Question about Western Digital My Book Essential 1TB External USB 2.0 Hard Drive
I have a WD my book essential external HD which 1T. I accidentally pulled the USB cable while it is still running. When I plugged the cable again the device is detected but it is not visible in 'my computer' is there any solution with my problem? I'd be thankfull for any suggestion
  • 696 Answers
Unfortunately if these drives are unplugged while running the structure of the drive can be damaged, normally if they show up in my computer there is a simple fix that works about 1/2 the time but if it is not showing up that will not work.
The two remaining possibilities are that the enclosure circuit board was damaged or that the structure was damaged as expected just worse than usual.
If you right-click 'My Computer', then select Manage, the MMC will open. Now click on the Disk Management utility and maximize the window. When it's done reading the drives and displays them scroll through the list and see if your 1TB drive shows in the list, if it does report back the exact wording and partition sizes showing as this may indicate a problem you can solve with inexpensive software.
If it doesn't show up this indicates that either the drive enclosure circuit or the drive itself is damaged. Report back including your Country, State and City and I can point you in the right direction for the professional assistance you will need on this issue.
Hope this helps FixYa
Posted on Sep 13, 2009
I accidentally plugged in my 19v toshiba laptop adapter to my 16v 1tb external hard drive it started up but then i plugged it out soon is it possible that the hard drive will work or is it dead, if no
The electronics in the hard drive is damaged and cannot be repaired by us mortals.
There are companies that can recover data from damaged hard drives BUT it will cost you an arm and a leg for their services.
May 12, 2012 | Western Digital WD My Book Essential 1TB,...
Hi, I have a WD external HD (my book essential) that doesnt seems to be read by any of the pcs I've tried to plug it on. It doesnt make a sound or even blinks that blues light. I tried to change...
This unit requires separate AC power. If the blue light is not on to begin with - indicating power, no PC will be able to read the USB. There is a hard disc in the unit that needs to spin...it is not solid state like a thumb drive.
Jun 13, 2011 | Western Digital My Book Essential...
When I plug in my WD 1TB drive it powers up and goes right back off. Any ideas or suggestions? It is 2 years old and has worked fine until now.
WD has had major issues with one of its chipsets (pitted IC due to thermals).
Have you tried the hhd on other machines and got the same issue?
Again, it is just a serious issue WD had with their "My Book" products.
Don't fret, the data is still on the hd and you can utilize it once you get the proper pcb for it.
Apr 13, 2011 | Western Digital My Book Essential 1TB...
I have WD My Book Essential 2 capacity 500 GB. Unfortunately everytime I connect it to the PC and power, does not show as a hard drive and has no driver. I backed up my files on it from the same computer...
you may have a bad drive,but first dose the drive power up not just light up can you hear the drive.
what you have in the box is just a nornal HD in an external box. you can if "absolutely nessesary " remove the HD and put it into your PC as a second drive.
but first you need to know if it is running and if the WD My Book power supple is working.
Have you tried using a different USB cable? a different power supply of the same Voltage & amps.
Mar 25, 2011 | Western Digital My Book Essential Edition...
WD 640Gb My Book Essential: HD on main computer
files must be "imported" into your new mail program.
the new computer may have a newer or different version.
Apr 08, 2010 | Western Digital My Book Essential Edition...
I accidentally plugged a 19V adapter to my 12V WD 1.5TB Hdd, now the hdd is dead
You'll have to hope that you have only blown a fuse on your HD Drive. other wise you will have to buy a new one. Have it checked by a tech and see if the HD itself can still be salvaged.
Dec 15, 2009 | Western Digital My Book Essential 1TB...
Western digital my book essential edition 320gb no installer
try this go to comp, right click go to properties,got to devives in the top left hand corner open this go down the the bottom click on usb controllers then scan for new hardware.
Jul 31, 2009 | Western Digital My Book Essential Edition...
WD 500gb external HD shuts down when plugged into USB port
Try a replacement USB cable first. If that does not fix the problem, then the USB to SATA adapter board is faulty, in that case you will need to take out the internal disk to replace the external enclosure.
see
YouTube - How To: Take Apart A Western Digital My Book Enclosure
If unit is under warranty see : WD Support > Warranty Services > End User > Warranty Policy.
Note any SATA external enclosure willl work wthe same with the internal WD HD.
Apr 17, 2009 | Western Digital My Book Home Edition 500...
Win98se i did it ... HERE'S HOW
OK, I bought this Western Digital MyBook 500 GB Essential Edition too, and could not get it to work with Windows 98 SE.
I followed the above instructions, but my version of windows was missing even the drivers suggested above! UGH!
HOWEVER, I found ANOTHER SOLUTION. I installed USB 2.0 drivers for mass storage and the the MY BOOK icon popped up on my Windows 98 SE machine. Hurray! Hurray! Hurray!
Here are the drivers from this british webpage:
http://www.technical-assistance.co.uk/kb/win98se-usb-mass-storage-drivers.php
Good luck to all you frustrated folks scooping your info off Windows 98 machines!
Dec 29, 2007 | Western Digital My Book Essential Edition...
Western Digital My Book Essential 1TB External USB 2.0 Hard Drive Logo
321 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
