Question about Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer
When scanning a picture, the picture comes out faded even if the picture is clear and crisp.
  • 125 Answers
Most scanners allow you to chose what resolution that you want to scan the photo at and you may have selected too low a resolution, for example for the web. If you want the highest resolution scan you need to select the TIF option if its there. If not, select the highest number available.
When you say its "faded", do you mean when it prints out or when it shows on your computer screen? If its when it prints, obviously it could be a printer ink issue or maybe your printer is set to "fast print", which gives poor resolution and may look how you explain.
Posted on Sep 12, 2009
Hi there I have a TV Samsung 46 inch model LN46B640R3FXZA It has vertical lines intermittently (more often than not) that slowly show up in different parts of the screen. Thank you Stami
Try cooking the tcon board in the oven...there are some postings on youtube that tell how to do it, if that doesn't help replace the board...Good luck!!
Mar 24, 2018 | Samsung Televison & Video
I have a Samsung rear projection tv, the picture is faded and the colors are not crisp or clean cannot watch it like this what do you think the problem is?
If this is a CRT-type rear-projection TV, the CRT coolant fluid is probably broken down. It's supposed to be clear, but after a long period of TV operation, it turns a yellow-brown color. If you unplug the TV and remove the back, you can look into the tops of the three picture tubes. They should be a clear red, green or blue color, with no yellow-brown tint.
CRT coolant can be changed, but you need to be very good at mechanical work to do it. Besides the safety considerations (picture tubes and other parts may carry a high voltage charge even when the set is unplugged), spilling broken-down coolant on electronics is usually disastrous, so you have to be very careful.
LCD panels used in projector applications may lose contrast if they are overheated (this can be caused by failure to keep the vents clean as recommended in the owner's manual).
You would have to provide your set's model number to get more specific information.
Oct 27, 2010 | Samsung Televison & Video
The picture is fading.. I replaced the lamp. did not work
if the pic is just dull and no longer crisp. polishing the small mirror up front will restore the clarity and brightness most of the time.
Dec 01, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Best settings
Vivid will make the picture look its brightest, press either Status, info or recall on the remote to see what Resolution you are receiving. If 1080i or higher,(720p is higher than 1080i) you should have a very clear and crisp picture.
Aug 09, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Looks blurry, wanting a clear & crisp picture.
In the picture settings, you can choose between hdtv and standard t.v.. That should work for you because not all channels broadcast in the hdtv signal.
Jul 16, 2017 | Televison & Video
Loewe articos 55
had same problem, solved by lamp replacement. back to full glory!
jurgen
Oct 07, 2008 | Loewe Articos 55 55" Rear Projection...
Screen not crisp. words are blurry and colors are faded .
you need to replace the coolant in the cRts. You can get the coolant replacement kit at the following link under the repair kit category. Its called phillips CRT coolant replacement kit. It contains all the coolant you need and the step by step proceedur on cd with pictures so you can do the job yourself. Heres the link.
http://servicemanuals.vstore.ca/
Aug 10, 2008 | Philips 6P4830W 48" Rear Projection...
Fuzzy pictures
The blurry pictures are due to movement. Sometimes adjusting the flash helps.
Mar 19, 2008 | Samsung Digimax S630 Digital Camera
Blue (actual) lamp out of focus. Picture is washed out and milky.
I found a local tv repair guy who sold me the the CRT fluid for $80 and I gave it a go. It wasn't easy, but it worked. If you are really interested I'll tell you how I did it.
Aug 11, 2007 | Philips Magnavox 9P6034C 60" Rear...
Fuji FinePix S602 Zoom - Black strip down picture
If you see the black line on your images and it is a very crisp clear line then it is an issue with the cameras image sensor. If the line is less crisp and clear then it may be a more simple of contamination in/on the lens. If the line is crisp and clear and the camera is under warranty get it fixed or replaced. If it is out of warranty look into getting the CCD component replaced at a repair facility. There is an outside chance that it is just the connector which bridges the sensor to the processing board - but that usually manifests all over the image, not just in 1 strip. David Millier Advance Camera Repair
Feb 11, 2007 | Fuji FinePix S602 Zoom Digital Camera
Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer Logo
95 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
