Question about Music
I've recently purchased and am installing an XMidi 2x2 on my system. I've got XP64 as an OS and using Sonar 8 for a midi music program. What my problem is, when I start Sonar up it wants me to chose the MIDI devices every time. For some reason it's not saving my selections can you help me?
  • 62 Answers
Maybe there is another selection where you have to save your preferences which are different from selections.
Good Luck
Posted on Sep 13, 2009
Voyetra midi orchestrator
The only Voyetra Midi Orchestra Plus software I can know was written for Windows 3.1 and Windows 95. Thus there are several reasons for it to be incompatible with Windows 8. First, it was a 16-bit software; the most common Windows 8 installs use a 64-bit OS. This means that the OS has undergone a number of major changes. The installers are completely different (format/way of talking to the OS). The DLLs that communicate between the software and the OS have also changed. The drivers for MIDI devices will be totally different in the modern OS.
The documentation for Voyetra Midi Orchestra is available here: http://www.turtlebeach.com/support/files/241/ . It is a discontinued product and no one at the company that owns it will be writing a new version of the code for Windows 8. I'm not sure this software will work in Windows 7 32-bit. You might be able to use the software in a compatibility mode from a virtual version of XP. For Windows 7 Pro, Virtual PC and the XP mode package are available as free downloads and can be used if your hardware allows. Windows 8 Pro has Hyper-V but requires a licensed version of any Windows OS that you want to use. For non-pro versions of Windows software, you would need to buy a Pro upgrade. The alternative is to obtain another Virtual machine software (VMWare, for example) and a licensed copy of XP or an older version of Windows. (OEM Windows 7 Pro licenses are still available from many computer hardware vendors.)
I hope this helps.
(Many 32-bit device drivers don't work under Windows 8; older software that didn't run under Windows 7 have similar problems.)
Nov 29, 2013 | Yamaha Music
Tascam 2488 neo mmc control
That seems to be in the midi time sync functions. In cakewalk under options find the midi settings and choose midi device. All of you clock and sync settings should be there. Also I think under the audio menu there are settings for folders and I think a tab for sync is there as well. I use Sonar, which is an upgrade of cakewalk but used cakewalk for a long time. I have it on another computer and will look later to see if I am forgetting something or remembered it wrong and let you know.
Mar 14, 2013 | Tascam 2488NEO 24 TRACK RECORDING...
While using korg m50 editor using usb data cable there is no sound from my lap.the sound is only from my head phone connected to my keyboard directly?
Are you connecting to the laptop and using it as a midi controller? You can record midi notes from the keyboard and send them to your laptop via USB using any midi sequencer program (reason, logic, etc). Create a midi track, select the input of that track as your keyboard, then hit record to play some midi notes. To hear what you record, you have to set the output of the midi track to whatever midi sounds or instrunents you have installed on your laptop.
If you are trying to record the actual audio sound the keyboard makes, use an audio program such as cubase, sonar, audacity, pro-tools, and either mic the keyboard, or connect one of the other audio outputs (1/4" TRS) to an audio input on your DAW, and record an audio track that way (as opposed to a midi track).
Apr 13, 2012 | Korg M50 61-Key Music Workstation Keyboard...
I get random unwanted midi notes triggering while I plug my dd-55 into my emu x-midi 2x2 with my Reaper DAW. I don't know if this is a problem with the emu or the dd-55 itself, but it doesn't...
Check that you don't have MIDI echo on in the DAW. If the MIDI data is echoed, it MAY be merging with the outgoing and when MIDI signals are merged in pieces instead of whole messages the data is corrupted. If you can look at the data stream with software, you should be able to spot the problem. Another problem might be excessive latency of the recording software. Make sure you do not have antivirus or antispyware programs running or network running. The Roland will spill data at much less rate and while the dd55 may overrun the DAW the Roland might not be able to. The key to the problem is to analyze the MIDI data stream that is being recorded.
Sep 05, 2011 | Yamaha DD55 7 Pad General MIDI Digital...
I bought a usb to midi device for my Casio CTK-491, but none of my VST's or DAW's receive midi information from the keyboard, The programs see that there is a midi input and output but the computer...
what program are you running and did you set up your keyboard with the software so it can recognize it. Depending on what software it is your using as soon as I know I can tell you how to get it working. I use my midi keyboard with everything from reason, Ableton live, pro tools logic logic express vdj traktor basically every software!
May 29, 2011 | Casio Ctk491 Midi Keyboard
I recently purchased the Keystation 88es and I have installed the Able Live Lite 6 on my computer. I have installed the USB MIDI series 5.0.1 from the M-Audio website. I have plugged in the usb port as...
First step is to download Midi Monitor http://www.snoize.com/MIDIMonitor/
just to make sure you're actually getting midi over USB into the computer. This is a great utility that I use all the time for troubleshooting midi data issues.
Feb 28, 2011 | M-Audio M Audio Keystation 88es 88 Key USB...
Where do I download midi keyboard drivers for a technics keyboard.
Normally the drivers you load are for the MIDI interface you use, not the keyboard.
The software for the keyboards are usually either system update programs OR editors for the voices, etc. There are many music editor programs and most have some method of communicating via MIDI to external devices.
Apr 22, 2010 | Music
I would like to record my songs compositions in the computer system. pls advise which software and accessories to use. i would also like to have the notations for my compositions, which can be changed...
You haven't said what kind of computer you have but I will recommend a program called Audacity which is very good. It is freeware.You will need a stereo cable with plugs that match the line out jacks on your keyboard on one end and an 1/8" stereo plug on the other. The 1/8" should go into the line in jack on your computers sound card. Audacity is available here:http://audacity.sourceforge.net/ That is to get you started. If you want notation software, I would recommend Finale which you will have to purchase for a full version. Their website is here:http://www.finalemusic.com/ They have trial versions available. Here is a link to another program that might be good although I haven't tried the program:http://www.techspot.com/downloads/1831-magicscore-school.html If you want to use a program to record the midi output of your keyboard, you will have to use a midi cable from the midi out on your keyboard to a midi to usb adapter to your computer. That is the easiest way if your sound card has no midi in/ out jacks. Here is a good link to info about all that:http://www.indiana.edu/~emusic/etext/MIDI/chapter3_MIDI.shtml Let me know if this helps.
Oct 26, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
Casio PX-320 Keyboard has no MIDI driver for MacOS
It would not be a "driver"... if anything you would need a music editing program. Some examples are like "Cakewalk", "Sonar" etc. This assumes you have a MIDI port on your PC. If not, a driver will come with the MIDI interface you need and buy.
Sep 02, 2009 | Casio Privia Keyboard Case
Recording on my Yamaha CP33 keyboard using USB
We're talking about audio recording. If so you must conntect your piano by using the L + R outputs with your sound card or mixer line inputs (that's how I do this). USB is ok if you want to use your piano as a master keyboard (MIDI). Another important thing is that you must have an additional application installed called sequencer ( for example Cubase Sx, Sonar...) which will let you store your digital music. I'm not talking about the proper settings of them because it could take a day or so...:)
Overall, you will have to learn a bit about the home studio, home recording techniques. There are tons of informations on web. A great thing is that you can use your CP33 as a master keyboard to control additional virtual instruments (VST) or for example play different piano samples (check Synthogy Ivory). Possibilites are endless!
Regards
Radek
May 24, 2008 | Yamaha Full-Size Keyboard
Music Logo
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
