Question about Sony FD Trinitron WEGA KV-32HS420 32" TV
Sony KV-32HS420 won't come on.
MY Sony KV-32HS420 stand by timer blinks 7 times then pauses, and the TV won't come on for several days, and when we finally get it to come on then the timer blinks 5 times. I found out what the 7 blinks means (horizontal deflection stopped--- at least one IC on D board needs to be replaced). What does the 5 blink mean when it's on. I'm afraid to turn it of because it'll be a while before it comes on again. If it even does. I think this is a fairly common problem for this model.
    Top Expert:
  • Sony Master
  • 74,482 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Jun 15, 2017
  • 556 Answers
SOURCE: missing vertical deflection on philips TV
TDA 8362B IC which have vertical freq.output is at pin no.43. (vert.osc) caution for fixing this problem minimise brightness to avoid crt burn. proceed as follows 1 if you are getting sawtooth at output of ic tda 8362 pin 43 then check 1 supply at vertical output ic from eht. 2 yoke connector loose . 3 check vertical output ic parts. 4 finally vertical ic. please check for normal output from power supply even though fault gets rectified just for protection. good luck.
Posted on Sep 23, 2007
Vrya
  • 62 Answers
SOURCE: Kv-36xbr800
Hiii...
My version is :
For safety reason you should replaced them ( Horizontal ic,Vertical ic, Deflection ic) and olso all the big capasitor nearest the ic....that's my version....if you have big budget for it....he..he....
Thank's
[Vrya]
Posted on Feb 19, 2008
  • 280 Answers
SOURCE: KV 32HS420 SONY WEGA TRINITRON
Shorted diod D503 next to HOT on main board
Posted on Apr 18, 2008
  • 668 Answers
SOURCE: 6 horizontal lines
I would look for a Vertical circuit failure. Most likely is the vertical output IC and or open resistor off the hv transformer. Definitely look for any loose solder connections around the Vertical output IC.
Hope this helps,
Skyassoc
Posted on Jun 17, 2009
  • 7 Answers
SOURCE: My Sony KV-32HS420 Trinitron Wega TV will turn on
You have what is commonly known as a shutdown problem. It's an overload in one of the internal circuits. It needs to be looked at by a professional tv reapir person.
Posted on Nov 03, 2009
Stand by timer sony triniton color tv Model kv-32hs420
How many times the standby button blinks before going OFF at one time switch ON?
Apr 17, 2012 | Sony FD Trinitron WEGA KV-32HS420 32" TV
My Sony KV-32HS420 won't turn on -- blinks 7 times, pauses, blinks 7 times. I've seen the same problem described on this site, and the answer seems to be that 2 ICs on the DZ board need to be replaced. I'm...
The 7 blinks on this model indicates that the horizontal section of the TV has stopped working. Horizontal Deflection Stopped
Occurs when either:
1) a +B overcurrent is detected (IC5007), or
2) overheating is detected (Thermistor TH5002).
I have the serrvice manual if you need it. Let me know where to send it to.
Dec 16, 2010 | Sony FD Trinitron WEGA KV-32HS420 32" TV
Have Sony KV-34HS420 with no picture or sound. Timer/Stand By light flashes 7 times with pause in between. What is the likely problem and cost to repair?
Hold hair dryer to back right side on high heat for a couple of seconds while you hit the power button several times. It only took 2 times for my set to power on. Good Luck!
Aug 12, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
My sony wega 32hs420 timer light is blinking 7 times stops then blinks 7 times and so on. do i need a repair man to come look at it?
Yes,this problems must have parts change.Repair and parts should be under $250 more than that not worth it to repair old CRT tube tv.High Voltage parts are dead must get it replaced.
Jan 23, 2010 | Sony FD Trinitron WEGA KV-32HS420 32" TV
My Sony KV-32HS420 Trinitron Wega TV will turn on but then shuts off again after 5 seconds, never showing a picture. The "Stand By/Timer" red light on front blinks 7 times, pauses, and then repeats. I've...
Nov 03, 2009 | Sony FD Trinitron WEGA KV-32HS420 32" TV
Tube does not turn on
If TV model is Sony KV-32HS420 then mostly it requires to replace 2 ICs on DZ board, let me know if you can replace ICs on circuit board and know about TV repair to provide you more technical info.
Thanks.
Sep 16, 2009 | Sony FD Trinitron WEGA KV-32HS420 32" TV
Apr 15, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
SONY WEGA KV-32XL90E
Hiii...
what chassis your tv set ?
Thank's
[Vrya]
Jan 23, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony FD Trinitron WEGA KV-32HS420 32" TV Logo
247 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
