Question about Avanti FF1102SS Top Freezer Refrigerator
Avanti FF1102SS refrigerator. The top part works fine the freezer Now the bottom bottom part seems like it is not cooling and water builds up and drips from the top part of the inside down to the bottom and shelves. The water build up is in drops and they form at the top of the inside of the fridge. Please help.
SolutionGuy
  • 331 Answers
SOURCE: Freezer works bottom part does not......
Yep, the ice buildup is restricting air flow to the fresh food compartment. This means you have a problem in your defrost circuit. First, go to your local appliance parts store and purchase a defrost thermostat. Part #WR50X55. It's a G.E. built part and will replace your bad one. UNPLUG YOU FRIDGE! You'll have to empty out your freezer compartment and remove the rear panel. Once this is done, you'll see the defrost thermostat physically mounted to the *evaporator. *(the aluminum coil assy. that's all iced up.) It looks like the one you just bought. Remove it from the evaporator and cut the wires right at the thermostat, then discard it. Strip the newly cut wires exposing 1/2" of wire. Do the same with your new one. Wire color does not matter, just connect one wire of your new part to one of the wires in the freezer, then do the same with the other one. Now mount it (use the clip provided) back to the evaporator where the old one was located. Repair complete. Except that you'll need to completely defrost (melt) all that ice out of there before it'll cool properly again. Grab a hair dryer for this job. Do this before you replace the rear panel, it'll go quicker that way.
Posted on Aug 01, 2007
SOURCE: GE Refrigerator
check the seel on the freezer (if the door is a open)?
Posted on Aug 28, 2007
aborcass
  • 2651 Answers
SOURCE: water in my fridge
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Posted on Nov 18, 2008
lsteward68
  • 331 Answers
SOURCE: Moisture/Ice build-up in Refrigerator
ok first of all. the refrige is in the basement. do you know what the relative humidity in the basement is?
you can check this with a humidity gauge.
Posted on May 26, 2009
  • 340 Answers
SOURCE: Avanti refrigerator not cooling
thermostat set ? might not be defrosting all the way. damper actuator not opening from freezer to refrigerator. is the condenser clean?
Posted on Jun 17, 2009
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
AVANTI REFRIDGERATOR HAS WATER BUILD UP ON THE BOTTOM OF THE FRIDGE
more than likely you have a clogged drain. This occurs when the machine goes into defrost and the melted ice somehow is prevented from draining and therefor refreezing and blocking the drain for the next defrost cycle. Over time it gradually builds and starts voer a larger area. Being you have a top mount refrigerator(freezer on top) there are air ways that connect the freezer to the fridege, which is how its cooled. The best way to resolve this is to unplug the machine for atleast 24-48 hours to let all ice melt
If thats not an option that you want to use the actual repair method would be to 1) unplug the machine 2) empty everything out of the freezer so you'll have room to work 3) take all the shelving and baskets out 4) locate the screws on the rear wall inside the freezer and remove them 5) take the back panel off exposing the evaporator coils ( the aluminum ) 6) directly below the coils is a trough of sorts and the drain is usually in the middle and runs out the bottom, remove the ice by carefully chipping it out or by using a hair dryer or hot water. 7) once all the ice is gone, the drain is visible and water can flow smnoothly down the drain dry the area and reassemble.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 28, 2012 | Avanti FF1101W Top Freezer Refrigerator
Bottom fridge has stopped working. Top freezer is okay. Fridge light is working and thermostat is making operating noise, just no coolness.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 26, 2011 | Avanti FF510 (5.1 cu. ft.) Top Freezer...
The freezer is about 65% cold - the ice cream is melted but the ice cube trays have not. The fridge is about 50% cold, no food has spoiled yet. What is causing the problem?
Clean the condenser fins. Lint build up in the condenser fins is inhibiting heat transfer. Just clean the condenser very well and that might solve your cooling problem.
Jan 06, 2011 | Avanti FF1102SS Top Freezer Refrigerator
My freezer is working fine but the fridge is not cold at all. Not sure what could be the problem. Its an Avanti FF501W
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 11, 2010 | Avanti FF501W Top Freezer Refrigerator
Why does the freezer part of the refrigerator work and the fridge part does not. whirlpool
The cold air is not being transferred from the freezer unit to the refrigerator. A fan normally does this. Sounds like the fan motor has expired.
Oct 09, 2009 | Avanti FF1102SS Top Freezer Refrigerator
Jun 17, 2009 | Avanti EC15W-2 Compact Refrigerator
Refrigerator is not cooling
trying to rechange my avanti mini refrigertor but i dont know where it goes please help me
Nov 28, 2007 | Avanti FF1101W Top Freezer Refrigerator
Aug 01, 2007 | Avanti FF1102SS Top Freezer Refrigerator
Avanti FF1102SS Top Freezer Refrigerator Logo
60 people viewed this question
Top Avanti Refrigerators Experts
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
