Question about Pioneer SD-643HD5 64" Rear Projection Television
Pioneer sd-643hd5 fuse issue
Today I picked up a pioneer sd-643hd5 from someone that was having issues with the unit, this is a 64 inch widescreen projection unit.
Basicly the unit was trapped in standby mode, after a great deal of research I opened up the unit to discover that on the power supply/ middle board the middle and right fuse were blown.
more research indicated that a 5A fuse was generally found in the middle of these 3 fuses
What was located in the unit from left to right was 5a 125v then in the middle: 4a 125v and on the right a 5a 125v
I replaced the middle and right fuse with corrisponding types, fired up the machine, it went into standby then went green for all of 2 seconds. so I replaced the the fuses again only this time I put a 5 amp in the middle as well. This time the unit fires up but sputters in green mode before finally giving up. it however is not blowing the fuses.
My question is this, what spec fuses are supposed to be in these spots
ps plug fuse tests with active current
  • 1 more comment
  • meeowssir Sep 13, 2009
    origional poster here: Well here is the thing on the back of the power supply assembly the light thats comming on is the little red one on the board that says power supply assembly? I havnt gone as far as to pull the boards yet but I do believe the def assembly has at least 1 loose circut.
    Top Expert:
  • Pioneer Master
  • 14,553 Answers
The fuses may not be your problem--I have fixed several of these---The large power board is on the right side as you look from the back?
Lots of these sets develop bad solder connections on that board--several sites on the internet offer to have you remove and send them the board to resolder--this set used lead free solder and after some years has problems--a few I have opened had clearly broken solder joints--I usually in this case remove the board(mark all the many plugs and make a diagram) and solder almost all of it by hand----usually fixes this kind of trouble.
I do this here for free so if this information was helpful give me a vote here....I am here to help people.
If you have any questions or need advice reply to this posting here.
SD TECH
Posted on Sep 12, 2009
Testimonial: "Thank you very much, I only wish I knew where to find a free schematic"
  • rxinverstor Oct 30, 2010
    I have a Pioneer 64in rear projection TV which keeps blowing fuse FU 303. I'll replace the fuse and it will work for a week to 10 days then blows again.\r\n
    Any thoughts are greatly appreciated.
    Pioneer SD 643HD5
If you look at the circuit board, the proper fuse for the spot is listed next to it, I think on the right hand side.
Posted on Apr 25, 2010
I have a 64 inch hdtv pioneer projection monitor sd-643hd5 and it won't fit into my basement. What can I do? Thank You In Advance, Bruce Morash
Ha Ha, I had the exact problem. I think mine is the same model of TV as well, I have a 64" Pioneer made in 2003. So my TV would hit the slanted ceiling above my stairs as I tried to move it down. I first took off the wheels of the TV and this helped but it was not quite enough. So since the bottom of the TV is flat with exception of the side boards and the front trim. I removed the front trim temporarily and cut off the side boards with a circular saw till even with the flat bottom. This gave me 2.5" more clearance which was enough to fit the TV downstairs. Hint if you scribe the cut line with a utility knife it will reduce chipping.
TimBilt
Mar 28, 2011 | Pioneer SD-643HD5 64" Rear Projection...
I have a Pioneer SD-643HD5 that was working and then just turned off? Now the tv won't turn on
CK for Blowed Fuse will be in middle of chassis 6amp fuse if it is blowed set will not come on.
Dec 30, 2009 | Pioneer SD-643HD5 64" Rear Projection...
Convergence board cracked?
Once the board is cracked it is no longer repairable (even if it's a tiny crack that may not appear to interrupt any connections), and you would have to replace the complete board. Any attempt to repair or continue using a cracked board may cause more damage to the entire unit. You can find a replacement digital convergence board for a model # SD-643HD5 from this major Pioneer parts distributor at the following link:
Pioneer SD-643HD5 Replacement Part Digital Convergence Board
Feb 02, 2009 | Pioneer SD-643HD5 64" Rear Projection...
Where do i find convergence chips for a pioneer sd-643hd5
Complete convergence assy is available in Part Store for $126
Pioneer Parts has same CONVERGENCE ASSY for $288
Jan 25, 2009 | Pioneer SD-643HD5 64" Rear Projection...
Pioneer sd-643hd5
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Nov 03, 2007 | Pioneer SD-643HD5 64" Rear Projection...
Pioneer SD-643HD5 does not power on
i had the same problem and it was the flyback transformer on the power supply board.it cost me $375 for the board.just make sure you ground yourself because the static electricity could fry it all.when unplugging the cables mark them and be careful.use a jewlers flat head scewdriver to unlock the cables.use a can of compressed air to clean off the dust.
Aug 26, 2007 | Pioneer SD-643HD5 64" Rear Projection...
Pioneer SD-643HD5 64" Rear Projection Television Logo
763 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
