Question about GE Profile Spacemaker 1.8 Cu. Ft. Over-the-Range Microwave
The microwave runs for a few seconds and then automatically shuts off. the digital display resets showing the time entry
  • 525 Answers
High voltage diode short, need to be replced by a technician
Posted on Sep 12, 2009
  • 1 more comment
  • High voltage diode short, need to be replced by a technician
Microwave keeps shutting off after a few seconds and error number H97 shows up on display pad. What does this error mean?
Error code H97 is an indication of a possible failure of the Magnetron, DPC board or the High Voltage Inverter board. It could be just a loose wire connection also between the DPC board and the High Voltage Inverter board.
This failure will require a service technician to diagnose and repair.
Jan 24, 2015 | Panasonic Microwave Ovens
Microwave runs for 5 seconds then shuts down displaying F9 HELP
If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the microwave display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad
Oct 19, 2014 | LG Microwave Ovens
Time
follow the next steps use the VOM and fix it. God bless you
  1. Main control boardIf your microwave runs for a few seconds and stops, the first thing to check is the main control board to ensure that a shortage has not occurred. If the part is defective then it will need to be replaced to prevent continual shut offs. If this is not the issue, the next step would be to check for a faulty touchpad.
  2. Touchpad/Control panelIf the control board is not the issue and your microwave continues to shut off after running for only a few seconds, the next thing to check is your touchpad, which is also known as a control panel. Although uncommon for this issue, symptoms are usually that the display and some buttons are working properly; however, when selected some buttons are not functioning. If this is the case the touchpad will need to be replaced.
Jun 18, 2013 | Panasonic NN-S254BF Microwave Oven
GE spacemaker microwave turns off during cooking and display goes black
Step 1:
Door Switch
If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently
Step 2:
Main Control Board
If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
Touchpad and Control Panel
If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
Touchpad
If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the microwave display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
High Voltage Transformer
If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
Thermostat
If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostat
Step 3:
Step 4:
Step 5:
Step 6:
use the DVOM tester and fix it. God bless you
Feb 08, 2013 | Microwave Ovens
Set clock but time goes off
see this causes and fix it. God bless you
Door Switch If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently.
Main Control Board If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed
Touchpad and Control Panel If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
Touchpad If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
High Voltage Transformer If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
Thermoprotector If the microwave runs for a few seconds and stops the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Thermostat If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostats.
Oct 02, 2012 | Viking VMOS200 Microwave Oven
Microwave starts and runs 2 seconds and stops. Display is jibberish. After resetting date and time, it will again run 2 seconds and then shuts down again.
See this FixYa solution. even if your model number is different.
Oct 26, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker jvm1650sh01 starts to microwave then loses power
May 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker shuts off after a few seconds and asks for the clock to be reset
Ge Spacemaker comes on ok but after a few seconds the noise level goes up significantly and it does not heat. It keeps running until the time runs out but it doesn't heat.
Feb 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
This mircowave shuts off after 59 seconds all of the time ????
Change the Damper Motor and switch. Cost is approx $30.00 and you must remove the microwave from the mounting bracket and remove the cover to gain access to the motor and switch.
Feb 02, 2010 | Sharp R-1874 Convection/Microwave Oven
GE Spacesaver XL 1650 microwave shuts off after a few seconds
this would be the digital control board that would need to be replaced
Nov 27, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Spacemaker 1.8 Cu. Ft. Over-the-Range Microwave Logo
181 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
