Question about Philips 60PP9352 60" Rear Projection Television
Picture crooked. skewed torwards bottom right corner.
Hi techs! i recently acquired a phillips 60PP9352 from my g/f's mother who traded up to a plasma. awhile ago this problem started and she was unable to figure out how to fix it and never bothered to try, so i acquired the problem as well :)
the entire image is slanted towards the bottom right corner. this results in the image being cut off a bit at the top and bottom in areas. i've also noticed a slight bowing effect near the top and to the right of center. i've checked all the color convergence and tried different picture formats to no avail.
please help me figure this out so i can get as much enjoyment as possible out of this otherwise beautiful set. thanks in advance!
  • 3 more comments
  • golfcav Dec 11, 2007
    Same deal w/ me.
  • sean122774 Dec 11, 2007
    great link, very informative. something i can probley tackle myself. but are you sure doing this will correct the entire picture from being slanted? the colors seem properly converged. but, when i do do the manual multi-point converge the alignment crosses themselves (the base yellow ones) are also slanted. just want to make sure before i open the set up. thanks!
  • sean122774 Dec 19, 2007
    here are some pictures of the tv image to try to clarify the problem:
    this image is slightly blurred but if you look at the top letterbox portion just to the right of center, you can see the slight bowing. and at the bottom how the image is cut off (this is regardless of the picture format, 4:3, panorama, etc.)
    http://img264.imageshack.us/img264/763/t...
    heres another image of the multipoint convergence crosses. as you can see they all slant down and to the right:
    http://img180.imageshack.us/img180/9282/...
    hope this helps. dont think its the color convergence though because there is no blue/red "ghost image". thanks again!
  • sean122774 Dec 20, 2007
    here's what i got:
    Wide Blank 7
    Hor. Shift 24
    Hor. Parallel 8
    EW. Width 29
    EW. Para 36
    EW. Trap 31
    Hor Bow 7
    VER. Slope 42
    Ver. AMPL 28
    S Corr 31
    Ver. shift 31
    Fast Blank 0
    i'll give that a try. but yeah, i think it's just a matter of adjusting these numbers to get the appropriate size. thanks again for all your help.
    and for the sake of the community: this is the solution to the problem i was having. to clarify for future readers:
    you can enter the service menu in most phillips tvs by using your remote. enter the numbers 062596 and hit status. from there you can navigate to the geometry settings. i reached mine by going to "GDE SAM" and then "geometry"
    President:
  • 4,402 Answers
Replace convergance IC
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Posted on Dec 11, 2007
  • 1 more comment
  • Cary Farah
    Cary Farah Dec 11, 2007
    there is only red, green and blue
    the only think else it could be is manual convergence that is the rings on the tubes themselves when moved move the convergence
    and i would not recommend doing that unless you know what your doing.
    does it look like the picture in the link? the fix is about 40 bucks if you do it yourself it's a pretty common problem. there are some resisters that should be checked.
    http://cmpalmer.blogspot.com/2006/11/fix...
  • Cary Farah
    Cary Farah Dec 19, 2007
    your right it doesnt look like the typical convergance problem
    Can you give me the default settings for service mode:
    GDE SAM >
    Geometry >
    Defaults for:
    Wide Blank
    Hor. Shift
    Hor. Parallel
    EW. Width
    EW. Para
    EW. Trap
    Hor Bow
    VER. Slope
    Ver. AMPL
    S Corr
    Ver. shift
  • Cary Farah
    Cary Farah Dec 20, 2007
    they look pretty good these are the only ones that are slightly different.
    VER. Slope - 38 - i changed this to 24 to get more picture in visible range
    Ver. AMPL - 33
    Ver. shift - 30
    now that you have the numbers written down try changing ver. slope
    to a lower number see what happens, then reset it back to what it is and do the next.
TV no sound, picture bleached and skewed
model. serial numbers would be helpful.
