Question about Garden
Oil Changed, New spark plug & filter. No start. Pull cord and makes starting noise then off.
  • bulldogchief
    bulldogchief May 11, 2010
    What is the make and model number?
  • 389 Answers
Sounds like contaminated or stale fuel OR dirt/moisture in the carburetor. Remove the float bowl from the carburetor, clean it out, use some carburetor spray cleaner to clean the main jet in the carburetor and reasssemble
Posted on Sep 18, 2009
How do I fix a ryobi bp42 that will not start
It's a 2 stroke & it's relatively new. as long as you didn't score the piston by neglecting to add oil to the fuel mixture, the most likely problem is fuel issues. It only takes a month or 2 to have ethanol fuel absorb enough moisture to ruin the fuel mix. Return all carb settings to original settings. Empty your tank, get rid of your fuel, remix with NON-ETHANOL FUEL MIXED WITH A PREMIUM SYNTHETIC 2-STROKE OIL, such as echo or husquvarna. Purge all the fuel from your lines and primer. Remove the spark plug & pull the cord a few times to dry out the cylinder, run a flame under the spark plug to dry it out. Add 3 drops of fuel mix to the cylinder then replace the plug. Put it on full choke & pull 1 time. Then on 1/2 choke pull to start in 1 or 2 pulls. Still won't start; replace plug & air filter. Let it warm up for 5-10 seconds then turn choke off.
Sep 13, 2015 | Ryobi Garden
Craftsman tractor lt2000 with 17hp Kohler won't start. Ran fine last week. Rebuilt carb, changed oil, and new plug & fuel filter month ago. Has spark and fuel. Cranks but won't fire.
Hi Mike:
It's trying to make you crazy.
I have a model YT4000 and it is a PITA to start when cold.
I pull the air filter, toss in a bit of gas to prime it, and it starts instantly.
I'd suggest that you give yours another try. 3 or 4 times of a couple of seconds each. If it doesn't go, pull a spark plug and see if it is wet or dry. Wet indicates getting gas but no spark. Dry indicates not getting gas.
While you have the plug out, check the spark... Hot & blue.
Hope this gives you some more to work with.
Jun 22, 2015 | Craftsman Garden
After starting and operating the chainsaw for a short time, it dies and I can't get it started again. Suggestions?
Engines require 3 things. Spark, compression and fuel. And chainsaw need 2-cycle oil mixed with the gas.
Assuming you have the right oil-gas mixture and a fresh batch of gas, and you didn't leave old gas in the saw all summer long since last November.
-Take off the dirty air filter and see if saw starts without filter. Do not run without putting in new filter.
-Check exhaust port for mud dobber home or screen clogged with carbon and dirt
-See if saw fires up after squirting WD-40 directly into carburetor
-Check gas line >>> pull gas line loose and see if gas flows out of tank to carburetor
-Take out spark plug > put finger over spark hole and pull cord >> do you feel suction that says you got compression?
-Put spark wire back on spark plug >>> hold spark plug so threads touch bare metal part of spark plug hole >>> pull starter cord and see if spark shows between plug and saw >>> suggest you not hold metal part of spark plug while pulling cord [you'll understand why]
-If spark plug shows spark, then your saw has spark ... so put in new plug and start fresh.
If your saw has compression, spark, and fuel it should start unless carburetor is gummed up because gas was left in tank.
Here is the final trick. Start the saw while spraying WD-40 directly into carburetor and see if you can keep it going with the WD-40. This might take a helper. If this does not work, then carburetor is bad or gas line is clogged at carburetor. Time to take it to the shop.
Oct 06, 2010 | McCulloch Garden
My pressure washers does not start.
Will it start if you pour a small amoum of gas in the carb? If so, carb float needle probably stuck closed.
Jul 06, 2010 | Garden
Drove 96 dodge caravan thru a flash flooded roadway. had to make a quick a quick stop, van died. Have replaced starter because of grinding upon trying to start. Now it just makes one click when trying to...
Check cables must be tight at battery & starter. You must have 12 volts coming out of battery to starter.
Pull your dip stick is it over filled or milky looking. If so you very likely have water in engine.
Can you turn the fly wheel or is the engine locked up?
Drain the oil replace filter remove spark plugs turn engine backward to unlock engine. Drain fuel and replace fuel filter. Remove air filter has it gotten wet? Now crank it over with Air filter & spark plugs out. Now put in new air filter spark plugs dry wires & coils. And start the car, If car starts don't drive drain transmission change filter. If it did not start you may have done damage to computer or wiring.
But you got to see if engine is locked up if 12 volts is to starter & that no water is in oil or fuel.
May 31, 2010 | 1996 Dodge Grand Caravan
Can't start my Troy Built Tuffy tiller. I haven't used it for a year, but it started fine last season. I replaced the spark plug, changed the oil and air filter and filled it with fresh gas. When I pull...
First pull your spark plug out reconnect to the plug wire and ground tot he engine body
Pull the starter cord and see if you have a good clean spark that goes to the electrode and not to the side of the spark plug.
If no spark check your off/on switch
Mar 31, 2010 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Cannot turn engine over to start. Ariens 924 snow blower
pull spark plugs and see if it will pull over if not fuel may have filled the crank case drain & refill to proper level (starter is stuck in lube shaft & movethe gear up & down by hand to free up)
Feb 13, 2010 | Sport & Outdoor - Others
Hard to start, new racher455
1) Check plug & gap if that doesn't work try new plug. 2) Try cleaning air filter 3) Clean out main jet 4) Test petrol filter inside tank if dirty fit new one 5) Take plug out & fit inside HT lead & put to head of engine & see if you can see a spark when you pull the cord
Jan 24, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
I have changed the air filter and bought a new spark plug but my troy built with Honda 160 cc engine will not start.
there is a possibility the c oil is bad, pull the plug and with wire attached pull cord to see if any spark
Aug 07, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
118 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
