Question about Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune front loading washing machine, in last 5 minutes of cycle, would make a lot of noise and just now, while doing a small load of towels, the washer had stopped, before it was finished, with an FP code and there was water in the tub. It will not restart. What should I do?
    President:
  • 497 Answers
Http://www.applianceaid.com/neptune8.html
Sounds like a power failure, which needs a service tech out to fix.
Posted on Sep 12, 2009
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune front loading washer
What is the model # of your machine???? The loud banging noise sounds like the loads were getting unbalanced. This is the most likely since i have no problems with the suspension all of a sudden not stabilizing tub properly. If the washer was moved or transported than that would make more sense to me. please provide as much info as you can. Try doing a load of 10 towels. Let me know how that does and with the model # i can help with pulling some diagnostic codes
Oct 02, 2007 | Maytag MAH6500 Neptune Front Loading...
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Aug 20, 2011 | Washing Machines
    EVERYTHING WORKS FINE UNTILL IT GET TOWARDS THE END OF SPIN CYCLE THEN IT STARTS VIBRATING AND WALKING ACROSS THE FLOOR PLEASE HELP ? WE HAVE ALWAYS HAD THIS PROBLEM EVEN AFTER LOWES INSTALLED THE WASHER...
    First, make sure the 4 shipping bolts have been removed, and that the machine is level front to back and left to right BOTH! Some machines prefer to be high in the front. VERY IMPORTANT Must have a minimum of clothes & towels, sheets or blankets to wash. DON"T wash 2-5 item loads (small loads)
    run machine at least 2/3 full of dry clothes. These machines are built to wash more per load, also because of the many technical parts of the machine, sensors and relays, the machine decides how much water to use not the user! Some "Old Schoolers" have a real issue with the lack of water and unclean clothing... most complaints are user error. Enjoy the new front loading technologies! Cheers! Happy Washing.
    Oct 16, 2010 | Maytag MAH8700AWM Neptune Front Load...
    Face Clothes and Towels are smelling bad after being washed and dried in my Kenmore HE3 washer and dryer. Have tried running an empty cycle with bleach only, washed small loads with hot water, pre-wash and...
    Try running an empty heavy duty wash cycle with a pint of vinegar added to the water, run wash cycle for two or three minutes then turn the machine off for thirty minutes then restart and let finish the full wash cycle
    Aug 02, 2009 | Maytag EPIC MFW9700S Front Load Washer
    I have sitting water in bottom of outer ring after wash cycle.
    The Neptune will typically have a bit of water in the front seal area after the cycle.
    Take a towel and wipe the area clean and dry after heavy loads. There is a drain in the bottom. Wiping this area will help keep the drains clearer and help prevent ordors too.
    Jul 11, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Maytag front loader washing machine. Mould
    How old is the washer? Did you try straight bleach on a towel and placed over the "mold" spot for about 5 minutes, be sure to wear gloves. Then scrub with a small brush being careful not to splatter bleach on yourself and rinse well. May need to replace the seal. I always leave the door cracked open after every use to "dry" out the inside and the boot. I also leave the drawer pulled out when not in use for that area to dry out as well. I have never had mold on the door seal of my Neptune washers, only the water holes above the dispenser drawer.
    Sep 08, 2008 | Maytag MAH6700AWW Neptune Front-Load...
    Nd error essage
    nd= no drain. loud buzzing noise sounds like something stuck in pump assy.remove the door(2screws) adn other 2 screws oppisite side, and hte front panel comes off giving you acess to the drain pump, pull the hoses and look for the obstruction
    Mar 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
    Maytag front load washing machine Model MAH5500B misses spin cycle
    either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
    Nov 01, 2007 | Maytag Neptune MAH5500B Front Load Washer
    Maytag Neptune MAH5500B Front Load Washer Logo
    124 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
