Question about Extron Electronics Switching and Transmission System (tps150-1)
I have a 94 honda civic the transmission only works when the car is cold once it heats up it wont move at all do i need to replace the transmission or could it be a sensor? help!!!
  • 67 Answers
Honda dont have filter to change,to do it you must to open the trany,there is not oil pan ok,if the filter is cloged it dont work any way coold or hot,so there is a seal leaking inside or selenoid fault when its hot,you better go to a trany shop for and electrical or pressure tes at transmission ports ok, GL
Posted on Nov 23, 2009
  • 784 Answers
It is Torque converter clutch (TCC) solenoid locked up causing this problem. This is common in Honda Civic. To fix it, 1-It could be anything from a simple fluid and filter change (to get debris out of the fluid that might be clogging the solenoid up), 2-It could be an electrical problem (such as the solenoid, or wiring) . 3- It could be the torque converter itself has failed 4- Most the time it needs a rebuilt transmission.
However, try the most economic solution first then go to the next on according to the listed number. Good luck.
Posted on Sep 12, 2009
  • 125 Answers
This is a lot more than just a sensor, unfortunately. I recommend bringing it to your transmission shop, because most of them offer a free diagnosis and one really needs to look at it to check the clutch, etc. You might be low on transmission fluid if you have never added any, so you should check that. Low fluid causes slipping and eventually nothing works. If that's the problem, you could get out of the problem cheaply.
    Brigadier General:
  • 4,044 Answers
It could be a faulty solenoid in the transmission or a weak seal. You need to have the transmission serviced at a transmission shop.
My honda civic LX 97 start to over heating when I start to run a High speed
For car running hot and overheating issues,i suggest to you go through this help links. Click this link below and go through the troubleshooting procedure to take care of the problems :----Car runs hot? http://howtobyme.blogspot.com/2011/11/car-runs-hot-in-traffic.html
-----------All types of car overheating problems and troubleshooting?
http://technoanswers.blogspot.com/2011/11/all-types-of-car-overheating-problems.html
Car freeze overnight and started overheating while driving?http://technoanswers.blogspot.com/2012/01/car-freeze-overnight-and-started.html-----------Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
--------overheating? http://schematicsdiagram.blogspot.com/2011/12/buick-century-overheating.html
----------Car engine Overheats and transmission starts slipping?http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
----------This details will help.Thanks.
Feb 13, 2012 | 1997 Honda Civic
1996 Honda civic transmission wont shift when engine is hot
I thave the same problem with my civic ek 96 model the tranny work fine when its cold but when it get warm and i put it in P or N and D4 again it will stock in 1st gear I have to wait 3 to 4 hours to get cool and it work fine again. Hope somebody can help me. Thanks Eli
Jan 18, 2012 | 1996 Honda Civic
My shifter wont shift from park to drive brake lights work 94 civic
You may have a bad switch (Ford calls it a brake shift interlock not sure the exact term Honda uses) but check all your fuses. Below I gave you a picture and instructions on how to bypass the interlock switch until you can get the repair done or replace the bad fuse. I hope this helps and good luck.
Jun 26, 2011 | Honda Civic Cars & Trucks
94 del sol auto transmission problem, drives fine at first then trany goes completly, all at once, shutt it off for 20secs restart works fine for another 30 secs, ecu? selenoid?
Sounds like a plugged filter. But it is internal. You have to remove the transmission and disassemble it to replace the filter.
Jun 19, 2010 | 1994 Honda Civic Del Sol
My car wont move forward or reverse
Chances are is that the torque converter needs to be replaced. However, the transmssion on this vehicle are only serviceable by transmision shops. No regular mechanic will open up the transmission. When the torque converter fails (clutch and plates shutters to small pieces) the debri flows in the transmision thereby potentially destroying the gears and/or clogging the filter and pump. Go straight to a reputable transmission shop and let them correctly diagnose the transmission.
Nov 22, 2009 | 2002 Honda Civic
94 Honda Civic DX idles low/rough at a stop
Check for split hose's around the inlet manifold.Sounds like a vacuum leak.
Hope this helps.
Jun 28, 2009 | 1994 Honda Civic
Heater Control for 93/94 Honda Civic
Glad you found your problem
Jan 19, 2009 | 1994 Honda Civic
1994 honda civic LX Auto transmission problem
It sounds as if your transmission has failed. look for a good transmission tech in your area and get it priced up
Dec 19, 2008 | 1994 Honda Civic
1994 Honda Civic - Over heating
You most likely need to replace the Thermostat, but also verify the engine cooling fan is working, it should come on when the AC is turned on.
Oct 07, 2008 | 2002 Oldsmobile Alero
Open Questions:
Computers & Internet Logo
518 people viewed this question
Top Extron Electronics Computers & Internet Experts
David Payne
David Payne
Are you an Extron Electronics Computer and Internet Expert? Answer questions, earn points and help others
