HP just want me to buy a new machine. They are bad quality 3 in one's. That is for sure.
Jun 28, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Makes noise
Click HERE for HP troubleshooting for your printer.
Jun 06, 2008 | HP Officejet 5610 All-In-One InkJet...
Make sure the printer is not out if ink. When the light flashes this may be the case. Also check the print queue. If it contains pending print jobs and there is no paper the light will flash. Here is how to check print queue: Click Start > click priters and faxes > double click printer icon and see if there is something ... If you see any print jobs delete them right away. and restart your computer. This should solve your problem.
Oct 05, 2007 | HP PSC 2410 All-In-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
53 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
