Question about Canon Pixma iP6600D InkJet Photo Printer
Why is my canon printer not printing words, only pictures .I can print pictures, but when I try to print works it will not print. I did clean the print head, and soaked it in ispropyl alcohol , and water. lots of ink came out, but it did not solve the problem. I tried printing the words in blue, but it still did not print words. I have printed pictures recently. can you help?
tom19511
  • 1601 Answers
SOURCE: wont print black ink, 3ebk
Here is what Canon says:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=10444
Posted on Nov 12, 2007
SOURCE: Canon IP4300, Yellow prints as green. And all colors prints blue
makklodge:
1. Replace your Ink cartridge with original Ink. (yellow problem is Black catridge problem.
2. Clean your Printer Head using with ISOPROPHYL ALCOHOL.
MrScared
Posted on May 15, 2008
worldvet
  • 859 Answers
SOURCE: Canon MP500 Printer head error
Print heads for nearly all printers are rated at 2 years. You may also need to clean the tube from the resevoir at the ink supply to the cartridge and clean the working resevoir on the cartridge as well. If you are up to this challenge there is a how-to at your manufacturer's web site or you can have a tech do it. Most people, when they realize how inky you will be getting choose to have a tech do this.
It is best to use 100% denatured alcohol, from your hardware store, to clean these parts and tubing. But, you must take precautions.
DO NOT USE DENATURED ALCOHOL UNLESS YOU READ AND FOLLOW THE DIRECTIONS ON THE BACK OF THE CAN.
I'm not kidding about the precautions. I do all this stuff outside when there is a breeze in the air and then I stay up wind of my work.
If you have any questions whatsoever just feel free to comment back to me.
Regards,
Worldvet
Posted on Jun 07, 2008
SOURCE: Printer will not use the magenta color
I had the same problem. It is most likely that your print head nozzles are clogged. Your choices are to attempt to manually clean them, or order a new print head from Canon.
Attempt the manual cleaning at your own risk, this doesn't always work. When it does not work, it means your print head is damaged.
To maually clean the print head. Printer cover up (so you can get to the cartridges and print head). Turn the Printer Off. Remove all the cartridges (I put each cartridge in a separate zip lock bag). Then flip up the lever and remove the print head.
Now heat (don't boil) distilled water (Iused a good sized cook pan and a plastic measuring cup to pour the water). Find a container you can soak the print head in (I used a deep alluminum baking pan). Pour the hot (not boiling) distilled water over the print head molding where the cartridges seat down (hold the printhead over your diposable alluminum pan). Then dunk the molded print head part into the pan numerous times. When the water gets dark change it (be carefuill not to stain the sink). Then slowly pour the hot distilled over the print head (opposite side from where the cartidges seat in). Eventually no ink will be in the water. Set the print head on a dry paper towel, and let it dry for 24 hours or longer. Reinstall the print head, then the catridges. If it worked, your true colors will return. It make take up to 15-20 photos to get all the ink catridges flowing-be patient. You can also just wait 24 hours after re-installing the cartridges, and hopefully it will take less photos to see the correct color match.
Never keep printing when a cartridge is low or out.
Print a few prints every week. Not printing for weeks causes the printheead and the ink flow to clog!
Good luck. I just recovered my S820 and my i900D using the above cleaning method. Like everything else, your mileage may vary! It cost me $1.29 for distilled water and about an hours worth of time!
Posted on Oct 20, 2008
tstraub
SOURCE: Canon i960 printer won't print in blue
Your problem is the print head. You can buy one from Canon for about $95, or find them new from dealers on Ebay for $60 to $70. For a less expensive fix, try to remove the print head and clean it. (You don't need any tools, just remove the ink tanks and pull the print head forward and out. Over time, the receivers tend to get dry & crusted ink on them. Note that the inks used are fast drying inks to keep your pictures, etc. from smudging after you print them. Try not to use solvent. I use q-tips and hot water, then dry using another q-tip. If this does not work, there are commercial cleaning kits available for about $10. Short of that, your choice is to replace the print head or the printer itself. My i960 prints such good quality color prints and normal color printing, that I would fix it rather than replace the printer. I hope the easy cleaning does it for you!
Posted on Mar 07, 2009
Canon Pixma iP6000D prints white streaks thru the words
Run a self clean on the printer a jet may be clogged. print a test page to see if problem persists. If ink is low put a piece of electrical tape over the sensor of the ink cartridge and try again.
Hope this helps!
Aug 13, 2012 | Canon Pixma iP6000D InkJet Photo Printer
My printer prints pictures fine but when i print words it dont print black ink just colors why
Black printer ink in Canon Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
Nov 16, 2010 | Canon Pixma MP500 All-In-One InkJet...
Will not print text from computer (paper feeds
PGBK cartridge was totally blocked. Deep cleaning did not resolve block. Replaced ink cartridge (large black).
Feb 07, 2010 | Canon PIXMA MP160 All-In-One Printer
Won't print text from microsoft word or anything like that, only prints pictures.
Perform a deep cleaning on the printhead:
1) power on the printer
2) access the menu button
3) scroll down to printhead cleaning
4) deep clean the printhead 3x
5) try printing again on Msword
Jan 02, 2010 | Canon PIXMA MP760 All-In-One InkJet...
Will not print black on any word docs
the head may have got jammed....kindly remove the head and try cleaning it
Sep 01, 2009 | Canon PIXMA MP750 All-In-One InkJet...
My printer only prints pictures, no text.
Sounds like your black pigment (PGBK-5) cartridge has clogged up the printhead or similar.
You could try running a single Deep clean on the that colour alone (use Right click printer > printing preferences > maintenance tab > Deep Cleaning)
If that doesn't work you will probably need to either:
- clean the printhead (see this thread)
or
- replace the printhead/cartridge
Hope that helps.
Mar 09, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon i-550 printing in black--the lines are only printing half of the line. In other words, cutting the words in half horozontally
Try cleaning the cartridge by taking a damp paper towel and wiping the ink jets. If you still get the problem, try running the cleaning cycle. If nothing works, then try a new cartridge.
Mar 06, 2009 | Canon BubbleJet i550 InkJet Printer
PRINT HEAD - CANON IP4500 OR OTHERS
Please click the below mentioned link to download a word document containing clean print head procedure:
Canon iP4500- Clean Print Head
Thank you
Aug 01, 2008 | Canon I990 InkJet Photo Printer
Canon Lines in picture and colored word doc
you should check whether the color ink is out or not. If so replace it with a new one. Otherwise just cleaning the print head will solve your problem. To clean the head Go to control panel > open printers and faxes > right click printer icon > Click properties > Find the option "Clean print head" or somthing sismilar. Use it and your problem could be solved. Note: Some printers have seperate software utilities to clean the print head.
Sep 11, 2007 | Canon Pixma iP6600D InkJet Photo Printer
Canon Pixma iP6600D InkJet Photo Printer Logo
20 people viewed this question
old marine
old marine
