Question about Car Audio & Video
Why do you have to remove the whole rear trim to replace rear speakers when my manual says to pop out grills and remove speakers how do i remove the whole rear assembly
    President:
  • 1,714 Answers
You don't have to if you can access them from the top by pulling the speaker cover. Just take off what you need to access the mounting screws and take them out. Then install the new ones.
Posted on Sep 12, 2009
Replacing quarter glass on left side on 2005 pontiac gto
Remove the door opening weather-strip. Refer to Door Opening Weatherstrip Replacement in Doors.
Remove side sill trim plate. Refer to Door Sill Plate Replacement in Interior Trim.
Remove the lower quarter panel trim. Refer to Rear Quarter Trim Panel Replacement in Interior Trim.
Remove the center pillar upper trim panel. Refer to Center Pillar Upper Trim Panel Replacement in Interior Trim.
Remove the quarter upper trim panel. Refer to Rear Quarter Upper Trim Panel Replacement in Interior Trim.
Remove the center pillar outer applique. Refer to Center Pillar Applique Replacement in Exterior Trim.
Remove the roof drip molding. Refer to Body Side Roof Drip Molding Replacement in Exterior Trim.
Important: It is necessary to use new nuts when reinstalling the quarter window.
Remove the nine quarter window nuts (1), securing the quarter window assembly (2) to the body opening.
Caution: When working with any type of glass or sheet metal with exposed or rough edges, wear approved safety glasses and gloves in order to reduce the chance of personal injury.
Important: When removing the quarter window from the body opening make sure that the attaching pins are clear of the outer body.
Remove the quarter window (2) from the body opening.
Remove the rear seat cushion. Refer to Rear Seat Cushion Replacement in Seats.
Remove the rear seat back. Refer to Rear Seat Back Replacement in Seats.
Remove the door sill plate. Refer to Door Sill Plate Replacement .
Remove the 3 quarter trim panel retaining screws (1).
Starting at the lower edge of the trim panel and moving alternately clockwise and counterclockwise, pull outward on the trim panel to disengage the eight rear quarter trim panel attaching clips (2).
Remove the quarter trim panel from the vehicle.
Remove the 4 radio speaker grille speed clips (1), securing the speaker grille.
Remove the speaker grille (2).
Remove the rear quarter trim panel insulator (1), from the back of the quarter trim assembly (2).
Remove 7 rear quarter trim panel armrest retaining clips (1).
Remove 7 rear quarter trim panel armrest retaining nuts (2).
Gently pry the quarter trim panel armrest insert assembly (3), away from the rear quarter trim panel and remove.
You mite look for a video on youtube !
Dec 23, 2016 | Pontiac Cars & Trucks
Attempting to remove plastic molding around passenger rear vent motor, having difficulty. any help would be appreciated
This is more difficult than it looks because the rear trim panels must be removed in a certain order as they overlap at their edges.
First remove the rear seat.
Remove the step panel from the floor near the side door opening.
Unbolt the 2 seat belt anchors.
Remove the trim panel below the lift gate (rear hatch opening.) Pry the screw plugs out with a small screwdriver and remove the screws.
Pry out the rear speaker grill using a flat blade screwdiver that has been taped to prevent scratches.
Remove the rear speaker mounting screws. Pull the speaker out and unplug the connector.
Remove the passenger side trim panel mounting screws.
Use a panel clip removal tool and pry the clips that hold the trim panel then lift the panel away.
Installation is the reverse of removal.
Apr 07, 2011 | 2002 Honda Odyssey
Need instructions to replace the passenger side mirror and the driver side tail light on a 1999 Ford Taurus 4-door sedan. Thank you, Gary S.
Section 01-09: Mirrors, Rear View 1999 Taurus/Sable Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 06/25/1998 Mirror, Power-Outside Rear View Removal
  1. Disconnect battery ground cable (14301).
  1. Remove front door trim panel (23942). Refer to Section 01-05.
  1. Remove radio speaker grille from cover assembly by squeezing or pinching between thumb and index finger.
  1. Remove two screws from cover assembly.
  1. Disconnect outside rearview mirror wiring connector (C515-LH; C615-RH). Remove wiring guides as necessary.
  1. Remove three outside rear view mirror retaining nuts. Remove outside rear view mirror (17682) while guiding wiring and connector through hole in door.
Item Part Number Description 1 17682 Outside Rear View Mirror 2 N621906-S36 Nut (3 Req'd) 3 F8DB-17D699-
AAW Cover Assembly Rear Substrate-LH 3 F8DB-17D698-
AAW Cover Assembly Rear Substrate-RH 4 N808968 Screw 5 F8DB-18B984-
AAW Speaker Grille-Standard (No Badge)-LH 5 F8DB-18985-
AAW Speaker Grille-Standard (No Badge)-RH 5 F8DB-18K901-
BAW Speaker Grille-Mach-LH 5 F8DB-18978-
BAW Speaker Grille-Mach-RH 5 F8DB-238A35-
AAW Speaker Grille-Blank (No Speaker)-LH 5 F8DB-238A34-
AAW Speaker Grille-Blank (No Speaker)-RH A - Tighten to 6-8 Nm (54-70 lb-in) ------------------
Trim Panel, Door Front
Removal
  1. Remove cover behind inside door handle.
  1. Remove screw from bottom of pull cup retaining front door trim panel to front door (20124).
  1. Remove three screws retaining front door trim panel to front door.
  1. NOTE: Do not attempt to remove more than one pushpin at a time.
    Using Rotunda Windshield and Molding Trim Removal Kit 107-R0401 or equivalent, remove the door trim panel by pulling one door trim panel pushpin at a time from the inner door skin.
  1. Disconnect electrical connectors as necessary. Refer to Section 01-14A.
Installation
  1. Follow removal procedure in reverse order.
  1. Replace all pushpins with new pushpins (N808994-S).
Front Door Trim Panel
Jan 14, 2011 | 1999 Ford Taurus
Replace rear speaker grills on 2004 Toyota Camry
To remove that whole lid you need to remove the rear seat. the bottom half just pulls up and out and the back side pieces have two bolts down low, one on each side, then you can remove the rear seat back and that lid should be held in place with either bolts or push pins. The lid should come out and give you access to replace the speaker grills.
Mar 17, 2010 | 2004 Toyota Camry
How to replace rear speaker grills on 2004 Toyota Camry
Remove the rear seat, pull up and out on the bottom half, remove the sides of the back- one bolt on bottom of each side,remove the backrest, then remove the whole deck lid with speaker grills in it , then you can replace the speaker grills.
Driver side power window stopped working
The door panel is held on by plastic clips and 5 screws. 3 screws are on the bottom and 1 in the pull cup and 1 in the inner door handle.Then grab one of the corners and give a small tug, when you get some of the clips to pop out then proceed around the whole panel. To replace the panel take the clips out of the door with a fork and slide them back into the panel and then line it up on the door and use your hand like a hammer and bang the panel back on. Hope this helps
Jan 12, 2009 | 2004 Chrysler Sebring
Car Audio & Video Logo
18 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
