Question about Vacuums
I have a hoover elite 200 it did not have a belt on it when i got it and i cant find the drive shaft.
  • 430 Answers
You must remove the lid of the vac and find the pulley end of the brush. directly behind it one hand length you will see a small silver shaft. If the shaft is other than silver it is coated with burned rubber. or rust and dirt.
Clean off the burned rubber polishing the shaft with wet dry sandpaper . Then rotate by hand to test for any blockage in the motor fan. Also rotate the brush roll to see that it spins freely. Using a genuine hoover ELITE belt wrap the belt around the motor shaft and brush roll and use the brush to stretch the belt forward as you lower the brush into place. Once seated , rotate the brush again to see that the belt is turning, then reinstall the lid. Do not pick up anything larger than your fingernail or you will blow the fan on this unit.
Posted on Sep 12, 2009
I have a Upright Hoover Elite. Can't get belt back on right.
The belt loops over the motor shaft and the brush roller. Verify that the arrows on the end caps of the brush roller are facing DOWN or you will be doing the job over again. Start with the motor shaft and stretch the belt to allow the brush roller to seat. A new belt can require a strong pull on the brush roller to get it seated.
Nov 16, 2016 | Hoover Vacuums
What is the belt part no. for a hoover elite rewind?? model no. UH71009RM
If you look up the Hoover page for the UH71009 (the non-remanufactured Elite Rewind), there are 3 different belt model numbers listed. One part number is simply for a 2 pack of the belts. See http://hoover.com/products/details/uh71009/elite-rewind-bagless-upright/ . Click on the Parts & Accessories tab.
I believe the belt part number is 38528058 , http://hoover.com/parts/details/38528058/sra-r-b-562932001-belt/ .
I hope this helps.
Oct 04, 2015 | Hoover Vacuums
Belt wont stay on
The belt is bad. Been sitting too long. Replace the belt it will work fine. Explanation why is here:
http://www.vacuummedic.com/blog/2012/10/09/my-brand-new-vacuum-doesnt-work/
Sep 09, 2012 | Hoover Vacuums
How to replace hoover 73288 drive belt
get a new belt put it over the motor shaft put the belt over the drive shaft and turn it and it will go on
May 30, 2011 | Hoover Vacuums
I need to know how to install the belt on a hoover elite upright, #38528027
There are two snaps underneath to release the bottom plate. Next remove the top cover by gently prying off the base with a flat screwdriver. this will expose the belt. Install the new belt on the roller nd then push through the hole to attach to the motor shaft. reinstall the cover and bottom plate.
Jan 14, 2010 | Hoover Elite U5061-900 Bagged Upright...
Hoover elite how do i put the belt on
Here is the belt you need: Hoover U5061900 Belt
Simply turn the machine over and you will see (4) screws, remove them and you will be able to access of the belt.
Dec 14, 2009 | Hoover Elite U5061-900 Bagged Upright...
How do I change the belt on my Hoover Elite Dual Purpose Vacuum cleaner? The belt part # is 38528-027. Where is the motor pulley?
The hoover belt number you listed (38528027) has been changed by Hoover to 38528040. Below I have listed a link to the manual that has instructions and a link to the belt you need. Hope this helps!
Hoover Elite Manual
Hoover Elite Replacement Belts
Nov 02, 2009 | Hoover Elite U5061-900 Bagged Upright...
Hoover elite, model no. u4671-930
in the front on the bottom you will see 2 slots put a small screwdriver in and push up on the clips in the slots and the bottom cover will come off .be careful not to break the clips.just push up on the clip and pull out on the cover at the same time.before you replace the belt clean the old rubber off the motor shaft first ,if you don't the new belt won't last very long
Apr 29, 2009 | Hoover Elite U5061-900 Bagged Upright...
Change belt on a hoover elite, model no. u4671-930
Every Hoover I've had has two screws on the bottom that you remove.  Then you lift off the cover and you pry out the brush roller. The new belt goes with one end on the motor shaft and the other end on the humped roller part on the brush roller.  Good luck it's a bit of a struggle but you can do it.
When you receive advice from this website you have to understand that without the item in front of us, we are only able to provide "a best guess" as to what the problem might be based on you description of the defect.  If you haven't described a clear and precise description of the defect you decrease the chances of an accurate reply.  Thank you.
Hoover upright vacuum information
cant help with manual but if i may why would u take it apart theres not much to service but to take the belt off turn the machine over and down by the roller there are a few screws take them out the cover should come off and thats it
Sep 26, 2007 | Hoover Elite U5061-900 Bagged Upright...
Vacuums Logo
239 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
