Question about Refrigerators
Freezer and refrigerator kinda of working. Lights on fan on but not cold. Set both settings to 7 and not cold or frozen. But it is cool inside. Whirlpool Gold gd5rhaznb00
  • 525 Answers
Move your refrigerator 1 foot awy from the wall . Enjoy technical secret?
Posted on Sep 12, 2009
Gsc3pgxcfss warm fridge, freezer working fine, lights off in fridge
James, not sure I understand your message when you say both lights go off, but later say lights begin working. Do you mean they go off when you push the buttons at the door? And when you say no cold air comes from the freezer, is the freezer door closed? See if air begins flowing with freezer door open. If so it would indicate the return air path from the refrigerator to freezer is blocked.....damper staying closed or evaporator coil frozen up. The return air path has to be open to allow the freezer to keep sending out cold air to refrigerator when freezer door is closed. You might thoroughly defrost to make sure coil is not frozen.
If the door button for the refrigerator light is bad it can signal that the door is open all the time, so the freezer will never send cold air to the refrigerator. And that will be good news. Door switches are cheap. If you don't have a volt meter and know how to check switch, just remove the door switch from the refrigerator, leaving wires dangling, and close the door with a thermometer inside to see if it begins cooling (or just wait a while) I had that problem a year ago and was happy to find a bad door switch. More often it's a frozen coil, and that can be more expensive to fix. Sometimes you can discover a bad switch by pushing in the door button and the light stays on, but it doesn't sound like your situation.....sounds more like a frozen coil. If so, maybe all this extra information will help someone else.
Mar 23, 2014 | GE Profile PSW26P Stainless Steel Side by...
Freezer is to cold and refrigerator not cold enough. When you open freeze it is always running
Sounds like the fan that cools the lower refrigerator is inoperative or it's fan blades frozen up.
Try defrosting. You will have to remove everything and remove the access panel to the fan to ensure it's fan blades are free and not frozen up. They have a built in inherent safety feature and sometimes they will work properly again when thawed out. More than likely the small fan motor burned out and will need to be replaced. There are appliance parts stores every were or call the mfgr parts department.
Once replaced your can restore your freezer setting to where it belongs. There is a dial that raises and lowers this setting.
The small fan draws air from the freezer and cools the refridgerator. It is also on a thermostat and usually has a dial to set the way it cycles and determines the temperature.
Cheers,
TF
Jun 02, 2011 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Refrigerator section not cooling
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 20, 2010 | LG LFC22740 Bottom Freezer French Door...
Freezer works fine, fridge don't
your inside fan has stopped working.  Could be stuck or frozen or simply bad.
Mar 13, 2009 | Amana BC21V1W Bottom Freezer Refrigerator
The food side not geting cold I set up the control nothing
the small cooling fan in the freezer compartment that sends chilled air to the food side is defective and needs replacement.  Sometimes that are only frozen stuck.
Mar 06, 2009 | Amana AFD2535DES French Door Refrigerator
Refrigerator not cooling--has thawed/ but top freezer is cooling
Their is a fan that blows the cold air from the freezer to the refrigerator section, on some models. If thsi fan is  frozen or bad what you havwe discribed wil bew the result.
Nov 26, 2008 | Whirlpool Refrigerators
My GE GSS22SGMBBSCC side by side refrigerator does not cool the upper freezer portion
Most newer GE fridges have dc fan motors controlled by a computer board. Sometimes the board just fails and sometimes the fan can cause the board to fail.
Jun 30, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
My refrigerator does not cool properly. The freezer does not have ice built up and the fan is working, I can here it blowing when i open the freezer. The freezer almost works too well, it is at its lowest...
The lowest setting in the freezer compartment may be set to cold holding back cooling to the refrigerator. Try your settings at mid-point on both refrigerator and freezer settings.
Dec 05, 2007 | Kenmore 73503 Stainless Steel Bottom...
Kenmore 73503 not cold enough
Is the fan in the freezer working?? Is there Ice on the rear panel in the freezer?
Dec 04, 2007 | Kenmore 73503 Stainless Steel Bottom...
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
