Question about Refrigerators
Avanti EWC16B (wine cooler) got fried by power surge
Avanti EWC16B (wine cooler) does not work anymore after a power surge in our building. Which part of this cooler could have been affected and is it easy to repair? http://www.avantiproducts.com/parts/ewc16b_exploded_view_and_parts_list.pdf
  • Patrick de Man Jul 28, 2010
    The fuse was indeed blown, so I replaced it by soldering in a 2.5A 250V one in a fuse holder. However, the cooler still does not work. I tested the diode closest to the fuse, but that seems to be fine. There are a bunch of other diodes. Any idea?
  • 93 Answers
A lot of time during storms the control boards in appliances get messed up. Try unplugging it and plugging it back in after about 20 seconds. A lot of times that will reset the controls.....if they did not get fried.
Posted on Sep 12, 2009
Testimonial: "I enjoyed the detailed explanation. The fuse was indeed blown, but the diode probably as well. But can anything else be blown??"
There is a 2.5A 240V fuse soldered onto the main pcb board at the rear of the unit. Likely it is blown. It is covered with black heatshrink. You will need to solder a new one in. Also the diode 1N4007 that is near the fuse sometimes blows. This is a common diode that will cost about $1. You can probably use something close like anything else in the 1N400X series. This diode is near the edge of the pcboard on the same side as the fuse..
Posted on Jan 24, 2010
My avanti wine chiller mod ewc 16 b serial n.0800854 stop cooling what can i do ?
I've added a link for an Avanti ewcb,
http://www.retrevo.com/support/Avanti-EWC16B-Refrigerators-manual/id/867bh235/t/2/. There you can find a complete manual on the product which will help you to locate where the problem is coming from. hope I've helped!
Oct 24, 2012 | Avanti EWC16B Thermoelectric Wine Cooler...
I have a Avanti wc492d wine cooler that is not working. The unit shows power(lights are working) but it will not cool at all. I can here a click sound when I change the temp set, but the cooler will not...
The issue could be the cold control, timer, wiring, or the compressor.
The temp control has to be closed for voltage to get to the timer. The timer then calls for the fans and compressor to run. The timer could have stalled after a defrost cycle or the cold control could not be sending voltage to the timer.
Jan 28, 2011 | Avanti WC492D Wine Cooler
Wine cooler has no light or power working it simply shut down
you want to check power coming into unit... do you have power at the switch... there was alot of issues a ton etime with there power control switches and thermostats... check incoming power to unit and see if the switch has failed... also these units have small controls on them that will fail from time to time. you are going to have to see where power has failed at.
Jan 03, 2011 | Avanti EWC28 Wine Cooler
Power surge caused wine cooler to quit cooling
Power surges, spike and brown-outs are a nemesis to small refrigeration units. The capacitor for the compressor likey was affected and possibly the start components in general, especially if the unit was operating when the surge occured.
Jul 20, 2010 | Haier BC112G Wine Cooler
My Avanti wine cooler, model WC3201D, stopped cooling
same problem, can not fix. Had a authorized service tech who said that you can not add freon to this unit, the only option is to plant flowers in it.
Nov 20, 2009 | Avanti WC3201D Wine Cooler
AVANTI WCR683DZD WINE CHILLER - E4 ERROR CODE
I have the same E4 problem. You can order the PCB from Avanti at Miami Florida or your regional Avanti service rep.
Jun 04, 2009 | Avanti WCR683DZD Stainless Steel Wine...
2 mos old. simply stopped working. no power at all to lights, motor ,etc.
check if you get power by the motor if no power change the thermostat
May 13, 2009 | Avanti WCR683DZD Stainless Steel Wine...
Avanti WC492D wine cooler temperature control does not work
the wine cooler has to be at least 3" away from the wall, do not block the air flow to the condenser. or check power plug to outlet is it secure.
Feb 21, 2009 | Avanti WC492D Wine Cooler
My cooler cannot cool
pull it out and lay hands on the compressor and see if its running if not replace the thermostat
May 27, 2008 | Avanti EWC28 Wine Cooler
Avanti EWC28 Wine Cooler TOO Cool
contact avanti cust svc they are easy to work with and want you happy tell them your promb but i suspect you need a new themostat
Dec 31, 2007 | Avanti EWC28 Wine Cooler
Refrigerators Logo
612 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
