Question about Husqvarna Forest & Garden #952802239 235E 16" Gas Chain Saw
Timing is off
I have a husqvarna 235 E series chainsaw. The nut came off of the fly wheel and it lost its timing. At what point does the piston and magneto time right?
  • 5,603 Answers
There should ba a keyway that aligns it. You MAY have sheared the key. This is a common problem.
Posted on Sep 12, 2009
I have a husqvarna 350 chainsaw that was running great and it just went dead and now it is popping back through the carb what is wrong with it and how do I fix the problem
If its back firing through the carb, It would point towards a timing issue, the engine is igniting the fuel/air mix before the full compression stroke, meaning that the cylinder port on the carb side isn't fully covered by the piston when ignition takes place. Check the ignition system, Plug, lead, ignition module and flywheel. The fly when has a moulded woodruff key in it, these can become worn or broken and cause the flywheel to turn out of position, advancing the timing of the spark.
Mar 03, 2016 | Husqvarna Garden
How to replace chain on a Husqvarna chainsaw 235 e-series
Hi:
Husqvarna has excellent "how to" videos.
Here's a link that should answer your question.
https://www.youtube.com/watch?v=dS0O8jahBF4
Cheers
Jan 28, 2016 | Husqvarna Garden
Husqvarna 235 chainsaw wont run
Check fuel supply, proper plug (resistor) compression 120 to 145 lbs. If saw will not run have the ignition tested with a 3-point spark tester.
Apr 30, 2014 | Husqvarna 232 235 240 Cylinder Pn...
3 month old Husqvarna 235. Refuled. Won't start. Plug is firing. Primer bulb gets full. Still won't start.
These machines have had issues with main bearing cages breaking up, this it turn scores the piston and snags the ring in, if there is a good spark and the plug is getting wet i woud whip the muffler off and take a look at the piston through the exhaust port.
Jun 14, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Not getting spark to the plug.On my Husqvarna 18 in. chain saw 235, e series.
Try a new condenser. They are very cheap and can freeze which shorts it out inside so the magneto energy is not absorbed and ready for when the points fire. It only has one wire and looks like a metal cylinder about 1/2" diameter.
Mar 29, 2011 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Wont start got spark and fuel husqvarna 235 model #9528021-55 serial # 2010 0700375
Is the saw mechanically sound? remove the muffler and check the condition of the piston through the exhaust port, any sign of damage or scuffinf and it will need to come apart for further investigation, they are very prone to the drive side main bearing breaking up and damaging the piston.
Mar 01, 2011 | Husqvarna Garden
How do you get the fly wheel off of a 1979 165cc
A model number would have been helpful.
I suggest a length of nylon rope (nothing left behind) be used as a piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises
Some pry them off (breaks cases, may damage points on yours), some smack the crank with a hammer (your crank), Some try holding the fly wheel and break cooling fins that effect balance. Professionals use a puller (call a local saw shop they might do it for a small compensation). HTH
Lou
Feb 17, 2010 | Husqvarna Chain Saw 20" Bar
Brushes EM235 HUSQVARNA
I think if you click the "Spare Parts List" box and type "235" in the search window you can find the part number for your points here:
http://www.mcculloch.biz/node1092.aspx
Use the parts list as a guide to aid with brush replacement. HTH
Lou
Jan 24, 2010 | Husqvarna Garden
Husqvarna 235 e series won't start
take the muffler off and look inside.....if you see scoring on the oiston then you need a new piston and cylinder,alot of new saw come from the factory adjusted too lean and it burns up the piston and cylinder.you need to call husqvarna if they are scored........should be under warranty........they will send you to a husqvarna dealer to repair the saw. hope this helps,let me know...............
Jun 09, 2009 | Garden
Ineed to remove flywheel from 365XP Husqvarna to split crank case
The thread is RH, loosen the nut un till its just flush with the top of the crank threads, use an soft metal drift, copper, allly, brass etc.
hold the fly wheel and strike the top of the nut with the drift it will pop the fly wheel off. you may need a hand. if it wont come off use a screw driver under the fly wheel and pry it up when you strike the nut..Dont hit the nut /shaft without the soft drift...you will destroy the shaft.
the clutch thread is LH..
Jan 15, 2009 | Husqvarna Chain Saw 20" Bar
Husqvarna Forest & Garden #952802239 235E 16" Gas Chain Saw Logo
231 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
