Question about HP VECTRA VLI8 P3 Motherboard (KZM6120)
Initial configuration how can go to the initial configuration the bios somebody toll me so wiht a jumper but i dont now sorry for my english
  • shynomsk Dec 12, 2007
    thank for your help its so usefull
  • m3joe Dec 17, 2007
    Rayaz, can you explain the procedure for jumpering the cmos clear headers? Do it with computer on or off, battery in or out, etc.?
OK. Found something interesting. There is a little red box with 10 switches on it. The box is an inch long and half a centemetre wide. Each switch is labled in sequence; 1, 2, 3, etc.
There are little charts or tables or whatever on the mainboard that describe what each switch can do.
This one say's:
CLEAR CMOS...............SW1-5....ON
CLEAR PASSWORD........SW1-4....ON
KEYBOARD POWER ON...SW1-3....ON
BIOS CRISIS RECOVER...SW1-2....ON
Posted on Oct 16, 2008
    Problem Solver:
  • 17 Answers
Do you want to get back to the default configuration (meaning clear the CMOS) or do you want to go to the BIOS and clear the settings?
In case your machine is booting into the bios you can then clear the bios settings back to the normal through the bios. Your access to the BIOS depends on your hardware. Most motherboards that you buy will go to the bios when you press DEL key, while some branded boards work if you press F2 (HP for instance), and CTRL+ENTER (Dell), etc. You can then select the option to clear the bios to the original setting.
However if your machine is NOT booting, you will have to try clearing the CMOS, which means removing the jumper from the usual 1-2 pins to the 2-3 pin. The placement of the CMOS jumper changes based on your board, but if you take a torch and just get a good view of your motherboard you will see it most cases (it will have CMOS printed) and is usually located near the CMOS battery. However some boards DONT have a CMOS Clear jumper but they will have the headers (the pints wont be soldered) and then you need to use a screw driver to get the result!
Posted on Dec 11, 2007
I want to disable the system password on my dell computer
I assume that you have the password? Restart your computer. As soon as you see the dell screen, hit the f2 key. This will take you into setup. Look through the different menus and you will find the password options somewhere. You should be able to disable it there.
Mar 02, 2011 | Intel D865GBF Motherboard
Hello,sorry my english is not good, i have a problem with my thinkcentre M52 . when i start the comp it writes enter system password.i press enter and it goes into the Bios,but i cant change anything into...
Someone has put a password on the BIOS - you must input it before entering the BIOS and the normal boot procedure. Because of the way IBM are build you can't reset the password by removing the battery, but only by performing a low level BIOS upgrade - which only a dealer can do. You will have to take it to one.
If you aren't the one that put that password and noone had access to it then the motherboard is dying - replace it before it's too late and all your data is lost.
Jan 30, 2011 | IBM ThinkCentre M52 8113 - P4 551 3.4 GHz...
Sir my problem is that my SATA hard disk not detected by system. Also when i detect the SATA/IDE hard disk system hang, and nothing happen. But that time keyboard not hang. My SATA ports work...
Each PATA device (disk-drive or CD/DVD) drive has some small jumpers.
For the two devices connected via the one ribbon-cable,
set the jumpers on one device to the MA(ster) setting,
and set the other device to the SL(ave) setting.
Or, set both devices on the one cable to the C(able)S(elect) setting.
When properly set, both devices will be quickly and properly detected.
Be sure that your BIOS SETUP has been configured to allow SATA devices,
i.e., not set to "disabled" mode.
Nov 05, 2010 | Intel D915GAV Motherboard
I dont have the bios pasword kav60 luwcx0b0069443f2ea1601
you can disable the Bios password by opening your laptop to view the motherboard, look carefully on the jumper settings, you will identify password jumper setting on your motherboard, remove the jumper on the two pins. by doing so, you have disable the password and can now access your Bios configuration
Sep 24, 2010 | Gateway Computers & Internet
How to break BIOS password wiht plug out cmos battery or jumper
Do this when PC is off.
The jumper is a 2 pin jumper and there are 3 points on the motherboard where it is connected. So one pin is empty. Say pins are numbered 1 - 2 - 3 and the jumper is on 2 - 3.
Now unplug the jumper and put it on 1 - 2 and wait for a  minute. Then put the jumper back to 2 - 3 and start the computer and the password and any other settings should be removed and set to default.
HTH,
Regards,
Deboo
Feb 22, 2009 | Intel Computers & Internet
Dfi infinity freeze at logo screen
there is a jumper on the motherboard for that perpose, should reset on it 3 jumper it is alway on pins 1-2 move it to 2-3 for a few secound and than move it back and reboot system
rod
Feb 04, 2009 | DFI INFINITY NF4X Motherboard
Pls i dont know my setup password so i cant enter the bios setup and the person that asembled the computer is no where to be found pls how can i get the password.
Remove the onboard Battery, the one like the coin chaped battery on the motherbaord. then place it back & your bios will be reset.
Feb 02, 2009 | EliteGroup 661GX-M Motherboard
Intel d945gnt
Yesterday night i resove the problem with the intel by many e-mail.
For all guys that have the same problem , the solution is:
1- put the jumper in position pin 2 and 3.
2- turn on the PC with jumper in the same position ( pin 2 and 3)
3- the bios start in "recovery mode"
4- deselect the memory "aggressive mode"
5- save bios setting, then power off the PC
6- set bios jumper in position 1 and 2
coolhandan thx for attention and please insert this solution in intel D945GNT archive for future customers that fall in same problem. Sorry for my bad English ;) THX at all
Nov 18, 2008 | Intel D945GNT Motherboard
Reseting...
The reset jumper for an ECS P965T-A (V1.0) is J1 color red tag as "Clear CMOS Jumper" located near the Lithium memory battery. To reset, simply move the jumper temporarily to the opposite end/pair and revert back to original position soon as finished. pls refer to below image.
Alternately, removing the memory battery for a couple of minutes also reset the CMOS/BIOS configurations.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 31, 2008 | EliteGroup P965T-A Motherboard
Password
that is because the password in question that you are trying to get past is the BIOS password most likely. Verify that your computer is turned off, remove power cord from back of computer, and find the jumper near the Bios chip on the motherboard. It will usually be close to the battery ( another option, temporarily remove the battery for about 30 seconds, then replace the battery into its proper position ). Be careful when you do this as some battery sockets are a pain to work with. Anyway in nearly all cases, the Bios reset jumper is located very close to both the battery and the bios chip ( firmware ). Removing the Bios reset jumper and positioning it one pin over from the initial position will usually reset the bios and get rid of the bios password requirement. Always put the bios reset jumper back into its initial position before re-appying power to the motherboard. Be careful not to leave anything loose lying around on the motherboard or in the case, else you might fry the motherboard..
Once you have successfully managed to get past the Bios password, then you should see the computer start to boot up normally and prior to Windows boot up and in the Bios routine you can configure the computer to boot to CD first. In many more modern situations, the motherboard is already configured that way.
Feb 23, 2008 | Computers & Internet
Computers & Internet Logo
339 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
