Question about RCA HD52W59 HDTV Projection Television
When we try to turn on the tv, it chirps and shuts off
    Problem Solver:
  • 11 Answers
Power supply (switched mode) is shutting down due to either a fault within the power supply itself, or a problem in the line stage (EHT) and the current protection circuit is shutting down to prevent further damage. Flyback diode often fails shutting the power supply down.
A circuit diagram is required in order to repair this.
Posted on Sep 12, 2009
Tv wont come on
Did you try unplugging the TV? Also if that does not work then call the TV provider and ask them for help.
Mar 14, 2016 | Philips TV Tuner Video Capture PCI Card -...
Tv wont turn on just chirps
The power supply in these sets will chirp if there is a short on the secondary side. I would start with the horizontal output transistor. It is really hard to say because everything in the set is run off of this power supply. It would be best to have a technician check this out for you. Thanks for using fixya.
Dec 26, 2009 | Philips Magnavox 51MP392H Rear Projection...
Hitachi rear projection tv wont power on makes a chirp
You could have a bad HV Transformer causing it to shut down.
Jun 19, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Tv has no sound or picture just chirps
Hello hoggsnob,
This problem denotes the startup sircuit trying to turn on and the shutdown circuit trying to shut the TV off, the result is a on-off switching of relay circuits which causes the chirrping sound. The cuase of this issue is usually the convergence ICs have shorted or the Horizontal Output Transistor has malfunctioned (shorted). I would suggest checking the HOT first and then the convergence ICs.
I hope this helps,
Thank you,
Shuittle83
http://www.electron-age-technologies-llc.com
Apr 07, 2009 | Philips Magnavox 51MP392H Rear Projection...
RCA HD52W69D projection tv powers up for second green light
try replacing CP150 on the deflection board
Mar 15, 2009 | Televison & Video
Zenith iqc50h95 50 in rear proj
Rainman, can`t really be of any great help on this one, both techs can be right, the chirp is exactly as you thought, the set is trying to come on but there is a short in the set and it`s shutting down because of the short, could be convergence, low voltage power supply, high voltage power supply, until a tech gets in there and starts un-loading circuits it`s impossible to say where the short is, gonna have to call someone out for this one, good luck with it, BMW Rider
Jan 09, 2008 | Zenith IQC50H95W 50" Rear Projection...
No picture on screen, chirping noise every second from back
again a good set the deflection modules on these sets are pretty reasonable you need to have a tech swap it but i highly suggest that than a new one the chirping is the set trying to start up but going into shut down
Dec 02, 2007 | Samsung HC-P5241W 52" Rear Projection...
PT-43LC14 No Picture, chirping sound when turned on
Most of the time, when there is a chirping comming from a TV set, there is a short somewhere inside the TV set. That chirping noise is the TV's power supply starting up and shutting down because of a heavy load on the power supply. These sets have no user replaceable parts inside them, so play it safe, and call out a pro to assist you in this repair. good Luck PS Please do not forget to rate this thread.
Dec 11, 2006 | Panasonic PT-43LC14 43" Rear Projection...
RCA HD52W59 HDTV Projection Television Logo
148 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
