Question about HP VECTRA VL PC Desktop
Computer will not read hard drive, at the startup it just says 0mb as if nothing was there, but everything else shows up and also it makes a clicking noise when turned on.
    Brigadier General:
  • 4,044 Answers
There are several possible problems to look for. It could be a faulty hard drive or your hard drive has bad sectors on it. If you have another hard drive try using a different hard drive.
Posted on Sep 12, 2009
I turned off the computer at night, the next day did not start, you feel the hard disk spins and emits always one click - click, the print head that moves quickly. The computer BIOS sees it very slowly...
You can take it to a data recovery specialist. They will hook your drive to another computer and try to recover your data. If they cannot access it through this method, then you may have lost everything.
Mar 12, 2011 | Seagate Computers & Internet
Startup problems and blurry music
bugs sumware run sum cleaner www.ccleaner.com and trendmicro then windows update then cheak your msconfig uncheak alot junk in there starting up go to start run type in msconfig then startup then apply after u uncheak all thats junk in ther acept your wi fi ok
Jan 26, 2008 | Acer Aspire 9412AWSMi Notebook
My computer recently stopped recognizing my Western Digital external hard drive. I tried everything and nothing seemed to work so I figured it was the ciruit board. I removed the hard drive and opened up...
Unplugging the CDROM didn't cause this issue but installing the western digital on that cable did cause your drive numbers to change in BIOS. You need to disconnect the external hard drive from the SATA cable but leave the power connected,then boot windows. Once booted reconnect the SATA cable. Check and see if it shows up in your disk management utility.
To do this, right click on computer, then left click manage. When the management console opens, click Disk Management on the left side and scroll down through your drives. Let me know if it shows up and what it says about the partition on the right, I'll keep my eyes open for your reply.
Chris
Oct 05, 2010 | Western Digital Computers & Internet
Hello, My 8 month old "Mini 9" Inspiron 910 shows "operating system not found" on boot-up and bios shows HDD size of 0MB. Fixed shows STEC PATA 8GB-(PM). Any suggestions? I realize re-installing XP is my...
This means that your HDD is corrupted. This could have happened if your computer was dropped and sometimes it happens even when nothing has happened to it. If you take your computer to a repairman, he will be able to fix the HDD for you. Do not attempt to open the HDD yourself as the smallest piece of dust will ruin the HDD. The repairman will open it in a 100% dust proof room.
What might have happened is that the arm in your HDD has fallen on to the magnetic part of the HDD itself. Most of the data should be able to be recovered. If your laptop is only 8 months old, it should still be under warranty so i recommend that you take it to your suppler and they should fix it for free.
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
Feb 19, 2010 | Dell Inspiron 9100 Notebook
How do i completely wipe out everything on my toshiba laptop?
Go to thepiratebay.org and search for torrent of the windows version you want and download it by most popular and nice torrent downloader Utorrent .if it worls please mark it as helpful thanks
Nov 01, 2009 | Computers & Internet
Seagate Barracuda 7200.12 show 0MB issue
I would first look for a bios update for your motherboard to see if that helps at all.
If your bios did not fully support 1TB and special installation software was used to make it work by a method that uses overlay that would cause it to run slowly
To make it run faster I would have set up a primary partion of around 100GB and installed to that and left the rest of the drive formatted for general storage.
You may still want to look at that as an option.
If not and you did use any overlay software you are going to be restricted to slow speeds try putting it in another computer and transfer anything you want from it that way. when you are done you can actually delete the partitions etc using the other computer to do so.
You could also set it up on there ready to try re-install windows XP
Or it could just be that you have a nasty and I would certainly try get data off and re-format whilst you are at it if you have
If this info was useful then please click
Aug 13, 2009 | Seagate Barracuda 7200.10 320 GB SATA Hard...
System not booting, after installation
Update the driver by using xp , not the installer.
 Start . Right click,MY computer,click properties,click hardware,click device manager, click display adapters, click Update driver.
Mar 05, 2009 | XFX GeForce FX 5200, Graphic Card
Worked fine on my macbook but not by my powerbook g4 or any other computer
I would suspect a corrupted catalog file, these are the map that a comupter uses to find its way around the drive, they are also the first casualty when a crash corrupts something. Disc warrior will write a new catalog and fix everything. PCs do not see discs formatted for macs.
Aug 21, 2008 | Hitachi 500GB External USB 2.0 Hard Drive
Lexar LDP-400 MP3 player (128MB capacity
Formatting the Disk maybe solve it. But if the disk itself is working. Go to Start-> Run -> type "cmd" -> format F: then press "y" and another "y" if it asks you again if the system couldn't read the drive itself. Then this means that your storage on the MP3 Player (that shows as F on your computer) is now broken.
Nov 26, 2006 | Lexar LDP-400 MP3 Player
Can this be fixed?
Oct 03, 2006 | Lexar LDP-400 MP3 Player
HP VECTRA VL PC Desktop Logo
52 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
