Question about Pentair Pool & Spa
My pentair pool heater comes on for about 5 seconds and shuts off. Whats the problem? Thanks
    President:
  • 1,015 Answers
Is the inducer motor coming on only or is there burner ignition and then shut down? Newer pool heaters have a pressure switch for the gas pressure and when a pool heater burner comes on that intial drop in pressure can cause control to time out. Make sure your gas line is large enough for btu rating. Also your gas meter may be undersized for your btu load. The flame rectification sensor is also possibly the problem like the person above stated but i would not call it until you have verified the sensor is working. Dust or debris can cause the sensor to false read.
Posted on Sep 13, 2009
    Champion:
  • 246 Answers
The ignition control is not rectified for flame change it
Pentair Pool Heating Rapidly Increases Temp on Panel then shuts off.
Check the Thermal Reg in the header and also make sure you have adequate water flow thru the heater, make sure your filters are clean and there are no external by-pass valves open.
If you remove the Thermal Reg in the header and the heaters seems to run fine the replace with a new one.
May 03, 2017 | Pentair Minimax NT Heater
My pantair 720 prowler is not working. I have tried just about everything. The green light comes on for about 3-5 seconds and shuts off the unit.
unplug part that goes into pool plug in if it does the same bad control box if it works without unit in pool bad cable or inpool unit
Feb 21, 2013 | Pentair Prowler 720 Pool Cleaner
Pentair Minimax has worked correctly for 5 years. Now is comes on and the heater starts up for maybe 30 seconds and shuts off for a minute or two. It cycles like this for a really long time... a couple...
Usually this means that the flue temperature sensor indicates too high a temperature. this is usually caused by too low water flow through the heater and therefore both the water and the flue temperature is too hot. You should check all the baskets, the pump impeller, the filter and any return devices to make sure water can flow at full rate. It is unlikely but maybe the flue temperature or control board is defective.If all else fails you may be able to call the Pentair technical support line to help diagnose the problem. I hop this helps.
Aug 13, 2011 | Pentair Minimax NT Heater
I have a Pentair 40,000 BTU pool and spa heater. It comes on and then shuts off in about a minute with an error code appearing in the readout. The error code is E05. What does this mean?
The heater is trying to light but cannot. Either the igniter is broken or you are not getting any gas to the igniter. Check to make sure your gas valves are on.
Apr 17, 2011 | Pentair MasterTemp 400000 BTU Pool and Spa...
My mastertemp heater has a error 5 reading. Heater starts, then it shuts down after about 10-20 seconds.
This sounds like the flame rectifier (flame sensor) Below is a link to the manual to trace the part and also to get the part number.
http://pentairpool.com/pool-pro/manuals/section.php?s=28
Jan 20, 2011 | Pentair MASTER TEMP HEATER 400 000 BTU NG...
R=5 CODE ON A PENTAIR HEATER ?
flame sensor falure, probally your pilot.
Jan 16, 2010 | Pentair Minimax NT Heater
Pentair Heater shuts off prematurely when warming spa
check gas pressure could be running out or overheating
Mar 06, 2009 | Pentair MINIMAX NT TSI IGNITER
Pool & Spa Logo
293 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
