Question about Frigidaire FRS6R5EMB Side by Side Refrigerator
Icemaker continues to run water for several minutes
My icemaker runs water for about 3-5 minutes at a time filling up and freezing in the ice bin and also running out of the ice dispenser and then onto the floor. I too have set the lever to the stop position and water will begin flowing again for the same duration just a short while later.
  • 27 Answers
Water valve is out, or icemaker is calling for water when it doesn't need it which means it's broke... but i'm leaning towards the water valve is in need of replacement
Posted on Sep 24, 2009
  • 93 Answers
Change your icemaker module. It is getting stuck in the fill position. They are about 50 dollars or so and are held on with 3 screws normally.
Posted on Sep 16, 2009
Ice maker not dumping ice
It could be the harvest thermostat or the mold heater is bad on the icemaker. It is usually better to just replace the icemaker. Installing a harvest thermostat is a but tricky and the mold tray is 3/4 of the icemaker anyway..
Apr 08, 2014 | Refrigerators
Ice maker over flows water into ice hopper than it freezes
Several things can cause this issue.
1. Failed ice maker (overfilling)
You can easily replace the icemaker.
Lg 1 800 243-0000
2. Bad main computer. Or some one over adjusted the fill time on the computer.
3. bad water valve.
Jan 09, 2010 | LG LRSC-26922 Side by Side Refrigerator
I am looking for a schematic for the kenmore 51 lbs ice maker
There is supposed to be a cap or plug , at the bottom of the water bucket , to hold water for the recirculating pump . There is no cap at the bottom of the ice bin .
Sep 09, 2009 | Kenmore 51lb. Clear Ice Maker
Ice maker stopped working
The laser , is supposed to blink . This laser , tells the icemaker to stop making ice , when the bin is full . Pour about 2/3 cup of water into the icemaker . If it doesn't dump the cubes into the bin , the icemaker is bad . Or , if there is ice in the bin , which hasn't dumped , the icemaker is bad . If the icemaker dumps the ice ( from water pour ) , then look above the fill cup , and see if the black fill tube is frozen . If so , then replace the water valve and turn the freezer temp down slightly . It will take several days for this fill line inside freezer to thaw . If icemaker dumps , and black tube NOT frozen , replace the water valve . The valve , is where the wall water line connects to on the refrig .
Sep 05, 2009 | KitchenAid KSRP25FNSS Side by Side...
I have a Whirlpool refrige. side by side and the ice maker has stopped working. The infrared light keeps blinking. I have unplugged it a couple of times as well as turned the infrared off. Any advice?
Sep 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Sep 05, 2009 | Whirlpool Refrigerators
ICE DISPENSER
Dmuehr,
Are you sure it is a leak. Is the solenoid actually cutting off BEFORE the tray is full of water? If not, it is not a leak. The filling time for the icemaker water tray (where the ice freezes) varies depending on the local water pressure. With higher pressure, the tray may overfill. Your icemaker motor module timer may be set too long for your specific water pressure, so that the tray overfills. There is an adjustment on the module for shorter or longer fill time. You will need to remove the icemaker (3 screws probably) and reset the timer. It may take 2 or 3 tries to get it so the trays are about 80 to 90% full.
Jan 07, 2009 | Whirlpool GS6NBEXR Side by Side...
Kenmore koldspot model 106.56532400
Oviously you need water first. You'll have to check that the fill valve is opening and that the water is making it to the icemaker. Make sure the fill tube that feeds the water from the back of the frige to the icemaker is not frozen. Be aware, just because you get water at the dispenser doesn't mean the valve to the icemaker is ok. If you are getting water, you need to check that the icemaker is not jammed, sometimes ice can fall back into the icemaker, or get caught in the ejector. You may need to remove the icemaker and run the mold under hot water to melt the ice. If it was jammed, you'll need to check that the fill level is correct to prevent it from happening again, both too much water and too little water can cause problems. There is a heater that helps loosen the ice from the mold, because of that there is a thermal fuse to prevent it from over heating. It will be molded into the wiring harness supplying power to the icemaker. If you have continuity through the fuse it's ok. If you don't the heater shorted and you will need both a new icemaker and that wiring harness.
Jul 19, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice Maker Overflowing
i would recommend changing the water valves as they may be sticking or leaking now you can take the icemaker loose get a small baby bottle short the terminals to cycle water fill catch it with the bottle and see how much water it dumps should be about 4 ounces if the valve leaks will over fill the ice maker over a period of time say the valve is leaking a few drops at a time and the bail arm has the icemaker shut off because its touching ice in the bin but the water just keeps dripping down the fill tube till it runs over did you replace the whole icemaker or just the motor module
Jan 01, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Maytag MS2732GRW ice maker quit
guest make sure your wire arm on icemaker is down same dandcs also for orig poster they have duel water valves one goes to door water one goes to icemaker. icemaker works a general rule more than door water so wears out faster but you have to replace both as they are a unit .other things that will stop ice production are frozen ice fill tube ,bad motor module in icemaker .check that first .if that don't solve it then reply to me and we will get deeper
Dec 31, 2007 | Maytag MSD2732GR Side by Side Refrigerator
Frigidaire FRS6R5EMB Side by Side Refrigerator Logo
120 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
