Question about Samsung HLP4663W 46" Rear Projection HDTV
Broken Wire While replacing the color wheel, I destroyed a 5-Pin wire connecting from the DMD Board to the Balast Assembly. Does anybody know where I can get a replacement wire, or at least offer some kind of advice as too what the proper name for this wire would be, or a part number if there is one. Thanks in advance.
  • kopcych Dec 11, 2007
    A picture of where the wire connects up to the ballast assembly:
I'm having a similar dilema with my color wheel wire that broke off in the dmd board when I opened the light engine to check it. Other than buying a whole new color wheel it occoured to me that an authorized repair center locally would probably have tons of them laying around and possibly one of your wires...........
Posted on Sep 30, 2008
  • 87 Answers
Which color wheel were you putting in?
250a or 674a
Tv Coach
Posted on Dec 20, 2007
After 10 sec. after start up the tv starts to make a large growling sound for about 5 secs. then repeats every 15 sec. sounds like if might be a fan. How many fans in this t.v. . Took the back cover off...
That growling sound is most likely a your color wheel. Often, a color segment breaks free and causes the wheel to become unbalanced. I would suggest searching for a tutorial or "How-To" on replacing it. Basically, you need to disconnect (about 4 connections) and remove the Light Engine (2 screws). Then pull the cover off the color wheel housing (to the left of the lamp, 2 screws). Disconnect and remove the color wheel (2 screws and 2 connectors). You will need to use a vac the glass out from the lost color segment(s). Here's a tip for reassembly: color wheel 4-wire ribbon.. copper on the connector should face you. Also, the lamp door switch must be tripped or the TV will not fire up. I hope this was helpful.
Mar 28, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Just changed color wheel on my samsung dlp now it wont power on
First, the color wheel's 4 pin, copper connector which plugs into the DMD pcb should have the copper facing you as you look into the rear of the TV. Second, be sure you trip the lamp door switch in a closed position. Usually, you can just wrap the wht/blu wire around it, so the TV thinks the lamp door is closed. Try these and listen for the color wheel to spin up. If it does not, the lamp will NOT light. It's built that way. You may have a bad color wheel... which I have personally experienced in the past.
Mar 13, 2010 | Samsung Televison & Video
My panasonic dlp makes a ringing noise near the side where the fan is located what could that be?
Hello!
Replace color wheel assembly! Motor's bearings are gone. It will work for a little while, then will cease and destroy DMD board(part of light engine). Before it ceases, you may notice gamma is getting weird. Sooner, the better! It might cost $200, but it's doable for a skilled technician, if you never pull precise mechanical watch apart and backwards, try to hire professional. It's very easy to brake fragile color wheel, plus there are wires to be re- installed gently and in order, along with rubber gaskets.
good luck,
Alex.
Jul 09, 2009 | Panasonic PT-D5600U DLP Projector
Color wheel plugs into what?
Okay what you can do is first make sure that you haven't lifted any foil paths on the circuit board. To do this work you will have to remove the dmd board. There are tension springs that have to be taken off to be used for screen centering when reinstalling. Use caution when handling dmd. remove sheild and make sure no small copper foils pulled up from the board. Now if the three wires that are used in the 4-pin plug connector are next to each other then you can use the 3-pin plug connector to reinstall them. Just make sure that they connect to the same place as they were removed from. And in the same order. Also, if you look closely you can see how the wires can be removed from one plug connector and installed in the other without cutting anything. Good luck with this, but you can do it if you have patience, Russmann.
May 13, 2009 | Samsung HLN507 50" Rear Projection...
I have a Samsung HRL6167WX/XAP rear projection TV and the TV went out one day when the color wheel exploded. What happened was that the color wheel exploded, then the reapir guy came and replaced that,...
yes , u need to remove this jumper , and the whine would go away , the bulletin is unique for each color wheel , the jumper is very small so just take u time to look for it , is located at the dmd board
May 07, 2009 | Samsung HLN5065W 50" Rear Projection...
Can someone please tell me the DMD part # for a HLR6167WX/XAP?
When you replace the color wheel on certain models you must remove a jumper plug on the DMD board. There is a service bulletin that is usually included with factory replacement color wheels. If the color wheel has a whine to it that means it is probably used and came out of someone else's set. Anyhow the plug can be accessed as I recall without removing the shield of the DMD board. I know this because my first one of those gave me grief, too. Samsung changed wheels on different versions of the same model tv so it gets confusing. You should be ok though after adding/removing the two pin plastic jumper from the DMD board. The only other thing I saw cause a green picture eas the plug that goes from the DMD to the digital board can develop bad connections and can be replaced with a regular DVI type cable. Hope this helps, Russmann.
May 05, 2009 | Samsung HLN5065W 50" Rear Projection...
Tv work come on , all 3 lights blinking
All 3 leds blinking is a Lamp error. Pull the lamp and see if it is blown. If so, replace. This error can also be caused by many parts of the optical block = colorwheel, balast, or DMD board. If you hear a buzz sound when it tries to fire lamp then the lamp is bad. If not listen for the spinning high pitched squeel of the colorwheel coming up. If you hear this but no buzz from the ballast, you likely have a bad ballast. If you do not hear the color wheel, you have a bad color wheel or DMD board.
Dec 07, 2008 | Akai Televison & Video
About the DLP TV you helped with.
Brandon. Locate CN110 on the DMD its a wire plug. Pin 2 is gorund pin 4 is voltage for the color wheel. When the color wheel is off pin 4 should have 5V on it when power is pressed it should have 7v for the color wheel to start. If the voltages on pin 4 is 5V your DM is ok and Color wheel would be indicated as faulty, But if pin 4 is anything less than 5V its the DM which is faulty.
Jun 22, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Need help replacing the color wheel
there is a hiden screw down at the base of the fan assembly also lifting the fan cowl is very thight be sure to remove the ribbon wire and control wire from the DMD modual first. the color wheel also has a rubber gasket that must be reseated when replacing the color wheel.
Mar 23, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung hl-r4266w bottom black line
Your DMD board is now misaligned. It can happen when you changed the color wheel. All you have to do is pull up on your DMD board. I would use both hands, one on each corner of the DMD board and just a little at a time until you get it the way you want it. If you have a space at the top, then just push the DMD board down the same way.
Mar 21, 2008 | Samsung HL-R4266W 42" HDTV-Ready...
Samsung HLP4663W 46" Rear Projection HDTV Logo
89 people viewed this question
Jerry Greenberg
Jerry Greenberg
