It keeps going blank
My four year old monitor has started going blank when first turned on. If turned off and turned on again it comes on but goes blank again after a couple of seconds. Any ideas?
  • 1,684 Answers
This is a very common problem with LCD monitors of that age. The heat buildup in the case has cause parts in the power supply called capacitors to blow and short out the power supply. If you can solder you should be able to do the repair yourself. Just go to our web site at: www.ccl-la.com/badcaps.htm Open your monitor and look for the bad caps like in the pictures. Remove and replace any that you see and you should be back going again. Be sure to use high temp replacements (105c) not like from Radio Shack or you will have to do it all over again in a few months. The values are printed on the sides of the ones you take out usually 220uf, 330uf, 470uf and 1000uf values. We carry them in stock if you need them or they can be ordered from several places on the internet. When you install the replacements be sure to insert them with the polarity stripe going the same direction as the bad ones come out. If you don't want to do the repair yourself we do offer a repair service $35 + return shipping. If you have any additional questions just ask.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Sep 12, 2009
Dear Sir, I am facing problem with my Samsung LCD monitor, when I switched on my Computer it shows the bootup screen, after booting the LCD screen goes blank, when i turned off the monitor and again turned...
yes turn on the computer and keep pressing F2 contineulsy immediatly after display observed then menu will be come then highlight on last good known configuation and press enter problem will be solved
Mar 05, 2010 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Monitor goes blank after 2-3 seconds
could be hardware failure but i would try buttons on front of monitor first. notice, usually green led on monitor is green, if it goes to amber, you are loosing sync pulse.
Aug 20, 2009 | Computers & Internet
Monitor screen comes on when computer is first turned on but goes blank within a second. If I turn the monitor off and then on again the home screen appears but then goes blank again. What could be the...
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
Over 21 years of computer and printer support/repair
Jun 26, 2009 | Dell E173FP 17" LCD Monitor
Screen comes up for about 10 seconds, then goes blank
Hello Robert,
Buddy
Corporate Computer
Jun 19, 2009 | LG Flatron L1750S 17" LCD Monitor
ViewSonic VA720 Screen displays briefly then goes blank.
it looks like the Inverter's gone in your screen, it works like a starter in a florescent tube, it 'kick starts' your screen to come on. Turning it on/off many times eventually 'kick starts' your screen and makes it come on eventually.
Jan 15, 2018 | ViewSonic VA720 17" LCD Flat Panel Monitor
Screen comes on briefly then blanks out.
check inverter, memory, and powersupply.
May 31, 2009 | HP w1907 LCD Monitor
Monitor goes to standby mode intermittent.
make sure the video cable is inserted firmly. is it is, the video cable wires are loose inside the monitor which it is not getting the signal, telling it to go on standby mode.
Jun 12, 2008 | LaCie Electron III 22" CRT Monitor
My MAG Innovision Monitor went blank, only works if I stay connected to internet
usually this problem is caused by a faulty inverter circuit. transistors might been running too hot or a leaky capacitors also.not an easy task but try looking down for any defects on high voltage sections.
Feb 24, 2007 | Mag Innovision LT776s 17" LCD Monitor
Monitor goes blank automatically after about 40 minutes...
Hi Randygui, Sounds like the back light inverter board is bad. It's a very common problem. LCD's use four small cold compact fluorescent bulbs to back light the display. (thats what gives the LCD it's brightness allowing you to see it) The inverter board runs these lights and when they go bad they will typically show symptoms like you have or the monitor power light comes on and you have either no display or a very dim display. If you ever have one that has no display but the power light is on you can check by shining a flashlight directly into the LCD from the front (right into the screen) if you can see an image then it's either the inverter board (most likely) or the CCFL bulbs have gone bad. The inverter board and CCFL's are replaceable. Good Luck, El Duderino
Nov 20, 2006 | BenQ FP71G 17" LCD Monitor
Computers & Internet Logo
89 people viewed this question
David Payne
David Payne
