Smoke from washing machine
We had smoke from the washing machine at the end of the rinse cycle. I have not identified the source of the smoke. Any suggestions as to where to look first.
  • jpb7428 Dec 11, 2007
    I don't know the model, but it says "heavy duty - super capacity plus 2" on the front. It is a Whirlpool, roughly 10 years old.
    I'll try it. Thank you!
    Sergeant:
    Champion:
  • 262 Answers
CHANCES ARE ITS THE MOTOR START MACHINE RUN IT IF POSSIBLE FOR A FEW MINUTES TILT MACHINE BACK AND FEEL THE MOTOR IF IT IS HOT YOU NEED TO REPLACE IT (THE MOTOR)
Posted on Dec 11, 2007
Washer fills on wash won't fill on rinse. Does on old washer and new washer. Checked and plumber said not the plumbing. Help PLEASE
It seems that you are out of cycle; meaning you are washing on rinse phase and the you are not getting water on rinse because you are at the end of the cycle. Try this; set the washer to the end of the rinse cycle, let it spin and stop. then wait 1/2 hour then start a wash you will be at the beginning of a new wash cycle..
Nov 10, 2016 | Washing Machines
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
Gets stock in rinse cycle
Rinse cycles are usually with cold water. If it cant fill with cold water, it wont go through the rinse cycle. Make sure it fills with cold on a normal wash. You may find its filling with hot only. Alternatively, the machine may not be pumping out properly, this will cause a similar fault. Check to see the machine is draining at the end of the wash. check the pump and the filters for blockages or lint etc clogging the hoses or pump.
Feb 18, 2015 | Washing Machines
Fisher and Paykel MW 512 stopping at rinse cycle
you have a faulty pump do not use until you replace it
Dec 30, 2012 | Fisher and Paykel Washing Machines
Ge front loading washer drum fills with smoke at end of last rinse cycle and smells of burning rubber
THE INNER DRUM IS BAD WITCH LETS IT RUB THE FRONT SEAL OF THE WASHER YOU NEED TO SEE IF YOU CAN MOVE THE DRUM UP ARE DOWN ARE SIDE TO SIDE IF SO ONE OF THE SUPPORTS ON THE BACK BROKE AND THE GET THE SMELL OUT WASH THEM IN WHITE VINAGER
Oct 31, 2012 | Kenmore Front-Load Washing Machine 3.5...
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Hi, The washing machine does the wash bit of the cycle, but on the rinse it just keeps filling with water and the water goes out of the waste pipe. Can you suggest what the probelm is please
Yes it is not measuring the water level or the valve is stuck. If it fills ok on the wash but not the rinse it must be one of the inlet valves. Identify which valve is for the rinse and check if it stuck open. If it is repalce it. The valves are at the end of the fill hoses. Hoe you have success. Thanks Tony
Sep 05, 2010 | Washing Machines
Nec nw-891 washing machine will not complete the programmed cycle
Apparent malfunction in the timer circuits. Specific Component replacement not available.
Jun 30, 2009 | Washing Machines
4E code keeps apearing
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 29, 2009 | Washing Machines
Washing Machines Logo
751 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
