Question about Cycling
WHERE CAN I OBTAIN INSTRUCTIONS FOR THE SHIMANO ACERA X DERAILLEUR OPERATION?
  • 484 Answers
Here is the Shimano .pdf page. Not sure which derailleur you wanted, so you can pick.
Posted on Sep 13, 2009
How do you adjust a shimano xtr m9000 front derailleur from 3 speed operation to 2 speed operation as there is no selecter switch
You have to do it at the front derailleur. You adjust either the inner or outer limit screw so that the derailleur can only go to two of the chainwheels. Front Derailleur Adjustment
Feb 24, 2017 | Shimano Cycling
I have an electric RMartin R10H, and replaced the 9c motor hub. But, the derailed is no longer aligned. Cog needs to be moved outward by 3/8 inch or so. Is such an extender available?
Are adjustment screws all the way out? If so, frame won't accommodate this cog. ITs too wide. Sometimes a frame spreader will correct. This repair is difficult to do, contact local bike shop for assistance
Oct 05, 2014 | Shimano RD-M 310 DL Alivio/Acera/Altus...
Fitting instructions needed for Shimano Rd-Ty18-6-Gsd Bike Rear Derailleur with Bracket
The semi-circular spacer is what holds the derailleur in the dropout. Take the part that looks like a "C" and line it up on the drop out, the spacer goes on the other side of the dropout. There should be a screw that fastens to the spacer and clamps the derailleur to the drop out.
Apr 14, 2014 | Shimano Rd-Ty18-6-Gsd Bike Rear Derailleur...
I've disassembled my acera rear derailleur and have forgotten which cog/sprocket goes where. One of them has an offset. What are the symptoms if I have them interchanged? TThanks Allan L
Generally there is no much difference, but as I remember in acera they have different sizes: the bigger one goes to the bottom (down), smaller one goes up.
As for offset you'll just have to readjust your rear derailleur. (If you disassembled it you'll have to readjust it anyway so no big deal)
Apr 10, 2011 | Shimano Cycling
When I go into high gear the chain continues to ride-up and derail to the spokes. Do I need to tighten the cable or adjust the screw adjustment, which I have no idea which way to screw.
The problem is with the rear derailleur limiting screw. This is what limits the travel of your chain and keeps it from overshifting into the wheel. This fix is a bit complex so I would recommend you take into your local bike shop. They can probably fix it on the spot and if you have a good relationship with them they won't charge you too much.
May 20, 2010 | Shimano Acera Mountain Bike 87 Speed Rear...
1 have a mid 90's bike with a Shimano Acera X that will not shift
My solution on the same shifters was to lube the grippers on the levers, they did not engage but after moving them around and lubing they started to grip and problem fixed.
Apr 25, 2010 | Cycling
Adjust Shimano Acera back derailleur
There is a limit screw on the body of the derailleur that you have to back out slightly. You can tell which one of the two it is by watching carefully as you adjust it. It takes a phillips screwdriver.
Aug 01, 2009 | Cycling
Cycling Logo
346 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
