Question about HP Pavilion dv9000z Notebook
Toshiba Satellite A100/Pro100 Series - Power on - screen black
Recently added memory, worked well for 10days now nothing; tried Fn+F5 to no avail. Please help.
    Brigadier General:
  • 4,044 Answers
If yo have the original memory try putting that back in and see if it works. If it does double check that you have the correct memory type you are trying to install as it is possible that you ahve a HOT chip situation that is caused by the computer trying to overclock the ram you installed. Double check your bios setting to make sure they are set for Auto-Detect. You should be able to get in after you remove the memory chips if they are the problem.
Posted on Sep 12, 2009
What's your protoshiba satellite A205-S5880 display function keysblem?
Remove the battery. Keep pressed power button 30 seconds. Reinsert the battery. Try again.
If not let it start like this - black screen. And press ONE TIME FN and F5 until the screen comes back again. OR FN and F9.
Apr 11, 2013 | Toshiba Satellite A205-S5880 Notebook
TOUCH PAD FOR TOSHIBA SATELLITE M840 SERIES WON'T WORK, HOW TO FIX?PLEASE HELP :)
Press the function key with the image(mouse/no mouse).For M840 its [ F5 ].
Try [ F5 ] or [ FN ]+[ F5 ]. For other pcs it maybe [ F9 ] .
Sep 02, 2012 | lf New Toshiba Satellite M800 M800D M801...
I have a toshiba Satellite A100/A105 Series that will has been working PERFECT until today. When I turned it on it will not light up anything on the internal monitor. How can I cross over to an external...
Just connect it to an tv using an S-Video cable then with the laptop started press Fn and F5 keys to switch between screens until you have the desktop on the tv.
Sep 07, 2011 | Computers & Internet
The monitor on my Toshiba P25-S5093 does not have any display of any kind; all black. I have display using external monitor.
Does the display show anything before you enter windows? If yes, then press the key to transfer video back to your original screen once you enter windows. It should be the function key "Fn" + F5 - F8. looks for the icon which shows a monitor or says "CRT/LCD".
If it doesn't show anything before you enter windows I'm afraid your screen needs to be replaced. Good luck.
Mar 08, 2011 | Toshiba Satellite P25-S5093 Notebook
The pad for curser not working
did you try the unlick button? fn f9
fn f8 or fn f7 one of those.
get back to us plz
Jun 09, 2010 | Toshiba Satellite A100-S8111TD Notebook
How can I get my screen back on?
ok maybe what happened is that you accidentally enabled the external monitor function. That is when you want to connect your computer to a monitor, projector, etc. your monitor will turn black and you will be able to see the other monitor. most computers you have to press the keys Fn+ either f5 or f8 that will return to your screen.
if the configuration on your keyboard is different look for the key that says CRT/LCD and combine it with Fn if you can not find it try Fn and all the f keys on top (Fn+f1, f2, f3, etc) when you do that wait a few seconds to see if your monitor reacts.
if it works for you don't forget to rate me
thx
May 14, 2010 | Toshiba Satellite A100-S8111TD Notebook
Screen stays black on startup of toshiba satellite L300
have you tried either switching between external and internal monitor usally Fn + F5 on toshiba or try plugging a monitor into the back and see if it displays.
if you get a display on the external monitor then its probably a screen or inverter fault if you donot get a display to an external screen then it is likley t be the graphics on the board itself.
hope this helps
Feb 22, 2009 | Toshiba Satellite Pro L300-EZ1501 Notebook
S-Video Out Port
for A100 series, you can hook up the tv on your toshiba laptop through VGA port on S-video. you need to hook up the tv while the laptop is turned off. toggle the display by simply holding down the Fn button followed by the F5 button. and you need to set the mode on the tv as S-video. or you can go to display settings and set the tv as the secondary monitor. you can extend the display or do cloning.
i hope this info helps you.
Sep 11, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite P200 doesn't boot
Try pressing FN/F5 keys simultaneously, or the key that toggles internal/external Display. Look for the double screen Icons on the keys.
Tap the Pause Key.
Restart and press and hold F8 key when Toshiba logo appears. When the boot Menu appears, select Last Known Good Configuration.
If all else fails ther should be a reset button on the side of the LT. Consult owners Manual for location
Aug 15, 2008 | Toshiba Satellite A100-S8111TD Notebook
HP Pavilion dv9000z Notebook Logo
71 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
