Question about LG DU-42PX12XC 42 in. Plasma HDTV
Conection to mac mini
Hi. I have a 42" Plasma LG and I can't connect my mac mini to the TV. The gray screen appear and them the TV shows "no sign" on the screen. What should I do? Is that any configuration that I have to set before? I have a VGA/VGA cable and also a HDMI..... Thanks,
best regards.
Roberto.
Coldcut
  • 1554 Answers
SOURCE: lg plasma
there are 2 types of flicker, one is the lamps that drive the display and the second is the sync signal of the video.
I assume the video sync is the flicker you see,
I would try connecting a different way to make sure it is not the tv,
connect using the aux /rca connectors to cable box.
and or connect using the cable direct bypassing the cable box.
I have seen several complaints about the hdmi cable signal being incorrect in some way,
this is the same issue that the svideo connector had in its early adoption signal was too hot or too low.
another thing to watch out for is the low light sensor on the front of tv if it gets an incorrect reading it can flicker the back light though it should be slow in doing so.
some times the flicker you see is not flicker but ac running through the sides of the picture from an ungrounded cable source.
how does it perform if you play a dvd player , with and without the cable box connected.
Posted on Apr 29, 2008
snakehead
  • 1074 Answers
SOURCE: plasma
if your tv is on warranty take it back to best buy for a replacement.good luck
Posted on Jul 25, 2008
SOURCE: what kind of connector do I use to connect a dell
If your computer supports a HDMI connection that would be your best solution. If not then I would go with a DVI to HDMI cable.
Posted on Dec 14, 2009
SOURCE: sansui 42'' HDMI problem
howto get the hdmi signal thro hdmi to dvi cable in plasma pdp42 sansui tv in dvi input
Posted on Nov 14, 2010
Mas Baz
  • 177 Answers
SOURCE: Hi, I have bought LG LCD
Hi Jatinder Kumar ,
Yes you can connect your computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable.
1. Connect to HDMI (DVI) : just plug in HDMI (DVI) out of PC or laptop to HDMI or DVI TV. Than select source from HDMI.
2. Connect to PC : Plug D sub to TV, select PC in.
I hope that will help you.
thanks.
Posted on Mar 21, 2011
Tv plasma 42"
Could be an internal power supply problem affecting the video
Nov 01, 2013 | Televison & Video
42inch LG plasma TV
well if you could please give out the model nuumber thank you
Sep 10, 2008 | LG RU-42PZ61 42 in. HD-Ready Plasma...
Problem with the LG 42PC3D 42 in. Plasma Television Horizontal half black screen, sound is still there
Sorry this tv it is not repairable because the tv Plasma screen panel itself it is the tv problems and the causes,this tv only can be repair by replace the whole new tv Plasma screen panel itself only not practical.Because the tv Plasma screen panel are 90% inportant to the tv functions and the cost of the tv.By replacing the tv Plasma screen panel will cost the same as a new tv.
Sep 22, 2011 | LG 42PC3D 42 in. Plasma Television
Everytime i conect my monitor into my mac mini the screen shows up for a brief second and disapeers. how can i fix this
Hello sir, hi, you need to try another good working monitor, and confirm if the problem is your monitor or your Mac mini, or test your monitor on another mac, and see if the same symptoms appear. you now have an idea of where is the problem. let me know your progress
Apr 26, 2010 | Acer V193w LCD Monitor
Gray bars while full screen viewing my Broksonic CCVG-4500 42 in
hi, i have a broksonic model ccv-4500 , these is a monitor or tv because i cant founder the digital cable imput. thanks.
Apr 25, 2010 | Broksonic CCVG4200 42 in. Plasma TV
Very light colored verticle (1" wide) ribbon on LG 42" Plasma TV
The TV is design for 16:9 format. The bars appear when the TV off showing that the TV has been watching under channels which is have 4:3 format for long time. The screen was burn out because no sweepping to those area. This is not critical problem but you can do nothing to fix it. To eliminate it a bit you shoud read the manual, I believe it has mentioned how to roll or sweep the screen. For plasma TV, if you keep watching 4:3 channels fomat, you shoud do it one a month within 30'. Good luck
Aug 12, 2009 | LG 42PC1DA 42 in. Plasma HDTV
LG 42PC3D plasma television -- screen split down the middle
Our 42" LG picture is also split down the middle. It doesn't matter if it is cable or a DVD. I would love to know if anyone has found out the solution to this prob. The TV is only 3 years old...
Jun 19, 2008 | LG 42PC3D 42 in. Plasma Television
LG PLASMA TV WITH COLOURED LINES OVER SCREEN
If the Video (Picture/Pix) is gone but you can hear the Audio (sound), then it could mean the YSUS PCB Assembly is gone/kaput/finish. Can replace the PCB, not repair the PCB due to timing circuitry involve. Cost maybe roughly $500 depending where you located. The PCB is located on the left hand side of your TV when you are facing the back (Back open). Might find 3-4 brown flex membrane connecting to the plasma panel. The PCB has a silver or black aluminum heatsink (big) on it.
Good Luck.
Dec 22, 2007 | LG 42PX5D 42 in. Plasma HDTV
Lg 42PX4dv PC connection
I think the problem is the screen resolution and size of your pc is not matching the resolution size of your tv or is not compatable at the size you have it on or you may have to change to 4:3 ratio from widescreen. In your manual it will tell you the resolution sizes that you tv uses. You would probably be better also using the VGA to DVI lead, thats if it came with the tv (it does in the UK) as it supports higher wide screen resolution, whereas VGA will only support 1024 x 768 or there abouts.
May 19, 2007 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
LG DU-42PX12XC 42 in. Plasma HDTV Logo
61 people viewed this question
Computer Repairing
Computer Repairing
