Question about Panasonic Viera TH-50PZ85U Plasma TV
Have a th-50pz850u. If you turn off and then try
Have a th-50pz850u. If you turn off and then try and turn on it won't and the led blinks 10 times
Plasma Panasonic TV stopped working
Lightning-damaged electronics are a gamble to repair. Sometimes the problem is a single component, but more often multiple components are damaged, and even if you get it working, something else may die shortly thereafter. If you are lucky, only one board was damaged. My recommendation, if you have homeowner's or renter's insurance, is to put in a claim for the TV and get it replaced.
Having put forth that caveat, the blinking red LED hints that you may have enough left of the set for it to be repairable, especially given that much of a plasma set is already built to cope with high voltages. Try downloading a service manual and following the troubleshooting procedure. Here's the link (it's a Hungarian site, but there's enough English available to find things):
Service manual eprom result list ElektroTanya Service manuals and repair...
Jun 26, 2015 | Panasonic TH-50PZ850U TV
Plasma Panasonic
Replace the Power supply board very common issue with that chassis.
Oct 22, 2012 | Televison & Video
PANASONIC TH-50PX75U PLASMA TV LED LIGHT BLINKING 10 TIMES
That is a power suuply problem,i have the same problem i looking for a solution to fix my or i gonna buy a new one,also new onw is spensive on ebay some people offer the repair service good look
Sep 03, 2012 | Panasonic TH-50PX75U Plasma HDTV
Panasonic viera th-50pz800u won't turn on. Red power light blinks 10 times.
thats a sos error for numerous supply voltages missing. Send a email to me for assistance as I cant post the info here slinteriors@yahoo.com
Apr 01, 2012 | Panasonic Viera TH-50PZ800U Plasma TV
I have a Panasonic model TH-42PZ80U Plasma Tv the red light keeps blinking 10 times and it won't turn on?help
hi,
In your tv there some problem with power supply. you have to check the followin voltages. Sub 5v SOS ,Main 3.3v SOS A-Board,DTV 9v SOS , Tuner Power SOS. If any one of the voltage fails it will shows 10 blinks.
ok
Jul 18, 2011 | Panasonic Viera TH-42PX80U Plasma TV
Panasonic model th42pz77u no pic, no sound, blinking red light ten times
9.2. Power LED Blinking timing chart
1. Subject
Information of LED Flashing timing chart.
2. Contents
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the
defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
26
TH-42PZ77U:
There are different patterns for blinking light...
10 times indicate DG board problem - SUB 5V SOS, MAIN 3.3V SOS, DTV 9V SOS and Tuner Power SOS.
Aug 16, 2010 | Panasonic TH-42PZ77U TV
Panasonic plasma 50PZ85 power led blink 10 times
Either a bad power supply or a bad processor board.
A Good Service Shop should know what the 10 blinks are indicating.
May be a repair cost between $200 and 400 dollars.
Be prepared -
Blessings,
A/V Media Guy
Nov 22, 2009 | Panasonic Viera TH-50PZ85U Plasma TV
TH-42PX60U red light blinks 10 times wont come on
On a Panasonic TV the 10-blink error code can sometimes be caused by low voltage running through an HDMI cable, particularly from a Media PC or some video game consoles. Try disconnecting any HDMI cables and unplugging the Television for 30 seconds, then power it on without the cables attached.
If this works, connect the cables to the front panel (usually HDMI-3) which uses a different controller board.
Dec 08, 2008 | Panasonic TH-42PX60U Television
Panasonic Viera TH-50PZ85U Plasma TV Logo
458 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
