Question about HP Pavilion dv6000z Notebook
Printer will not print from computer .printer is on and appears to be connectes to computer.
    Scholar:
  • 77 Answers
Try replugging the printer into the computer - do you hear a sound indicating it's being connected? Try a different port on your computer as well. Also try powering off both the printer and pc and trying again - if it still doesn't work, click on start, go to printers/faxes, and make sure your printer is showing up in the list - if not, then click on add printer, and go through the add printer wizard to readd the printer to the computer. Hope this helps! Good luck!
Posted on Sep 12, 2009
My printer wint print from my mac its all connected but when i press on print it just wont print i have a mac osx and a hp envy printer 410
down load the driver for the printer into the mac as it appears that the mac is not recognizing the printer.
Feb 11, 2015 | HP Office Equipment & Supplies
My office jet G85 won't print. No error messages appear,it has a new color cartridge,it copies, but won't print from my computer.
If it copies ok, then the issue is either the way it is cabled to computer or the print driver software settings on pc.... How is it connected via USB? Check port and correct driver is in windows/control panel/printers. Reinstall.
Nov 30, 2011 | HP OfficeJet G85 All-In-One InkJet Printer
Not printing from a mac
Use one of the following methods to print, depending on how the printer is connected to the computer. hpweb_1-2_minus.gif Method one: Printing from a USB printer
  1. Make sure your printer is turned on and connected.
  2. Open a document to print, and then choose File > Print .
    NOTE: You can also go directly to System Preferences > Print & Fax .
  3. From the Printer pop-up menu, choose your printer. If you do not see your printer listed, choose Add Printer , and then click More Printers .
  4. In the Name column, select your printer, and then click Add .
hpweb_1-2_minus.gif Method two: Printing from a network printer You can connect to HP printers on your local network (wireless and Ethernet) using Bonjour or IP, as well as shared printers connected to an Apple Airport base station.
NOTE: Apple does not support AppleTalk in Mac OS X 10.6.
  1. Choose File > Print .
  2. From the Printer pop-up menu, choose your printer. A dialog appears, listing any Bonjour printers on your local network. It may take a minute or two for your printer to appear.
    NOTE: Your printer may also be listed in the Nearby Printers submenu.
  3. If your printer does not appear, choose Add Printer from the Printer pop-up menu. Printers that are turned on and connected to the local network (wireless and Ethernet) should appear as Bonjour devices.
  4. Select your device from the list, and then click Add to create the HP printer queue for your HP Photosmart, Officejet, or Deskjet All-in-One printer.
Your computer can usually detect whether a printer has special accessories installed, such as additional paper trays or a duplex unit. If it cannot, a dialog appears that lets you specify them. To enable full functionality, make sure the settings in that dialog accurately reflect the installed options.
The latest HP Utility is included in Mac OS X 10.6.
Method one: Open the HP Utility from System Preferences
  2. From the Apple menu, choose System Preferences .
  3. Click Print & Fax .
  4. In the list of printers on the left side of the dialog, select the HP All-in-One to view the options in the Print & Fax window.
  5. Click Options and Supplies .
  6. Click the Utility tab at the top of the window, and then click Open Printer Utility . The HP Utility opens. Features and options may vary depending on your printer model.
Method two: Alternative The HP Utility can also be launched from the printer icon in the dock to open the Printer Browser window.
  1. Double-click the printer icon. The Printer Browser window opens.
  2. Click Printer Setup in the toolbar.
  3. Click the Utility tab.
  4. Click Open Printer Utility . The HP Utility opens. Features and options may vary depending on your printer model.
Jan 18, 2011 | HP Officejet 6310 All-In-One InkJet...
Printer is offline how do I get it online?
Try to print. Once an error appear on your computer, right click the printer icon on the taskbar and click open printer connection.
Printer window will appear.
Highlight the pending print job. Click the File menu and uncheck the Print Offline.
Right click on the pending print job and select Restart printing documents.
