My washer fills extremely slow and I need to change the inlet valve. How do I get to this?
  • 4,070 Answers
It's on the back of the washer. The hoses which are connected to the water supply also connect to the water inlet valve on the other end of the hose. You'll probably have to remove a rear panel to access it where the hoses go in the back.
Posted on Sep 12, 2009
What is the sollution then to this FE error?
fe is a fill error is the washer filling ok or is it real slow to fill. if it is then u need to clean the inlet valve where the hoses hook up to the washer. take them off and you will see screens in the valve clean with old tooth brush and try filling again
Jun 16, 2014 | Washing Machines
Slow filling
Is your water valve fully opened?? Check the water shutoff valve and ensure that it is fully opened. IF it is, then do a simple test by disconnecting the hose from the washer, and get a large bucket, and turn on. If strong flow, then you may have some sort of clogged screen inside the washer (check inside the inlet connection).
Mar 21, 2014 | Amana 3.2 cu. ft. Top-Load Washer
Washer fills extremely slow. Hoses are fine water
Hi, check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve.
Jun 19, 2011 | Maytag PAV2300 Top Load Washer
Cold water filling of tub is extremely slow. No kinks
turn cold water off and remove hose from washer,next remove the screen from the water inlet and clean it and place it back in the valve, place hose back on the inlet,turn cold water back on and test cold setting,you should have good flow.
Dec 25, 2009 | Roper RTW4300SQ Top Load Washer
Cold water is not filling when water temp is set to cold. When set to warm the washer will only fill with hot water. Appears that the cold is not working at all. I took the cold hose off of the washer and...
check the inlet screens inside the water mixing/inlet valve on your machine, they may be extremely clogged causing your troubles.
if they are not clogged up you need to verify whether line voltage is making it to the inlet valve allowing it to open, if present the valve is bad.
if not determine if your temperature control switch is bad, but usually its a water valve or screen..
hope this helps,
best of luck,
ttfn
Oct 27, 2009 | Kenmore Washing Machines
Cold water fill is very slow and makes strange sound
check with the plumbing work if that is fine then better take it to the dealer to change the inlet valve. attempting to change by yourself can cause other complications.
Oct 04, 2009 | KitchenAid KHWS01PWH Global Horizontal...
Slow to take water
Slow fill problems are usually attributed to a clogged inlet valve. If you live in an area that has hard water, or if you use well water, it is common for the inlet valve to become clogged with rust or sediment over a period time. Follow these steps:
- First, you need to make sure the fill hoses are not kinked. Many home owners push the washing machine too far against the wall in an attempt to save space and unknowingly kink the inlet hoses. Leave about a foot of space between the washer and the wall to prevent this.
- Next make sure you are getting the proper water pressure through the fill hoses by removing them from the back of the washer and placing them inside the wash tub. Turn on the water back on and see if water comes through the hoses unobstructed and forceful.
- If you have good water pressure, and the hoses are not kinked or clogged, check the inlet screens on the back of the washer (this is where the fill hoses connect). Clean them (if necessary) with cotton swabs to remove any debris. You can attempt to remove the valve and flush it with distilled vinegar too. Vinegar is often used to remove hard water deposits and can help in some situations.
- If all preliminary steps do not work, I would recommend replacing the inlet valve.
I hope you find this information helpful. If you require additional assistance, please post you make and model number along with any additional questions, so I may be able to assist you better.
Nov 07, 2008 | Washing Machines
Washer won't fill in rinse cycle
REPLACE YOUR WATER INLET VALVE(HOT,COLD WHERE HOSES ARE)IT'S NOT OPENING ALL THE WAY TO LET THE WATER FILL UP FAST,LET ME KNOW HOW YOU DO-MIKE
Oct 19, 2008 | Maytag Washing Machines
Hot water is filling up washer very slow
There is a screen in the valve where the hose hooks on. It could be getting plugged up. turn off the water and pull off the hose to see if it's full of particles. I can sometimes clean it out by putting a bucket under the water inlet and spaying a little water from the hose into the opening. If not you may need a new valve.
Apr 18, 2008 | Kenmore 24032\24036 Top Load Washer
WD63 washer dryer
your inlet valve is not opening properly and needs to be replaced. this is quite a common fault with inlet valves
Mar 08, 2008 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
Top Washing Machines Experts
