Question about Apple MacBook Air
My voice does not work at all.
I had this problem since the 2nd month when I purchased it.  I had no other problems with the air, except that I have no sound.  it's a hassle now I want to use the internet voice chat.
  • 55 Answers
Get laptop speakers
Posted on Sep 14, 2009
Split ac noise
yes you need to take of the plastic cover and loosen of the grub screws on your blower wheels and slide them along the shafts wile turning them till you hear they are free they are just touching the fan housing
Dec 08, 2013 | Heating & Cooling
I need to wire 3 woofers but 2 are dual voice coil and one is single voice coil
sure, if you wish to wire them all together, wire the first dual voice coil subs first voice coil negative to 2nd voice coil positive, second voice coil negative to single voice coil sub positive, and single voice coil negative to 2nd dual voice coil subs 1st voice coil positve (again with the second dual voice coil sub, run the first voice coil negative to the 2nd voice coil positve) your speaker leads will be attatched to first dual voice coils 1st voice coil positive, and 2nd dual voice coils 2nd voice coil negative)
Apr 01, 2013 | Kenwood KAC-8104D - 1000 Watts Class D...
How to leave a voicemial message
There are three elements to voice mail; having a Panasonic brand voice mail system, recording the greetings, and setting call forward conditions. Which ones have you done?
The default access to voice mail is extension 500 on the intercom, but we used to use 165. When you dial it, the lady says "welcome to the Panasonic voice processing system". If she doesn't or you're asked for a password, or you have not done the tutorial, then you need to do that and it guides you to the setup of the greetings, name, and password change. After that, you dial *710x 500 (or your VM access) # on the inercom to set call forward to voice mail, with 4 being no answer (my preference since it gives me the option of answering the 2nd call or letting it fall to voice mail), or 5 for Busy/No Answer.
The message manager (mailbox 998) and the system owner (mailbox 999) has the ability to access and change how the voice mail system performs. The owner can change your name for the directory or reset your password and/or
setup or delete your mailbox.
Carl
Aug 09, 2012 | Panasonic KX-T7630 Corded Phone
1996 old delta 88 ls fuel pumps burn up
Filter or pickup is probably clogged.
May 31, 2012 | Oldsmobile 88 Cars & Trucks
Gateway nv5 mouse pad frozen in the middle of screen.
Return the laptop to the place of purchase, the sensor pad has failed, or device driver issue.
Apr 16, 2012 | Gateway NV5384u Laptop
I have two liftmaster's model 2500 one will not
I have the very same problem. I have 2 Liftmaster 2500, 1/2HP openers installed in a 2 car garage. They are merely 15 feet apart in my garage ceiling. About 15months ago one stopped working by only the remotes. Went through the process of reprogramming the good one 1st and replaced batteries in the remotes, then trying to reprogram the one not working. Checked for radio interference near the one not working no LED or Halogen Lights, no wall tarnsformers, no cell phone interference etc... Nothing worked to on the 2nd
opener in trying to get the remotes working again.
I then purchased a New Logic Board, part number 41A5507-B. It was about $70 and then installed it in the 2nd opener which is not working. Tried to get the remotes programed - still nothing? I was baffled. I called Liftmaster - the only suggestion they gave me was was to totally unplug the GOOD opener and try the reprogramming up close to the 2nd door opener that's not been working. SURE enough - the Opener Remotes "Learned" okay and started working! Liftmaster Help line indicated that the thought to be GOOD opener actual had the defective Logic board and it was over powering the signal from the 2nd opener which was not working. I'll be taking the New Logic board and replacing it in the 1st opener.
Thank you Liftmaster for the help !
Jan 17, 2010 | liftmaster Chamberlain Garage Door Opener...
Sudden loss of voice/sound on TomTom 720
This is a warranty cloaim and is not unknown for TomTom GPS. You might want to consider changing it for a more reliable brand
Jul 24, 2009 | Tomtom GO 720 GPS
One radio makes loud tone when other radio transmits
You may have a defective radio that has a bad push to talk switch which doesn't mute the receiver and feeds back audio to itself or this could be a bad solder connection or a broken wire inside.
Not much you can do except replace it or have a tech look at it.
May 11, 2009 | GE SmartHome (58173) 2-Way Radio
Recherche pilote pour vn-4100pc pour vista premium
Purchased an Olympus VN-4100PV digital voice recorder a couple of months ago at Radioshack. (no software came with it)
Recently purchased new PC with Vista 64-bit. Recorder will not work. Called Olympus today, 12-3-08 and was told no driver is going to be issued to remedy this situation, thus rendering my device useless.
Thanks for nothing Olympus product support.
Nov 18, 2008 | Olympus VN-4100PC Digital Voice Recorder
2nd voice coil blown
Have you called crutchfield yet? The are pretty good with customer service and stand behind their company. If they protest, get loud, they will likely bend. I have dealt w/them for years.
Dec 20, 2007 | Car Audio & Video
Apple MacBook Air Logo
79 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
