Question about Samsung PCL542R 54" Rear Projection Television
No picture on samsung pcl542r, the screen is black
  • lashawn_lint Sep 12, 2009
    I'm not sure, but I don't think that is the issue. I am leaning more towards a lamp issue. I can see a picture, but it is very faint and dark. Could it be the lamp?
    President:
  • 2,187 Answers
If there is a faint picture it could be an issue with the back light. It can be the ballast or the actual backlight or both. The ballast would be the piece before the back light. If there is power given by the ballast then there is an issue with the back light. If there is non have the ballast tested it may need replacing. While at it check if there are leaking capacitors or loose solders that may also cause the problem. These parts are hard to find spare parts for a tv because these are replaced by service centers.
Posted on Sep 13, 2009
    President:
  • 1,462 Answers
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Thanks for contacting Fixya
Posted on Sep 12, 2009
Need new screen
Based on the model and brand either look to Samsung (may no longer be available because of age) or GOOGLE screen replacement as there are several sites selling replacement screens for the older sets---note most are actually two screens and a few have a third which is clear with anti-glare and some only sell the screens as a set.
Mar 20, 2012 | Samsung PCL542R 54" Rear Projection...
What is a flyback and where is it located on the samsung pcl542r projection tv?
It is a type of transformer if you open up yout tv you can find it easily by the big cord comming out of the top.
Mar 14, 2010 | Samsung PCL542R 54" Rear Projection...
Where can i find a owners manual for my samsung television model number pcl542r
Go to : store.payloadz.com/.../583483-eBooks-Technical-Samsung-TV-TelevisionTV-Service-Repair-Manual-PCL542R.zip.html - you can download it
Mar 07, 2010 | Samsung PCL545R 54" Rear Projection...
Picture has little white spots everywhere tv is rear projetion 57" samsung
What you are seeing is asbestos insulation inside the crt tubes that has come loose or flaked off and is interferring with the scanning beams. The only remedy is to replace all three crt tubes.
Jul 09, 2009 | Samsung PCL542R 54" Rear Projection...
My samsung pcl542r has a red tinge to it adjustments do not seem to help
the picture tubes (green&blue) are the problem
they either have bad liquid or coolent pad
Jun 07, 2009 | Samsung PCL545R 54" Rear Projection...
Samsung big screen tv model pcl542r has a green or red tint to picture
This is for the 50" Vizio TV,
It sound like the control board has a problem. There is two way to fix this.
- Upgrade the firmware of the control board, If you can find the firmware upgrade device.
- Replace the control board (I think this the best solution)
Feb 08, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
do you have a service manual for this tv because it may be your red drive circuit and you need to trouble shoot it if you don't have a service manual for your tv I will post a link where you can get one plus free online tech support to help you troubleshoot this problem
http://servicemanuals.vstore.ca/
Apr 23, 2008 | Samsung PCL545R 54" Rear Projection...
PCL542r convergence
Samsung part number AA95-00706C its available at www.partsstore.com
Mar 13, 2008 | Samsung PCL545R 54" Rear Projection...
The color on my PCL542R is off...
try turning up the blue drive alittle see if that helps.
Feb 02, 2008 | Samsung PCL542R 54" Rear Projection...
Samsung PCL542R 54" Rear Projection Television Logo
111 people viewed this question
Jerry Greenberg
Jerry Greenberg