Apr 19, 2014 | Televison & Video
Hamilton Beack Kettle Switch Won't Stay On
the funny looking screw is a security screw designed to prevent the average user from taking it apart.
this device was designed to force you to send it back for repair or take it to an authorized repair tech.
the switch has failed crooked due to the toggle axel breaking or pulling out of its socket
Sep 13, 2013 | Kitchen Appliances - Others
I have a 60 inch Philips tv and the picture is kind of blury and a little red. What is tha caused from?
THREE possible reasons for this:
I will list each and describe for you:
1.) If redish picture go to a black and white channel; is the screen somewhat red or black and White? This is adjustable from inside the set.
2.) If colors are skewed or look like they have a red outline it may be a convergence problem. See attached photo.
3.) Some of these sets develop a problem with the coolant which is used to keep the face of each of the three tubes cool; it is called Glycol. You would have to remove back cover and with set on look into each of the three lens (red,green,blue) to see if you have a clear red, green and blue picture.
Which best describes your problem?
Aug 10, 2010 | Philips 60PP9352 60" Rear Projection...
HOW DO YOU CORRECT A SKEWED COPY ON THE COPIER? HAVE CHANGED REGISTRATION ROLLERS, SKEW IS SAME FROM ALL TRAYS & BYPASS. TRIED ADJUSTING THE FOCAL LENGTH ON THE MIRRORS, AND STILL HAS ABOUT 1/8 INCH...
First you need to determine if it is optical skew or mechanical skew.
If the machine is used as a printer then do the computer prints come out skewed? If it is not connected to a PC then print out the counter list using UserTools/Counter. If that prints straight then you are dealing with optical skew. Ricoh's in general are bad about the left front corner of the machine drooping from someone pushing down on that corner. If you have optical skew try lifting up the left front corner of the copier and try making a copy. That might fix your problem.
If the UserTools/Couter print out is skewed then your back to a mechanical skew and there are numerous causes for that.
The optical skew is more likely so let's start there.
Nov 18, 2009 | Ricoh Aficio 1018D Copier
Tv picture crooked towards bottom right.
I have a philips magnavox and had two problems that I recently fixed using kits from www.TvRepairKits.com. I can't say enough about their kits and help. Without them I would have never been able to fix my TV set myself.
The first problem I had was the TV was looking 3D. After doing some homework I found out that this is a convergence problem. I bought a kit, followed the instructions, and to my amazement fixed it myself.
After building my confidence with the 1st repair I decided to get their CRT fluid kit. This kit fixes the dull video,red video, or bright/halo looking video. If you have a magmavox set that is more than 5 years old your tv has this problem already. It happens on every set. As before I bought the kit, followed the instructions, and now my video looks factory new. Once again I wanted to say thanks to the team at Tv Repair Kits for putting together kits that the average joe can use.
ML
Jul 24, 2009 | Philips 60PP9352 60" Rear Projection...
Skewed or crooked paper uptake on Canon Pixma Mx300
Sounds like the roller(s) on the left side is missing or is slick (or split). You should have returned it to the place of purchase when you discovered the problem.
Jul 09, 2009 | Canon PIXMA MP470 All-in-One Printer
My 60" Phillips tv has a blurry picture at the bottom and the top
The convergence output IC's need to be changed. A very common problem with all projection tvs.
Jun 04, 2009 | Philips 60PP9352 60" Rear Projection...
Turn the TV on and it just make a chirping sound no picture
Without examing the set. IN general as a techs when they hear chirping noise is an indication of what is know as a Bad Flyback transformer; You may possibly have a shorted Horizontal Output Transistor or both that will need replaceing.
Apr 24, 2009 | Philips 60PP9352 60" Rear Projection...
Skewness
Hi! I think I may have your anwser. Make sure your moniter resolution is set to 800 by 600 in you display setting on your windows PC. If your running windows XP, right click on your desk top and click "properties" and go to the tab settings. I HOPE that helped :)
Aug 13, 2008 | Lightware VP 800 Plus Multimedia Projector
Phillips 60pp935217
I have a phillips HDTV monitor model 60pp935217, i don't get an hd picture but i do have sound. Please help.
Apr 08, 2008 | Philips 60PP9352 60" Rear Projection...
Philips 60PP9352 60" Rear Projection Television Logo
299 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
