Question about Belkin (F5D6230-3) Wireless Router
Ps3 internet connection problem
I have a router and i cant connect router to have internet connection...I did it already but it was interfieng with the normal internet
  • jakatjo Oct 07, 2008
    I have belkin G+ router and cannot configurate it to my laptop because it is vista and the installation disc is not compatible
  • 173 Answers
Click here to fix use link
Posted on Dec 12, 2007
I have a belkin n router model f5d8236-4v1,and im trying to get a open nat for my ps3 so i can host games anyways. i called my isp yesterday and asked them to bridge my modem and i got my pppoe user and...
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to completely bridge the modem
Dec 21, 2010 | Belkin (F5D5231-4) Router
How do i set my ps3 up to get online
Take the ethernet only and attach it to your router. If you are not already using a router for your computer internet connection then if your router has connection software that needs installing for network setup for the router only you run the software on the computer after connecting the router to the PC.
If you use the oruter for your PC connection already then do the following.
  • Connect the Ethernet from the PS3 to the router0
  • On the ps3 Go to settings
  • Go to network settings
  • Go to network connection, select enable
  • Go to Internet connection settings just below internet connection-
  • Push yes when it says you may be disconnected
  • Select wired or wireless
  • For wireless use scan or enter manually
  • Follow on screen instructions.
Once that is set up return to main menu and go to network near the right.
Here is a video instruction:
Dec 01, 2010 | Sony Playstation 3 (PS3) Console
I have a PS3 120GB. Recently installed Hi-Def and wireless in home. The wireless router is not in same room with PS3. Is there a device I can add to the PS3 to enable the wireless features, or does it have...
there is already a built in wireless device for the internet. id say its not working because you need to put your I.P adress, subnet mask, router and DNS numbers into playstation. go to settings on ps3. then network settings. manually install all these numbers. you should be able to get them off your laptop or computer when its connected to the internet. if you cant ring your internet provider to grt them.
Jan 10, 2010 | Sony Playstation 3 (PS3) Console
Cant connect my ps3 psp go to the internet using
Check to see if your router has backwards compatibility to wireless G because the N router uses 256bit encryption coding while the G uses 128 bit encoding. PS3,and PSP use the 128 encryption coding also. If the router does not support 128 bit encoding you will never connect with it.
Nov 22, 2009 | Sony Playstation 3 (PS3) Console
I cant hook up my ps3 to the internet
Does the ps3 have wireless antenna to connect to router?
Sep 20, 2009 | Sony Playstation 3 (PS3) Console
No internet connection
Check your network settings and make sure your system is set to wired connection not wireless
Nov 15, 2008 | Sony Playstation 3 (PS3) Console
Ps3 security code
The security code, that is called network key, is stored inside the router.
Check your router manual, it will tell you how to connect to the router using Internet Explorer.
You put router IP number on Internet explorer bar and open router control panel, then you go into wireless settings, and there you find the key.
Sep 08, 2008 | Sony Playstation 3 (PS3) Console
HELP, cant get an internet connection and Im frusterated!!!!
maybe your DSL does not have wireless connection. this may be the only reason so check 4 any probs. in ur dsl wireless connection.
Aug 08, 2008 | Sony Playstation 3 (PS3) Console
Wireless router wont connect
Hey mentalmc,
I had this problem at least once a month. Try these things out.
1. Make sure any WEP codes are entered EXACTLY as it is for your router.
2. Set up your router so only your PC connected to it can change any settings.
3. Turn off your PC while trying to connect via PS3 WiFi. The good ole Win update likes to download without you knowing it sometimes.
4. If all else fails, call Sony cause you may have a bad WiFi antenna or motherboard.
Jun 25, 2008 | Sony Playstation 3 (PS3) Console
Belkin (F5D6230-3) Wireless Router Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
