Question about Lenovo IdeaPad S10e Netbook
Cannot find hard disk drive
Only the 'C' drive shows up with 4GB of space (almost all of which is used). I have used the PC Doctor application to test the 2nd hard disk drive (it passes fine) but I can't even find it.
  • 3,153 Answers
On a laptop the second drive you refer to is usually there for RESTORE functions or as a DIAGNOSTIC PARTITION.
DO NOT DELETE THIS OR ITS CONTENTS !
If you do you may not be able to restore your laptop should you need to for any reason.
I would personally recommend that you do a major clean up on your C drive.
Also consider an external drive.
If you must have more space then a hard drive upgrade is your best solution.
this is a relatively simple process for a good repair shop and would leave you with a spare hard drive that you could place in an external enclosure as LARGE additional storage.
I do these types of upgrade on a regular basis and even the hidden partition is transfered safely to a new larger drive with such as the Acronis software.
Posted on Sep 13, 2009
  • 125 Answers
Did you look in the Windows Disk manager? How about the Device Manager. You should see it in both of those. If not in there, then check your BIOS for them. Maybe it is not recognized in your startup BIOS. Generally, you hold down the F6 or F8 key while restarting to get into the BIOS. Check your manufacturer's website for which key to use if those don't work and make sure the disks are detected and listed properly there. If that doesn't work, select return to default setting in the BIOS.
Posted on Sep 12, 2009
My sandisk cruzer 4 GB pendrive ws working fine but now whenever i try to format\copy\cut it shows location 0 with used space 0 free space 0 what should i do
Your flashdrive usually shows 2 drives when inserted to your computer, one is the U3 drive and the other one is the removable disk drives. U3 drive is your separate partition for the U3 system and in order for you to store, copy, format your flashdrive, you should be selecting the removable disk drive, not the U3 drive. U3 is a read only memory drive that is responsible for your U3 to work (just like portable applications). Hope this helps.
Jul 04, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Hi, I have WD 1TB Elements SE. When I checked the usage space on the partition after I plug in the drive, it shows a total capacity as 1,000,200,990,720 bytes (931 GB) and it shows 921,753,505,792 bytes...
If you have a 32bit system, it is expected to have miscalculations, a 32 bits can only go up to 4Gb for calculations (that is, 2^32 = 4'294'967'296 bytes) a 64bit system can make calculations to 2^64 bytes this is also why you couldn't copy a file larger than 4Gb in a 32bit operating system...
So, if you are running a 32bit OS, you should expect a discrepancy for the total space of the Hard Drive and the amount it shows (that's the 93Gb you are missing as total capacity).
Another reason why it can show you incorrect calculations are damaged sectors on the hard drive it-self. These will present themselves either as occupied memory or missing memory.
So, you should expect some miss calculations and you can expect some damaged sectors on the hard disk (a external drive spins on and off too often, eventually damaging sectors... its a problem of physical drives).
In the end, your disk might be fragmented, so run a disk analysis and a defragmentation on the disk so it can recalculate.
A note: A disk is like a shelve, you put things where there is space, if you remove things, that space will be open, and if you want to put something there it has to be the exact size or small enough to fit there. This effect, when things are small enough leaves blank spaces unusable, consuming space on the hard drive and making the access of files slower, this is fragmentation. In order to expand your disk life expectancy you should run defragmentations...
To run a defragmentation, go to START, write "Disk Defragmenter", choose your disk and run and analysis and defragmentation.
Jun 24, 2011 | Western Digital Wd Elements Se 1tb...
My pen dive doesn't show it memory . when i connect my 4gb pendive onto my pc then pc show me a removable disk connected but when i try to see properties then pc shows me that used space is o bytes and...
The problem you are talking about is most probably of the virus infection. Try to format your pen drive in your system and you can restore back your pen drive.
Dec 22, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
1)How to find and remove the hard drive on the IBM ThinkPad T22 2647. 2)The comp appears to start but screen is blank
hi
to remove the hard disk, remove screws from small hard disk drive door (loacted on back of notebook), disconnect the hard disk by removing two screws (if applicable) pull tab to remove disk.
OR -----
if you do eventually get access to your operating system , when computer runs normally ---
run this test ,, read carefully and follow instructions - go to this link and download the program first
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-70578
then follow instructions below.
Windows XP
  1. Click Start, select Search, then click All files and folders.
  2. Type hddquicktest_setup_60549818x86.exe in the search field, then click Search. This will locate the file you just downloaded.
