Question about Refrigerators
What are the average amp hours used per week on the model mcbr415s
  • Refrigerators Master
  • 3,051 Answers
HELLO THERE
I WILL SEND YOU A COUPLE OF SHEETS TO CALCULATE THIS OK
  1. Alphasolar: System load sizing worksheet Calculate your average amp-hours per day requirement ... This is your average amp-hour requirement per day that will be used to size your ...alphasolar.com/alpha_solar_089.htm - Cached
Posted on Sep 12, 2009
After how many hours a week a employee is considered full time ?
By US federal law a full-time employee is one who works on average at least 30 hours per week, or 130 hours per month.
Nov 06, 2015 | Computers & Internet
I have a sierra spa for 6 people and it take about 5 hrs. to reach 100 degrees. is this common for should I be concerned
Hi Mary.
The average spa increases in temperature 4-6* F per hour for a 240 Volt connection and 1-2* F per hour for a 120 Volt connection.
So... assuming your water is the average of 60* coming out of the tap, and 5 hours later it is at 100*, you are averaging 8* per hour, and that is a VERY fast rate. Thus you can relax.
Now, concerning your second comment, if you are feeling uncomfortable still please feel free to call me at 66O 263 O984, and I will walk you through this step by step.
Nov 01, 2015 | Pool & Spa
What's the average ball speed?
The average ball speed for a bowling is about 10 miles per hour to15 miles per hour with professional bowlers averaging about 20 to 25 miles perhour, the power of the throw depends on the bowling game type you're playingand your physical strength. You can improve your throwing speed by practicingyour throws and strengthening you forearm.
Jul 23, 2012 | Sport & Outdoor - Others
How much would it cost to run this computer for 24 hours? just an estimate is fine
Wattage is simply calculated by multiplying voltage by amperage. Look on the back of your system, and it will say how many amps the system uses. Often, it will also provide the wattage. For instance, the back of a ViewSonic E220 is 2.5A at 120V - ~300 Watts/Hr. An average rate is 10 cents per kilowatt hour, or 3 cents per hour to leave your monitor on. or 72 cents per day.
A computer system can use between 150 and 600 or more watts per hour. Together, it could cost between $20 and $60 a month
Read more: Click Here
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 06, 2011 | HP Compaq Presario SR5350F Desktop PC...
Can i use the timer for a water headter to trun on and off
Paragon 8145-20 is a 240V defrost timer
It is probably not best choice for water heater timer
Timer initiates defrost cycles each 4 hours.
A water heater timer should have more scheduling options.
-For example estimates show average run-time for water heater is 3 hours per day, depending on incoming water temperature, thermostat setting, and number of gallons used.
-To save money using water heater timer, you have to schedule times carefully so water heater runs less than 3 hours per day.
-Now your average electric water heater heats about 20 gallons per hour.
-Average shower uses 4-9 gallons hot water, so water heater needs to run 15-30 minutes (15 summer, 30 winter)
-Average bath uses 12-15 gallons hot water so water heater runs 45-60 minutes
-But lets say you run water heater for 1 hour and make 20 gallons of hot water. Then you take a shower, expecting hot water to remain in tank.
-Here's the problem ... cold water entered the tank to replace the shower water ... and the new cold water is cooling the rest of the tank.
-So a timer means scheduling hot water to match shower and bath events. For example taking shower and bath in immediate succession.
-Or set the timer for each individual hot water event ... for example set timer for 1/2 hour for shower, and later timer turns on 1 hour for bath, or 1-1/2 hr for 2 baths, etc
-> The flexible programming described above is not a characteristic of defrost timers.
I suggest Intermatic WH-31 240V or Intermatic T-104 240V or GE 15207. These are mechanical repeat-24 hour timers with manual override where each day has same schedule.
Digital programmable timers like Intermatic EH40 offer 7-day, 40 event programming. Weekends and weekdays can be different.
To see several box-type timers:
http://waterheatertimer.org/Boxtype.html
Sep 29, 2010 | Paragon 8145-20 Defrost Timer
How many hours used
Unless there is wear on the paintwork on the bed of the machine where the fabric feeds through the average actual time a machine is running is 30 hours per year that is all.
Apr 01, 2010 | Bernina Virtuosa 160
The projector is approximately 4 years old & on average runs for about 60 hours per week, 40 weeks of the year. After fitting a new lamp last October & resetting the projector, the image is still...
Additional information is required for us to assist. Can you better describe what you mean by "poor image"? Are the colors separated? Is the picture out of focus? Are the colors wrong?
Please describe the picture or post a picture of the screen if you can.
Thanks,
Dan
Feb 03, 2010 | Sanyo PLC-XP57 LCD Projector
Daily cost to operate
electric is billed at so many cents per kilowatt hour. a kilowatt hour is 1000 watts per hour. if your heater is rated at 3000 watts, running it for one hour will consume 3 kilowatts of energy at whatever your utility charges per kilowatt. if the amount on your bill is .026 per Kw it'll be 2.6 cents per hour.
Nov 19, 2007 | DeLonghi TRD0715T Oil Filled Radiator...
Refrigerators Logo
111 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
