Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
Dosnt Open via Remotes
Our garage door opener does not open from the remotes, only the wall mount. The remotes sometimes work and will work for about a day if we reset them, but just a day.
  • 5,603 Answers
Verify that the batteries in the remotes are good... best to replacee them if you haven't already done that.
Posted on Sep 12, 2009
Liftmaster 1255lm garage door opener
It sounds like a problem with the infrared safety beams, either they are not working, are misaligned (someone might have kicked/bumped into one), or I even had one that didn't work because there was too many cobwebs/dust covering one of the lenses.
Feb 09, 2014 | liftmaster Building Materials
I have a liftmaster formula 1 1280R opener that works fine from the wall mount but all of a sudden both remotes and the built-in remote in my car stopped working. It is not the batteries in the remotes. ...
The motor/control unit may have gotten reset. It needs to relearn the codes transmitted by the remotes.
MIne has a "learn" button on the control unit. Press and hold, then press the button on the remote. Lights will flash indicating it has received and stored the code. Release button.
Check to see if the remote works now. If so, all three should be working. If not, dig up your manuals.
Feb 28, 2013 | Sears Craftsman LiftMaster Chamberlain...
Remote won't work but keyless entry does on garage door
If the light in the wall control is flashing press and hold the lock button for 3 seconds. Your remote should now work.
Jul 23, 2012 | Sears Craftsman LiftMaster Chamberlain...
My Chamberlain Liftmaster Formula 1 garage door (2002) has stopped working. The power is on -- light turns on when I push the wall mount button. But the remotes no longer work. The door does not move. ...
The light by the learn button may be sending a diagnostic code. See if it is flashing a number of times, pausing and then repeating. Count the flashes. Is your door stuck in the open posititon?
Jun 11, 2011 | Sears Craftsman LiftMaster Chamberlain...
My lift-master garage opener works just fine from wall button, but will only open but not close from any remotes (from car or original remotes) If I open it with remote and immediately close with wall...
We have the same model and similar difficulties. We were told it's a bad antena. Not sure if there is anything we can do about this. Sometimes it works with the remotes, sometimes not. Always works with the wall switch, because that's wired.
Nov 12, 2010 | liftmaster Chamberlain Garage Door Opener...
(Chamberlain 1/2 hp Whisper Drive garage door opener) the garage mounted opener will open the door, but none of the remotes now work. batteries have been changed already. Is there a way to reprogram the...
If the wall button will operate the door up but none of the devices do then look at the wall button. Find the lock button and push it for 2 seconds and then try the remotes again. This is your vacation lock. You can get a manual at chamberlain.com. Now if the door does not open or close with the remotes you can reprogram them. Press the colored learn button on the motor head and then press the button on the remote. Repeat for each remote. If they fail to program you will need a new logic board. Thanks BB
Aug 18, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
Sear garage door wall mount contol light keeps blinking
Hold the button with the lock icon in for 3 seconds. This should toggle the unit off vacation mode and your remotes will work.
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage wall mount
This might be a easy fix but not sure two thigns I would try is check to make sure you don't have a lock switch on your wall control and if you do make sure its off. That locks out the remotes but oddly they go bad and sometimes just do really odd things. The other thing is check the wire to the wall control make sure theres no cuts or staples in it
Feb 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door only opens with wall unitq
The unit is in the lock mode, push and hold the lock button in for about two seconds and the green LED should stop flashing. Your remotes should work.
Dec 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Neither remote control will open door but wall mounted button wil
Make sure the code set inside the remote is the same as in the main reciving unit code.
Dec 06, 2008 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
129 people viewed this question
Top Chamberlain Car Audio & Video Experts
Glenn Mayer
Glenn Mayer
Vince Heuser
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
