Question about JVC HR-A592U S-VHS VCR
Programming a vcr
When I press menu on the remote the tv screen goes blank. It is a black screen.
  • zzoo Apr 16, 2008
    when i program the vcr i turn off the pow. it doesnt record and if i leave the pow on it still wont work. the vcr has no manual so i am doing it the same as my old vcr
Rebooting, (Unplugging the power cord for a few minutes, then reconnecting ) will allow you to bring up the menu.
The JVC factory tech said the the menu button is bad and the remote needs to be replaced. This doesn't make sense to me; since the button works after you reboot.
I believe that there is a glitch i0n the programing. Any other ideas as to the cause?
Posted on Feb 11, 2009
"when I press menu on the remote the tv screen goes blank. It is a black screen."
From other posts on this site, just unplug it, wait a minute or so, and plug it back in. I haven't done this yet, but I will go to my parents' place and try it with their vcr.
zzoo :
"when i program the vcr i turn off the pow. it doesnt record and if i leave the pow on it still wont work. the vcr has no manual so i am doing it the same as my old vcr"
No, this vcr is not like almost every other vcr in the world. To start recording you have to press the 'Timer' button near the bottom of the remote.
Posted on Nov 03, 2008
How can t I get the pop up screen when I apply menu. When I press menu nothing appends. I have the illico box for HD and had the videotron tech install it so I can recorded but since the menu does not work I cannot set the time or anything else on it.
Gilles T Garceau
Posted on Aug 26, 2008
How do I set the clock on a fisher fvh-7600 vcr I do not have a owners manual
Also having no manual for a Fisher FVH-7600, I eventually guessed how to set the clock after finding a remote control (Fisher RVR-7600) that works with it.
With the TV and VCR connected and powered on, the TV set to channel 3, and the remote's FUNCTION switch and VCR/TV button both set to VCR, I see a blank blue TV screen.
Then I press the PROG. button on the remote, and a menu with instructions appears on the TV screen. CLOCK SETTING is item 1 on that menu.
Sep 23, 2014 | Televison & Video
Acessing Menu with universal remote
We used a One4All model URC3021BOO remote. We programmed BOTH the TV function and the DVD/vcr button with code 0807.  To access the menu PRESS TV then MENU button then DVD/VCR button will allow you to change menu functions using left and right and select buttons. *TV button will access Menu screen BUT NO menu functions. * DVD/VCR button will NOT access menu screen but WILL control menu functions if menu is already displayed. May work with other sharp products, or other universal remotes? These original (RRMCG1330PESA) remotes run 38.00+ to buy new so try this FIRST!
on Oct 29, 2008 | Sharp 13VT-J100 13 in. Combo
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
• After timer recording is completed, the VCR turns off
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
Press SET –/+ to select one of
the program lines, then press
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
Aug 28, 2010 | JVC Televison & Video
Viore 7 tv no picture and tv disply
it is possibly you have put it into Cable mode or Video mode or even channel 3. also check and see if the remote has vcr/tv or tv/video you might have pressed this and that is why your tv is blank.
Feb 11, 2010 | Televison & Video
If you have the remote for the unit, with the incoming cable connected to the unit, on the remote, press menu/set up button, once in channel set up, select auto may take a couple minutes for all the channels to be found...once complete, select done/exit, or press the menu/set up button again to exit.
any questions, let me know.
Apr 29, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Closed captioning wont turn off
Go to the local Walmart and buy a generic controller and program it to your set. Go to MENU and follow the prompts. The remote will be less than 20 bucks, and you will have a remote that handles the TV, the VCR, the DVD, and the cable box. We go through roughly ten remotes a year. They all make the closed caption go away. One tip: don't lose the manual, or you will need to buy another remote. If the batteries fall out, or go dead, the remote will have to be reprogrammed. Underline the code numbers that work.The black box goes away when the info button on the remote is pressed.
Aug 25, 2008 | JVC AV-27D302 27" TV
Magnavox with pic tube tv skips over channel 3..goes from 2 to 4
You are right about the auto-programming, but Magnavox no longer has the original remote.
For my answer to be right, you must have posted this question to the EXACT CORRECT model # of your Magnavox TV - 27ms343s:
Press TV on your Verizon remote, and then press "0" and "3"
If that fails:
Press MENU to see the TV’s on-screen
menu. In the menu, use VOL.+/_ and
CH.+/_ to make adjustments or selections.
You can press MENU on either the
remote control or the front of the TV to
access or remove the menu.
Jun 14, 2008 | Philips Magnavox 27MS343S 27" TV
No remote specific to Sharp combo to turn off closed captionning
on some models the menu button is on the front disguised as the volume up/down or channel up/down buttons. you have to push both up/down buttons on either one of these to bring up the menu.
Apr 24, 2008 | Sharp 13VT-K100 13 in. Combo
Unable to connect philips dvd recorder/vcr recorder to philips flat screen 19pfl4322 tv. HAVE AV 1 AND AV2 ON FLAT SCREEN TV BUT RECORDER WILL NOT GIVE MENU PICTURE. COAXIAL CABLE ATTACHED TO VCR AHD...
make sure that av 1 out on the dvd go into av1 in on the screen and av2out goes to av2in onto the screen.make sure the cable is not av on the tv remote till you find it. same with the vcr remote
Mar 31, 2008 | Televison & Video
(1). Go to dollar store buy 4in1 remote control has all codes for all tvs cost $5.00 also you can enter menu on front of tv press menu button on front of tv when menu comes up use your channel up and channel down for up&down menu -- use vol- & vol+ to change settings
Jan 27, 2008 | RCA B27TF680 27 in. TV/VCR/DVD Combo
308 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