Jun 23, 2010 | Canon PIXMA MX340 Wireless Office...
Lost ip/connection on Dell 1720dn
try resetting the "print spooler"
  1. start
  2. control panel
  3. admin. tools
  4. computer management
  5. services and applications
  6. services
  7. scroll down till you see "print spooler"
  8. left click once
  9. "restart"
Jan 06, 2010 | Dell 1720dn Laser Printer
Computer appears to communicating with the printer but will not print. Jobs are in que but will not print.
Thermal printers can have a warm up stage, though it rarely exceeds a minute or so,
Check all cables and connections, if the problem persists, try uninstalling and then re installing the printer driver,
Hope this helps.
May 24, 2009 | HP Officejet 5510 All-In-One Thermal...
Sharing my computers and my printer on ahome network
At first you need to share the printer. in another computer now you can add printer.
Jan 25, 2009 | Acer Aspire™ T180 PC Desktop
Printer Won't Print
Step one: Restart the computer
Click Start and click Shut Down.
Click Restart or select Restart from the menu. Click OK.
After the computer restarts, double-click the Printer icon in the system tray located at the bottom, right of the computer. The print queue opens. If no documents appear in the print queue, the issue is resolved.
If the issue continues, proceed to the next step.
Step two: Check the product cable, Disconnect the USB cable from the product and from the computer.
Wait 5 to 6 seconds. Reconnect the USB cable to the product and computer.
(NOTE: The product must be connected directly to the computer using a USB cable or a powered USB hub. If the product is connected to the computer through a non-powered USB hub, or if the type of hub is unknown, connect the product directly to the computer) after the product is connected to the computer, the product should start printing the jobs in the print queue. If the issue continues, proceed to the next step.
Step three: Determine whether the product is paused or offline, Click Start and click Printers and Faxes. The Printers and Faxes window appears. In the Printers and Faxes window, right-click the product icon and click Open. The Printers folder opens. On the menu bar, click Printer. Make sure that the Pause Printing and Use Printer Offline options are not selected. If a check mark appears next to either option, click to remove it. If the menu includes Use Printer Online, click that option.
If neither Pause Printing nor Use Printer Offline is selected, press Esc to leave the menu without making changes.
Step four: Stop the print queue, Double-click Macintosh HD, Double-click the Application/Utilities folder.
Open the Print Setup Utility folder; Double-click the appropriate product in the product list to open the print queue.
Click Start Jobs. (NOTE: If the queue was accidentally stopped, the print job will resume automatically. If the issue continues, proceed to the next step)
Step five: Delete the print jobs, Double-click Macintosh HD, Double-click the Application/Utilities folder.
Open the Print Setup Utility folder, Click a print job and click the Delete icon. Repeat the steps for all the jobs in the print queue, Click Start Jobs, Double-click the appropriate product in the product list to open the print queue.
When the print queue is empty, click Start Jobs. Try the print job again. If the issue continues, proceed to the next step.
Step six: Remove and re-add the product to the printer list, Double-click Macintosh HD, Double-click the Application/Utilities folder, Open the Print Setup Utility folder, Select the appropriate product.
Click the red X to delete the product from the computer, Disconnect the USB or Ethernet cable from the product.
Close all open windows and restart the computer, after the computer is restarted, double-click Macintosh HD.
Double-click the Application/Utilities folder, Open the Print Setup Utility folder, and Reconnect the USB or Ethernet cable to the product. If the product is not automatically added, click Add. Select the product to add and click the Add button. After a few seconds, the product appears in the printer list. Try the print job again.
Jul 18, 2008 | HP DeskJet 5150 InkJet Printer
Prints gobbledgook!
You diagnosed a bad connection with the computer. Try changing the connection cord, borrow one if you can, just to test it. What does "leads appear fine mean?" Best Wishes.
Mar 21, 2008 | Epson Stylus Photo R320 InkJet Printer
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
