Question about Toshiba SD-5000
Toshiba SD5000 ...get a constant flashing "load" message
Have unplugged unit and replied power in the past, and this has sometimes worked. Sometimes get a "bad CD" message, but unit will not play any CD anymore
Can I clean the lens and laser with CD cleaning fluid or isopropyl alcohol?
Where can I purchase a new laser light for this model?
  • 736 Answers
Often the laser can become blocked by dust hair or smoke accumulation .. you can take it apart and clean the lens with eye glass cleaning solution .. but be careful its really delicate (flexible mount) .. there is something else that you might want to try first .. at most appliance stores they have a cleaning disk (about $8 or you can sometimes find them for $2) .. this disk has a brush mounted across some tracks .. dont touch the brushes .. just insert the disk and it will automatically brush off any dust or hair .. it wont however remove smoke .. its usually worth a try and works about 70% of the time .. you can clean the lens periodically with that ..
if you clean the lens directly then dont spray anything on the lens .. spray on a lintless cloth, soft paper towel or qtip .. dont get spray down into the mechanism .
the lasers do go bad with time and are often replacable but the cost + labor is almost always greater than replacing the entire unit .. the "laser" is actually a complex optical system that both transmits light and receives light .. it also has an automatic alignment mechanism as part of the "laser" assembly .. you have to replace that entire thing as a unit .. you cant just replace the laser .. ..
Posted on Sep 12, 2009
I have a Pride Sundancer that will usually go forward but not reverse. Green light flashed 3 then 5 blinks. What is the problem
Hi charge batteries & get them load tested ..U can buy a BATTERY LOAD TESTER of E/BAY cost aprox $36 this will give U an accurate reading on there condition,.3 flashe's unplug charger & turn key of & back on ..5 flashe's remove key push freewheel lever into freewheel & back into drive put key back & try it . Cheers
Nov 30, 2016 | Pride Health & Beauty
All my DVDs say "invalid" when I try and play. This just started all of a sudden. Was working just fine before.
Always first unplug for a minute and make sure the discs are VERY CLEAN. Sometimes my player/recorders give an error message 2-3 times but eventually are able to load the disc.
Mar 29, 2014 | Toshiba UNTESTED, AS IS BDX2150KU Blu-Ray...
Toshiba TP50G90, makes a loud popping sound then shuts off. red light flashes
it sounds like its over heating.clean all the fans ,put new artic paste on the cpu
Jan 25, 2018 | Toshiba TP50G90 50" Rear Projection...
After power on, the printer Leds flashes and I see several error numbers if I turn off an on. Sometimes it says that the cardridges should be changed, but they are bew and original. Than also a message...
Hi there.. based on your concern, it seems that your printer is having problems with the memory inside because it is not working..there's no reset with your machine.. and the only thing that you can do is to do a power reset by unplugging the cord from the back and plug it back in after 30secs.
if you have any questionsfeel free to reply on this message..
Jun 03, 2011 | HP Photosmart C5280 Printer
Computer won't turn on
Was it kept in a dry environment?
There goes a silly trick that sometimes works: unplug the power cord and press the power button for a few seconds. Then try to power up.
Try unplugging the floppy (if there is one in your machine). Sometimes capacitors load while unplugging the mains power. If that does not work, try a barebone (board, vga and ram only) configuration. If it works, keep adding parts until it locks. Then you will have youl culprit.
Oct 15, 2008 | Stormtek Gigapro 2000+ PC Desktop
Flash Cards
if its under warranty then you need not worry, you should contact the service centre, but before going there make all backup of your important documents..........
thanks
iqbal
Apr 02, 2008 | Toshiba Satellite A205-S4607 Notebook PC
DVD players not always beinvg able to load DVDs
You have bad filter caps in the power supply c10 and c11 need replaced and unplug unit when not using as power supply stays on always,,,,as long as its plugged in its on(P>S>) that is
Jan 02, 2008 | Cyberhome CH-DVD 300 DVD Player
Toshiba 50" cinema series
Try to unplug and replug back the power cord of the
tv and turn it on again. Sometime this work.
Sep 09, 2007 | Toshiba 55H70 55" Rear Projection...
Toshiba SD-5000 Logo
326 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
