My Sony Grand Wega LCD Projection HD-TV KDF-60XS955 will not turn on. When you hit the power button a green light flashes 5 times, pauses then a red light flashes 6 times, pauses, then red light flashes 6 times again, and so on and so on. We have to unplug the tv so the flashing will stop and the tv is off.
  • mddle Sep 12, 2009
    Is it easy to replace. Can you send me detailed instructions on how to replace it.
  • 10,594 Answers
It is problem with G1 Board (power supply) that need to be replaced.
G1 Board is mounted at left side of TV if you see TV from its rear.
Power supply (G1 board) part number for Sony KDF-60XS955 is as follows..
A1060177A G1 BOARD, COMPLETE
Available in Part Store (click link to see price info)
Thanks.
Posted on Sep 12, 2009
  • Shahid Electronics
    Shahid Electronics Sep 12, 2009
    Yes, its not so easy to replace because you need to remove lower back cover of TV then center pillar (metal sheet) removal etc. It requires expertise and if you want to replace G1 board by yourself I would recommend to download service manual of TV from HERE for small fee that has all details of disassemble procedure.
    OK, I found free service manual copy of KDF-42WE655 that has same chassis and will help you to replace G1 board.
    Click HERE and download all 9 files, unzip with winrar to get pdf manual file.
I have a Sony KDF-60XS955 tv. It won't power on,
I have that manual. There are three lights to the left of the power button. One is labled LAMP. The manual states "The projection lamp, which illuminates the picture, has a limited life. If the screen becomes dark, the color looks unusual, or the LAMP indicator on the front of the LCD projector TV flashes, it is time to replace the lamp with a new one (not supplied). Use a Sony XL-2200 replacement lamp (not supplied) for replacement. Use of any other lamp may damage the LCD projection TV." I also found in a different page " LAMP LED lights up in red when the lamp for the light source has burnt out." I guess burnt out would be extream. I found one other if you had opened the light bulb cover and didn't close it properly. " If the lamp cover is not reattached securely, the self-diagnostic function may be triggered and the POWER/STANDBY indicator flashes three times." You can down the sony manual at http://www.docs.sony.com/release/KDF60XS955.pdf
Jun 02, 2011 | Sony Grand WEGA KDF-60XS955 60" Rear...
Tv wont power up Standby light keeps flashing.
First step in any Sony LCD projector repair is bulb or lamp replacement. Fixes 95% of problems.
Taking apart and trying to measure things without a known good bulb is a waste of time and effort.
easyab
ConvergenceRepair.com
Feb 26, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
T.V. doesnt turn on and red light keeps flashing at Power Section
Ur power board have dead capacitors,Know how to solders?Take the tv aparts check for capacitors puff up or burst open in the power board.Replaced those capacitors.Or tries Shopjimmy.com,Ebay.com buy a refurbih power board.
Jan 21, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
My sony wega 60 inch tv will not turn on. The
I bought a new blub for it and the light still goes green then red.Anybody know?? mg
Sep 02, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Kdf-60xs955 red continous blinking lamp light
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced.
Please rate this a fixya
Jan 22, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
60 inch sony wega tv
Green flashing is normal. Red flashes are error codes. Count the error flashes.
3x - Lamp cover position or cover detect switch bad.
4x - One or more fans failed RPM test
5x - Lamp power supply/ballast failure
6x - Thermal fuse failed (usually)
Oct 16, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony KDF-42WE655
Bad lamp and/or lamp driver. Try replacing the lamp first.
Aug 20, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
KDF-60WF655
5 red flashes on your Sony indicates the power supply for lamp is not working .Or 5 pin harness to it is not seated properly.Possibly needs replacement..
Aug 01, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
What the @*#@*#
The 4 blink fault code means one of the fans is faulty or the H4 module in the TV.
Jun 07, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Televison & Video Logo
148 people viewed this question
Top Televison & Video Experts
Electro Med Services...