  3. Double-click the hddquicktest_setup_60549818x86.exe icon.
  4. PC-Doctor for Windows will be installed on your system.
How to Run Lenovo Hard Drive Quick Test
Summary
Lenovo Hard Drive Quick Test is a diagnostic tool that tests the hard drives in Lenovo ThinkPad, ThinkCentre, and Lenovo 3000 computers running Windows XP or Vista released after January 2004. If you are experiencing issues with your Lenovo product, you may run this test to determine if your issues are hard drive related.
Running Lenovo Hard Drive Quick Test
To run Lenovo Hard Drive Quick Test from Windows, follow these steps:
1. Download the test to your computer.
2. Run the application install and choose the defaults. Once installed, the application will be placed under a "Lenovo Services" choice on your Start Menu.
3. If the application detects that the Lenovo System Toolbox is already installed, it will ask whether you want to continue the installation. This is because the new hard drive test is installed by default as part of the Lenovo System Toolbox.
4. Choose a drive if you have more than one drive.
5. Start the Test
Testing in process:
1. The test may take 4 to 6 minutes depending on the size and speed of the drive.
2. When the diagnostics are complete, a message will be displayed indicating that test "Passed", "Failed", or "further testing is required to verify the drive's proper operation". If further testing is required, start running the extended test. The test may take more than an hour depending on the size and speed of the drive.
3. When the diagnostics are complete the extended test, a message will be displayed indicating that the test Passed" or Failed".
4. If the test failed, contact Lenovo Support Center
Note: Lenovo Hard Drive Quick Test is included in http://www.lenovo.com/systemtoolbox
Lenovo System Toolbox is a full application of computer diagnostics utilities.
hope this helps
Nov 15, 2010 | IBM ThinkPad T22 2647 Notebook
I receive a no operation system message while booting
Buy a new hard disk drive! Use the 2 golden Gateway, Applications, Drivers, & Operating System disc, also known as Restoration DVD to reinstall your Gateway programs & operating system. After that, reinstall your backups.
How much disk space do you need? Why buy a 320 GB HDD if you only use 4 GB? So, keep the bytes down if you don't need them and that will keep the costs down, too!
The Gateway support discs can be had at: www.Gateway.com/Support .
~PC-Doctor
Nov 12, 2010 | Gateway (M520HD80G) Hard Drive
External Hard Drive not Accessible after Windows Vista Update
Assuming that the external hdd is physically working fine, everything is pointing to a damaged boot sector.
You can get back most (if not all) your data stored in your external drive with the help of an application called: Pc Inspector File recovery.
Its a freeware.
Here is the link: http://pcinspector.de/Sites/file_recovery/download.htm?language=1#
Simply install it on your C:\ drive, and follow the prompts.
Please let us know the outcome.
Don't forget to rate this answer if it helps
Dec 12, 2009 | Maxtor Hard Drive
Not enough disk space to copy
Scan the drive due to possibly virus managing your disk drive. Virus can easily access through USB hard drives. If not solve the problem, so its better to format.
Mar 12, 2009 | Acomdata 500GB PureDrive USB eSATA 500 GB...
Not enough free disk space error
I saw that my drive was FAT32 and my machine is NTFS, wasn't sure that could be the issue until you replied advising the 4gb restriction. Does not make sense i transferd 4gb before, but none the less I reformatted the drive to NTFS and my file transfered just fine.
Thank you for your input.
Feb 05, 2009 | Western Digital External USB 2.0 80 GB...
Hard disk problem
This is because your current install is using all the Hard Disk space - it will be the other partitian on display at this point to get the space back you will have to delete the partitian the format it.
WARNING: Deleting the partitian will make you lose ALL the data currently on the Hard Drive
Jan 08, 2009 | HP Pavilion dv6000z Notebook
Reformatting.
hi there,
you can Format your drive on a Windows machine as "FAT32" and it will be usable both under Mac OS X and Windows. the only thing to make note of is there are some limitations on the FAT32 format, like the 4GB filesize limit and certain naming restrictions.
You can reformat your drive by opening Disk Utility and then reformatting it using that application. in Mac OS X
- In Disk Utility, select the disk.
- Click Erase.
- Choose format from the Volume Format pop-up menu
(select the windows based format).
- Type a name for the disk or volume.
- Click Erase.
- You can use the drive on both the mac and a PC by choosing MS-DOS from the Disk Utility application when you're about to reformat.
Apr 13, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Lenovo IdeaPad S10e Netbook Logo
191 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
